Interface for Offset feature. More...
#include <FeaturesAPI_Offset.h>
| FeaturesAPI_Offset (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| FeaturesAPI_Offset (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theBaseObject, const ModelHighAPI_Double &theOffset, const bool isPipeJoint) | |
| FeaturesAPI_Offset (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theBaseObject, const ModelHighAPI_Double &theOffset, const std::list< ModelHighAPI_Selection > &theFaces) | |
| virtual | ~FeaturesAPI_Offset () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeString > | creationMethod () const |
| Creation method. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | baseObject () const |
| Base object. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | offsetValue () const |
| Value of the offset. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | isPipeJoint () const |
| Is pipe or intersection joint. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | faces () const |
| List of faces for partial offset. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeString > | mycreationMethod |
| std::shared_ptr< ModelAPI_AttributeSelection > | mybaseObject |
| std::shared_ptr< ModelAPI_AttributeDouble > | myoffsetValue |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myisPipeJoint |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | myfaces |
explicit |
explicit |
explicit |
inlinevirtual |
Creation method.
inlinevirtual |
Base object.
inlinevirtual |
inlinevirtual |
inlinevirtual |
protectedinherited |
