Interface for RemoveSubShapes feature. More...
#include <FeaturesAPI_RemoveSubShapes.h>
| FeaturesAPI_RemoveSubShapes (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| FeaturesAPI_RemoveSubShapes (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theBase) | |
| virtual | ~FeaturesAPI_RemoveSubShapes () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | base () const |
| Base. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeString > | creationMethod () const |
| Creation method. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | subshapesToKeep () const |
| Subshapes to keep. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | subshapesToRemove () const |
| Subshapes to remove. More... | |
| void | setBase (const ModelHighAPI_Selection &theBase) |
| Modify objects attribute of the feature. More... | |
| void | setSubShapesToKeep (const std::list< ModelHighAPI_Selection > &theSubShapes) |
| Modify tools attribute of the feature. More... | |
| void | setSubShapesToRemove (const std::list< ModelHighAPI_Selection > &theSubShapes) |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelection > | mybase |
| std::shared_ptr< ModelAPI_AttributeString > | mycreationMethod |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mysubshapesToKeep |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mysubshapesToRemove |
explicit |
explicit |
inlinevirtual |
Base.
inlinevirtual |
Creation method.
inlinevirtual |
Subshapes to keep.
inlinevirtual |
| void FeaturesAPI_RemoveSubShapes::setBase | ( | const ModelHighAPI_Selection & | theBase | ) |
| void FeaturesAPI_RemoveSubShapes::setSubShapesToKeep | ( | const std::list< ModelHighAPI_Selection > & | theSubShapes | ) |
| void FeaturesAPI_RemoveSubShapes::setSubShapesToRemove | ( | const std::list< ModelHighAPI_Selection > & | theSubShapes | ) |
protectedinherited |
