24#ifndef PRIMITIVESAPI_SPHERE_H_
25#define PRIMITIVESAPI_SPHERE_H_
27#include "PrimitivesAPI.h"
29#include <PrimitivesPlugin_Sphere.h>
31#include <ModelHighAPI_Interface.h>
32#include <ModelHighAPI_Macro.h>
Dump engine for the model.
Interface for primitive Sphere feature.
Definition: PrimitivesAPI_Sphere.h:41
virtual std::shared_ptr< ModelAPI_AttributeDouble > phimax() const
The maximum phi.
Definition: PrimitivesAPI_Sphere.h:85
void setPhi(const ModelHighAPI_Double &thePhiMin, const ModelHighAPI_Double &thePhiMax)
Set minimum and maximum phi.
Definition: PrimitivesAPI_Sphere.cpp:101
virtual std::shared_ptr< ModelAPI_AttributeString > creationMethod() const
Creation method.
virtual std::shared_ptr< ModelAPI_AttributeSelection > centerPoint() const
Center point.
void setCenterPoint(const ModelHighAPI_Selection &theCenterPoint)
Set center point.
Definition: PrimitivesAPI_Sphere.cpp:78
virtual std::shared_ptr< ModelAPI_AttributeDouble > rmax() const
The maximum radius.
virtual std::shared_ptr< ModelAPI_AttributeDouble > thetamin() const
The minimum theta.
virtual std::shared_ptr< ModelAPI_AttributeDouble > phimin() const
The minimum phi.
void setRadius(const ModelHighAPI_Double &theRadius)
Set radius.
Definition: PrimitivesAPI_Sphere.cpp:85
virtual std::shared_ptr< ModelAPI_AttributeDouble > rmin() const
The minimum radius.
virtual std::shared_ptr< ModelAPI_AttributeDouble > radius() const
Radius.
PrimitivesAPI_Sphere(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: PrimitivesAPI_Sphere.cpp:31
void setTheta(const ModelHighAPI_Double &theThetaMin, const ModelHighAPI_Double &theThetaMax)
Set minimum and maximum theta.
Definition: PrimitivesAPI_Sphere.cpp:110
virtual std::shared_ptr< ModelAPI_AttributeDouble > thetamax() const
The maximum theta.
virtual ~PrimitivesAPI_Sphere()
Definition: PrimitivesAPI_Sphere.cpp:73
Dump wrapped feature.
Definition: PrimitivesAPI_Sphere.cpp:119
static const std::string & THETAMIN_ID()
attribute name of the lower theta limit
Definition: PrimitivesPlugin_Sphere.h:112
static const std::string & RMIN_ID()
attribute name of the inner radius
Definition: PrimitivesPlugin_Sphere.h:84
Attribute name of the radius.
Definition: PrimitivesPlugin_Sphere.h:77
Definition: PrimitivesPlugin_Sphere.h:49
static const std::string & THETAMAX_ID()
attribute name of the higher theta limit
Definition: PrimitivesPlugin_Sphere.h:119
Sphere kind.
Definition: PrimitivesPlugin_Sphere.h:42
static const std::string & RMAX_ID()
attribute name of the outer radius
Definition: PrimitivesPlugin_Sphere.h:91
static const std::string & PHIMIN_ID()
attribute name of the lower phi limit
Definition: PrimitivesPlugin_Sphere.h:98
static const std::string & PHIMAX_ID()
attribute name of the higher phi limit
Definition: PrimitivesPlugin_Sphere.h:105
static const std::string & CENTER_POINT_ID()
Attribute name of the base point.
Definition: PrimitivesPlugin_Sphere.h:70
SpherePtr addSphere(const std::shared_ptr< ModelAPI_Document > &thePart, const ModelHighAPI_Selection &theCenterPoint, const ModelHighAPI_Double &theRadius)
Create primitive Sphere feature.
Definition: PrimitivesAPI_Sphere.cpp:149
