FeaturesAPI_Pipe Class Reference
Interface for Pipe feature. More...
#include <FeaturesAPI_Pipe.h>
Inheritance diagram for FeaturesAPI_Pipe:
 FeaturesAPI_Pipe (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 FeaturesAPI_Pipe (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &thePath)
 FeaturesAPI_Pipe (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &thePath, const ModelHighAPI_Selection &theBiNoramal)
 FeaturesAPI_Pipe (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &thePath, const std::list< ModelHighAPI_Selection > &theLocations)
virtual ~FeaturesAPI_Pipe ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > baseObjects () const
 Base objects. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > path () const
 Path. More...
 Creation method. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > biNormal () const
 Bi-Normal. More...
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > locations () const
 Locations. More...
void setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects)
 Modify base attribute of the feature. More...
void setPath (const ModelHighAPI_Selection &thePath)
 Modify path attribute of the feature. More...
void setByBasePath (const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &thePath)
 Modify creation method, base and path. More...
void setByBasePathBiNormal (const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &thePath, const ModelHighAPI_Selection &theBiNoramal)
 Modify creation method, base, path and bi-normal. More...
void setByBasePathLocations (const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &thePath, const std::list< ModelHighAPI_Selection > &theLocations)
 Modify creation method, base, path and locations. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > mybaseObjects
std::shared_ptr< ModelAPI_AttributeSelection > mypath
std::shared_ptr< ModelAPI_AttributeSelection > mybiNormal
std::shared_ptr< ModelAPI_AttributeSelectionList > mylocations
◆ FeaturesAPI_Pipe() [1/4]
FeaturesAPI_Pipe::FeaturesAPI_Pipe ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ FeaturesAPI_Pipe() [2/4]
FeaturesAPI_Pipe::FeaturesAPI_Pipe ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< ModelHighAPI_Selection > &  theBaseObjects,
const ModelHighAPI_Selection &  thePath
explicit
◆ FeaturesAPI_Pipe() [3/4]
const ModelHighAPI_Selection &  thePath,
const ModelHighAPI_Selection &  theBiNoramal
explicit
◆ FeaturesAPI_Pipe() [4/4]
const std::list< ModelHighAPI_Selection > &  theLocations
explicit
◆ ~FeaturesAPI_Pipe()
FeaturesAPI_Pipe::~FeaturesAPI_Pipe ( )
◆ baseObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_Pipe::baseObjects ( ) const
Base objects.
◆ path()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_Pipe::path ( ) const
Path.
◆ creationMethod()
virtual std::shared_ptr< ModelAPI_AttributeString > FeaturesAPI_Pipe::creationMethod ( ) const
Creation method.
◆ biNormal()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_Pipe::biNormal ( ) const
Bi-Normal.
◆ locations()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_Pipe::locations ( ) const
Locations.
◆ setBase()
void FeaturesAPI_Pipe::setBase ( const std::list< ModelHighAPI_Selection > &  theBaseObjects)
◆ setPath()
void FeaturesAPI_Pipe::setPath ( const ModelHighAPI_Selection &  thePath)
◆ setByBasePath()
void FeaturesAPI_Pipe::setByBasePath ( const std::list< ModelHighAPI_Selection > &  theBaseObjects,
◆ setByBasePathBiNormal()
void FeaturesAPI_Pipe::setByBasePathBiNormal ( const std::list< ModelHighAPI_Selection > &  theBaseObjects,
◆ setByBasePathLocations()
void FeaturesAPI_Pipe::setByBasePathLocations ( const std::list< ModelHighAPI_Selection > &  theBaseObjects,
◆ dump()
void FeaturesAPI_Pipe::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
