PrimitivesAPI_Cylinder Class Reference
Interface for primitive Cylinder feature. More...
#include <PrimitivesAPI_Cylinder.h>
Inheritance diagram for PrimitivesAPI_Cylinder:
 PrimitivesAPI_Cylinder (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 PrimitivesAPI_Cylinder (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theBasePoint, const ModelHighAPI_Selection &theAxis, const ModelHighAPI_Double &theRadius, const ModelHighAPI_Double &theHeight)
 PrimitivesAPI_Cylinder (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theBasePoint, const ModelHighAPI_Selection &theAxis, const ModelHighAPI_Double &theRadius, const ModelHighAPI_Double &theHeight, const ModelHighAPI_Double &theAngle)
virtual ~PrimitivesAPI_Cylinder ()
virtual std::string getID ()
 Creation method. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > basePoint () const
 Base point. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > axis () const
 Axis. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > radius () const
 Radius. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > height () const
 Height. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > angle () const
 Angle. More...
void setSizes (const ModelHighAPI_Double &theRadius, const ModelHighAPI_Double &theHeight)
 Set dimensions. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelection > mybasePoint
std::shared_ptr< ModelAPI_AttributeSelection > myaxis
std::shared_ptr< ModelAPI_AttributeDouble > myradius
std::shared_ptr< ModelAPI_AttributeDouble > myheight
std::shared_ptr< ModelAPI_AttributeDouble > myangle
◆ PrimitivesAPI_Cylinder() [1/3]
PrimitivesAPI_Cylinder::PrimitivesAPI_Cylinder ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ PrimitivesAPI_Cylinder() [2/3]
PrimitivesAPI_Cylinder::PrimitivesAPI_Cylinder ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const ModelHighAPI_Selection &  theBasePoint,
const ModelHighAPI_Selection &  theAxis,
const ModelHighAPI_Double &  theRadius,
const ModelHighAPI_Double &  theHeight
explicit
◆ PrimitivesAPI_Cylinder() [3/3]
const ModelHighAPI_Double &  theHeight,
const ModelHighAPI_Double &  theAngle
explicit
◆ ~PrimitivesAPI_Cylinder()
PrimitivesAPI_Cylinder::~PrimitivesAPI_Cylinder ( )
◆ creationMethod()
virtual std::shared_ptr< ModelAPI_AttributeString > PrimitivesAPI_Cylinder::creationMethod ( ) const
Creation method.
◆ basePoint()
virtual std::shared_ptr< ModelAPI_AttributeSelection > PrimitivesAPI_Cylinder::basePoint ( ) const
Base point.
◆ axis()
virtual std::shared_ptr< ModelAPI_AttributeSelection > PrimitivesAPI_Cylinder::axis ( ) const
Axis.
◆ radius()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Cylinder::radius ( ) const
Radius.
◆ height()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Cylinder::height ( ) const
Height.
◆ angle()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Cylinder::angle ( ) const
Angle.
◆ setSizes()
void PrimitivesAPI_Cylinder::setSizes ( const ModelHighAPI_Double &  theRadius,
Set dimensions.
◆ dump()
void PrimitivesAPI_Cylinder::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
