PrimitivesAPI_Cylinder.h
20#ifndef PRIMITIVESAPI_CYLINDER_H_
21#define PRIMITIVESAPI_CYLINDER_H_
23#include "PrimitivesAPI.h"
24
25#include <PrimitivesPlugin_Cylinder.h>
26
32
37{
38public:
40 PRIMITIVESAPI_EXPORT
41 explicit PrimitivesAPI_Cylinder(const std::shared_ptr<ModelAPI_Feature>& theFeature);
42
44 PRIMITIVESAPI_EXPORT
45 explicit PrimitivesAPI_Cylinder(const std::shared_ptr<ModelAPI_Feature>& theFeature,
46 const ModelHighAPI_Selection& theBasePoint,
47 const ModelHighAPI_Selection& theAxis,
48 const ModelHighAPI_Double& theRadius,
49 const ModelHighAPI_Double& theHeight);
50
52 PRIMITIVESAPI_EXPORT
53 explicit PrimitivesAPI_Cylinder(const std::shared_ptr<ModelAPI_Feature>& theFeature,
54 const ModelHighAPI_Selection& theBasePoint,
55 const ModelHighAPI_Selection& theAxis,
56 const ModelHighAPI_Double& theRadius,
57 const ModelHighAPI_Double& theHeight,
58 const ModelHighAPI_Double& theAngle);
59
61 PRIMITIVESAPI_EXPORT
63
77
78
79 PRIMITIVESAPI_EXPORT
80 void setSizes(const ModelHighAPI_Double& theRadius,
81 const ModelHighAPI_Double& theHeight);
82
84 PRIMITIVESAPI_EXPORT
85 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
86};
87
89typedef std::shared_ptr<PrimitivesAPI_Cylinder> CylinderPtr;
90
93PRIMITIVESAPI_EXPORT
94CylinderPtr addCylinder(const std::shared_ptr<ModelAPI_Document>& thePart,
95 const ModelHighAPI_Selection& theBasePoint,
96 const ModelHighAPI_Selection& theAxis,
97 const ModelHighAPI_Double& theRadius,
98 const ModelHighAPI_Double& theHeight);
99
102PRIMITIVESAPI_EXPORT
103CylinderPtr addCylinder(const std::shared_ptr<ModelAPI_Document>& thePart,
104 const ModelHighAPI_Selection& theBasePoint,
105 const ModelHighAPI_Selection& theAxis,
106 const ModelHighAPI_Double& theRadius,
107 const ModelHighAPI_Double& theHeight,
108 const ModelHighAPI_Double& theAngle);
109
112PRIMITIVESAPI_EXPORT
113CylinderPtr addCylinder(const std::shared_ptr<ModelAPI_Document>& thePart,
114 const ModelHighAPI_Double& theRadius,
115 const ModelHighAPI_Double& theHeight);
116
119PRIMITIVESAPI_EXPORT
120CylinderPtr addCylinder(const std::shared_ptr<ModelAPI_Document>& thePart,
121 const ModelHighAPI_Double& theRadius,
122 const ModelHighAPI_Double& theHeight,
123 const ModelHighAPI_Double& theAngle);
124
125#endif // PRIMITIVESAPI_CYLINDER_H_
Dump engine for the model.
Interface for primitive Cylinder feature.
Definition: PrimitivesAPI_Cylinder.h:37
virtual std::shared_ptr< ModelAPI_AttributeSelection > basePoint() const
Base point.
Definition: PrimitivesAPI_Cylinder.h:76
virtual std::shared_ptr< ModelAPI_AttributeDouble > angle() const
Angle.
Dump wrapped feature.
Definition: PrimitivesAPI_Cylinder.cpp:83
virtual std::shared_ptr< ModelAPI_AttributeString > creationMethod() const
Creation method.
void setSizes(const ModelHighAPI_Double &theRadius, const ModelHighAPI_Double &theHeight)
Set dimensions.
Definition: PrimitivesAPI_Cylinder.cpp:74
virtual std::shared_ptr< ModelAPI_AttributeDouble > radius() const
Radius.
virtual ~PrimitivesAPI_Cylinder()
Definition: PrimitivesAPI_Cylinder.cpp:68
virtual std::shared_ptr< ModelAPI_AttributeSelection > axis() const
Axis.
PrimitivesAPI_Cylinder(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: PrimitivesAPI_Cylinder.cpp:27
virtual std::shared_ptr< ModelAPI_AttributeDouble > height() const
Height.
static const std::string & HEIGHT_ID()
Attribute name of the height.
Definition: PrimitivesPlugin_Cylinder.h:90
static const std::string & BASE_POINT_ID()
Attribute name of the base point.
Definition: PrimitivesPlugin_Cylinder.h:69
Definition: PrimitivesPlugin_Cylinder.h:48
static const std::string & ANGLE_ID()
Attribute name of the angle.
Definition: PrimitivesPlugin_Cylinder.h:97
static const std::string & AXIS_ID()
Attribute name of the axis.
Definition: PrimitivesPlugin_Cylinder.h:76
Attribute name of the radius.
Definition: PrimitivesPlugin_Cylinder.h:83
Cylinder kind.
Definition: PrimitivesPlugin_Cylinder.h:41
CylinderPtr addCylinder(const std::shared_ptr< ModelAPI_Document > &thePart, const ModelHighAPI_Selection &theBasePoint, const ModelHighAPI_Selection &theAxis, const ModelHighAPI_Double &theRadius, const ModelHighAPI_Double &theHeight)
Create primitive Cylinder feature.
Definition: PrimitivesAPI_Cylinder.cpp:111
