FeaturesAPI_RemoveSubShapes.h
20#ifndef FeaturesAPI_RemoveSubShapes_H_
21#define FeaturesAPI_RemoveSubShapes_H_
23#include "FeaturesAPI.h"
24
25#include <FeaturesPlugin_RemoveSubShapes.h>
26
32
37{
38public:
40 FEATURESAPI_EXPORT
41 explicit FeaturesAPI_RemoveSubShapes(const std::shared_ptr<ModelAPI_Feature>& theFeature);
42
44 FEATURESAPI_EXPORT
45 explicit FeaturesAPI_RemoveSubShapes(const std::shared_ptr<ModelAPI_Feature>& theFeature,
46 const ModelHighAPI_Selection& theBase);
47
49 FEATURESAPI_EXPORT
51
61
62
63 FEATURESAPI_EXPORT
64 void setBase(const ModelHighAPI_Selection& theBase);
65
67 FEATURESAPI_EXPORT
68 void setSubShapesToKeep(const std::list<ModelHighAPI_Selection>& theSubShapes);
69
71 FEATURESAPI_EXPORT
72 void setSubShapesToRemove(const std::list<ModelHighAPI_Selection>& theSubShapes);
73
75 FEATURESAPI_EXPORT
76 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
77};
78
80typedef std::shared_ptr<FeaturesAPI_RemoveSubShapes> RemoveSubShapesPtr;
81
84FEATURESAPI_EXPORT
85RemoveSubShapesPtr addRemoveSubShapes(const std::shared_ptr<ModelAPI_Document>& thePart,
86 const ModelHighAPI_Selection& theBase);
87
88#endif // FeaturesAPI_RemoveSubShapes_H_
Interface for RemoveSubShapes feature.
Definition: FeaturesAPI_RemoveSubShapes.h:37
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > subshapesToRemove() const
Subshapes to remove.
Definition: FeaturesAPI_RemoveSubShapes.h:60
virtual std::shared_ptr< ModelAPI_AttributeString > creationMethod() const
Creation method.
virtual ~FeaturesAPI_RemoveSubShapes()
Definition: FeaturesAPI_RemoveSubShapes.cpp:47
void setSubShapesToKeep(const std::list< ModelHighAPI_Selection > &theSubShapes)
Modify tools attribute of the feature.
Definition: FeaturesAPI_RemoveSubShapes.cpp:61
virtual std::shared_ptr< ModelAPI_AttributeSelection > base() const
Base.
FeaturesAPI_RemoveSubShapes(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_RemoveSubShapes.cpp:26
void setSubShapesToRemove(const std::list< ModelHighAPI_Selection > &theSubShapes)
Definition: FeaturesAPI_RemoveSubShapes.cpp:72
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > subshapesToKeep() const
Subshapes to keep.
Dump wrapped feature.
Definition: FeaturesAPI_RemoveSubShapes.cpp:83
void setBase(const ModelHighAPI_Selection &theBase)
Modify objects attribute of the feature.
Definition: FeaturesAPI_RemoveSubShapes.cpp:53
Definition: FeaturesPlugin_RemoveSubShapes.h:51
Feature kind.
Definition: FeaturesPlugin_RemoveSubShapes.h:37
static const std::string & BASE_SHAPE_ID()
Attribute name of base shape.
Definition: FeaturesPlugin_RemoveSubShapes.h:44
static const std::string & SUBSHAPES_TO_KEEP_ID()
Attribute name of sub-shapes to keep.
Definition: FeaturesPlugin_RemoveSubShapes.h:72
static const std::string & SUBSHAPES_TO_REMOVE_ID()
Attribute name of sub-shapes to remove.
Definition: FeaturesPlugin_RemoveSubShapes.h:79
Dump engine for the model.
RemoveSubShapesPtr addRemoveSubShapes(const std::shared_ptr< ModelAPI_Document > &thePart, const ModelHighAPI_Selection &theBase)
Create RemoveSubShapes feature.
Definition: FeaturesAPI_RemoveSubShapes.cpp:116
