PrimitivesAPI_Sphere Class Reference
Interface for primitive Sphere feature. More...
#include <PrimitivesAPI_Sphere.h>
Inheritance diagram for PrimitivesAPI_Sphere:
 PrimitivesAPI_Sphere (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 PrimitivesAPI_Sphere (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theCenterPoint, const ModelHighAPI_Double &theRadius)
 PrimitivesAPI_Sphere (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Double &theRMin, const ModelHighAPI_Double &theRMax, const ModelHighAPI_Double &thePhiMin, const ModelHighAPI_Double &thePhiMax, const ModelHighAPI_Double &theThetaMin, const ModelHighAPI_Double &theThetaMax)
virtual ~PrimitivesAPI_Sphere ()
virtual std::string getID ()
 Creation method. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > centerPoint () const
 Center point. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > radius () const
 Radius. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > rmin () const
 The minimum radius. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > rmax () const
 The maximum radius. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > phimin () const
 The minimum phi. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > phimax () const
 The maximum phi. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > thetamin () const
 The minimum theta. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > thetamax () const
 The maximum theta. More...
void setCenterPoint (const ModelHighAPI_Selection &theCenterPoint)
 Set center point. More...
void setRadius (const ModelHighAPI_Double &theRadius)
 Set radius. More...
void setRadius (const ModelHighAPI_Double &theRMin, const ModelHighAPI_Double &theRMax)
 Set minimum and maximum radius. More...
void setPhi (const ModelHighAPI_Double &thePhiMin, const ModelHighAPI_Double &thePhiMax)
 Set minimum and maximum phi. More...
void setTheta (const ModelHighAPI_Double &theThetaMin, const ModelHighAPI_Double &theThetaMax)
 Set minimum and maximum theta. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelection > mycenterPoint
std::shared_ptr< ModelAPI_AttributeDouble > myradius
std::shared_ptr< ModelAPI_AttributeDouble > myrmin
std::shared_ptr< ModelAPI_AttributeDouble > myrmax
std::shared_ptr< ModelAPI_AttributeDouble > myphimin
std::shared_ptr< ModelAPI_AttributeDouble > myphimax
std::shared_ptr< ModelAPI_AttributeDouble > mythetamin
std::shared_ptr< ModelAPI_AttributeDouble > mythetamax
◆ PrimitivesAPI_Sphere() [1/3]
PrimitivesAPI_Sphere::PrimitivesAPI_Sphere ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ PrimitivesAPI_Sphere() [2/3]
PrimitivesAPI_Sphere::PrimitivesAPI_Sphere ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const ModelHighAPI_Selection &  theCenterPoint,
const ModelHighAPI_Double &  theRadius
explicit
◆ PrimitivesAPI_Sphere() [3/3]
const ModelHighAPI_Double &  theRMin,
const ModelHighAPI_Double &  theRMax,
const ModelHighAPI_Double &  thePhiMin,
const ModelHighAPI_Double &  thePhiMax,
const ModelHighAPI_Double &  theThetaMin,
const ModelHighAPI_Double &  theThetaMax
explicit
◆ ~PrimitivesAPI_Sphere()
PrimitivesAPI_Sphere::~PrimitivesAPI_Sphere ( )
◆ creationMethod()
virtual std::shared_ptr< ModelAPI_AttributeString > PrimitivesAPI_Sphere::creationMethod ( ) const
Creation method.
◆ centerPoint()
virtual std::shared_ptr< ModelAPI_AttributeSelection > PrimitivesAPI_Sphere::centerPoint ( ) const
Center point.
◆ radius()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Sphere::radius ( ) const
Radius.
◆ rmin()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Sphere::rmin ( ) const
The minimum radius.
◆ rmax()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Sphere::rmax ( ) const
The maximum radius.
◆ phimin()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Sphere::phimin ( ) const
The minimum phi.
◆ phimax()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Sphere::phimax ( ) const
The maximum phi.
◆ thetamin()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Sphere::thetamin ( ) const
The minimum theta.
◆ thetamax()
virtual std::shared_ptr< ModelAPI_AttributeDouble > PrimitivesAPI_Sphere::thetamax ( ) const
The maximum theta.
◆ setCenterPoint()
void PrimitivesAPI_Sphere::setCenterPoint ( const ModelHighAPI_Selection &  theCenterPoint)
Set center point.
◆ setRadius() [1/2]
void PrimitivesAPI_Sphere::setRadius ( const ModelHighAPI_Double &  theRadius)
Set radius.
◆ setRadius() [2/2]
void PrimitivesAPI_Sphere::setRadius ( const ModelHighAPI_Double &  theRMin,
◆ setPhi()
void PrimitivesAPI_Sphere::setPhi ( const ModelHighAPI_Double &  thePhiMin,
◆ setTheta()
void PrimitivesAPI_Sphere::setTheta ( const ModelHighAPI_Double &  theThetaMin,
◆ dump()
void PrimitivesAPI_Sphere::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
