FeaturesAPI_Pipe.h
20#ifndef FeaturesAPI_Pipe_H_
21#define FeaturesAPI_Pipe_H_
23#include "FeaturesAPI.h"
24
25#include <FeaturesPlugin_Pipe.h>
26
32
37{
38public:
40 FEATURESAPI_EXPORT
41 explicit FeaturesAPI_Pipe(const std::shared_ptr<ModelAPI_Feature>& theFeature);
42
44 FEATURESAPI_EXPORT
45 explicit FeaturesAPI_Pipe(const std::shared_ptr<ModelAPI_Feature>& theFeature,
46 const std::list<ModelHighAPI_Selection>& theBaseObjects,
47 const ModelHighAPI_Selection& thePath);
48
50 FEATURESAPI_EXPORT
51 explicit FeaturesAPI_Pipe(const std::shared_ptr<ModelAPI_Feature>& theFeature,
52 const std::list<ModelHighAPI_Selection>& theBaseObjects,
53 const ModelHighAPI_Selection& thePath,
54 const ModelHighAPI_Selection& theBiNoramal);
55
57 FEATURESAPI_EXPORT
58 explicit FeaturesAPI_Pipe(const std::shared_ptr<ModelAPI_Feature>& theFeature,
59 const std::list<ModelHighAPI_Selection>& theBaseObjects,
60 const ModelHighAPI_Selection& thePath,
61 const std::list<ModelHighAPI_Selection>& theLocations);
62
64 FEATURESAPI_EXPORT
65 virtual ~FeaturesAPI_Pipe();
66
67 INTERFACE_5(FeaturesPlugin_Pipe::ID(),
78
79
80 FEATURESAPI_EXPORT
81 void setBase(const std::list<ModelHighAPI_Selection>& theBaseObjects);
82
84 FEATURESAPI_EXPORT
85 void setPath(const ModelHighAPI_Selection& thePath);
86
88 FEATURESAPI_EXPORT
89 void setByBasePath(const std::list<ModelHighAPI_Selection>& theBaseObjects,
90 const ModelHighAPI_Selection& thePath);
91
93 FEATURESAPI_EXPORT
94 void setByBasePathBiNormal(const std::list<ModelHighAPI_Selection>& theBaseObjects,
95 const ModelHighAPI_Selection& thePath,
96 const ModelHighAPI_Selection& theBiNoramal);
97
99 FEATURESAPI_EXPORT
100 void setByBasePathLocations(const std::list<ModelHighAPI_Selection>& theBaseObjects,
101 const ModelHighAPI_Selection& thePath,
102 const std::list<ModelHighAPI_Selection>& theLocations);
103
105 FEATURESAPI_EXPORT
106 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
107};
108
110typedef std::shared_ptr<FeaturesAPI_Pipe> PipePtr;
111
114FEATURESAPI_EXPORT
115PipePtr addPipe(const std::shared_ptr<ModelAPI_Document>& thePart,
116 const std::list<ModelHighAPI_Selection>& theBaseObjects,
117 const ModelHighAPI_Selection& thePath);
118
121FEATURESAPI_EXPORT
122PipePtr addPipe(const std::shared_ptr<ModelAPI_Document>& thePart,
123 const std::list<ModelHighAPI_Selection>& theBaseObjects,
124 const ModelHighAPI_Selection& thePath,
125 const ModelHighAPI_Selection& theBiNoramal);
126
129FEATURESAPI_EXPORT
130PipePtr addPipe(const std::shared_ptr<ModelAPI_Document>& thePart,
131 const std::list<ModelHighAPI_Selection>& theBaseObjects,
132 const ModelHighAPI_Selection& thePath,
133 const std::list<ModelHighAPI_Selection>& theLocations);
134
135#endif // FeaturesAPI_Pipe_H_
Interface for Pipe feature.
Definition: FeaturesAPI_Pipe.h:37
virtual std::shared_ptr< ModelAPI_AttributeSelection > path() const
Path.
Definition: FeaturesAPI_Pipe.h:77
void setByBasePathBiNormal(const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &thePath, const ModelHighAPI_Selection &theBiNoramal)
Modify creation method, base, path and bi-normal.
Definition: FeaturesAPI_Pipe.cpp:101
void setByBasePathLocations(const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &thePath, const std::list< ModelHighAPI_Selection > &theLocations)
Modify creation method, base, path and locations.
Definition: FeaturesAPI_Pipe.cpp:115
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > locations() const
Locations.
void setPath(const ModelHighAPI_Selection &thePath)
Modify path attribute of the feature.
Definition: FeaturesAPI_Pipe.cpp:82
Dump wrapped feature.
Definition: FeaturesAPI_Pipe.cpp:129
Definition: FeaturesAPI_Pipe.cpp:68
void setByBasePath(const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &thePath)
Modify creation method, base and path.
Definition: FeaturesAPI_Pipe.cpp:90
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > baseObjects() const
Base objects.
void setBase(const std::list< ModelHighAPI_Selection > &theBaseObjects)
Modify base attribute of the feature.
Definition: FeaturesAPI_Pipe.cpp:74
virtual std::shared_ptr< ModelAPI_AttributeSelection > biNormal() const
Bi-Normal.
virtual std::shared_ptr< ModelAPI_AttributeString > creationMethod() const
Creation method.
FeaturesAPI_Pipe(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_Pipe.cpp:26
static const std::string & PATH_OBJECT_ID()
Attribute name of path object.
Definition: FeaturesPlugin_Pipe.h:85
static const std::string & LOCATIONS_ID()
Attribute name of locations.
Definition: FeaturesPlugin_Pipe.h:99
static const std::string & BINORMAL_ID()
Attribute name of Bi-Normal.
Definition: FeaturesPlugin_Pipe.h:92
Feature kind.
Definition: FeaturesPlugin_Pipe.h:43
Definition: FeaturesPlugin_Pipe.h:78
Definition: FeaturesPlugin_Pipe.h:50
Dump engine for the model.
PipePtr addPipe(const std::shared_ptr< ModelAPI_Document > &thePart, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &thePath)
Create Pipe feature.
Definition: FeaturesAPI_Pipe.cpp:160
