BuildAPI_Interpolation Class Reference
Interface for Interpolation feature. More...
#include <BuildAPI_Interpolation.h>
Inheritance diagram for BuildAPI_Interpolation:
 BuildAPI_Interpolation (const FeaturePtr &theFeature)
 BuildAPI_Interpolation (const FeaturePtr &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &theStartTangent, const ModelHighAPI_Selection &theEndTangent, const bool theIsClosed, const bool theIsToReorder)
 BuildAPI_Interpolation (const FeaturePtr &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const bool theIsClosed, const bool theIsToReorder)
 Constructor with base objects, closed and reorder parameters. More...
 BuildAPI_Interpolation (const FeaturePtr &theFeature, const std::string &theXTexpression, const std::string &theYTexpression, const std::string &theZTexpression, const ModelHighAPI_Double &theMinT, const ModelHighAPI_Double &theMaxT, const ModelHighAPI_Integer &theNbStep)
 Constructor with expression analytical of X,Y andZ. More...
virtual ~BuildAPI_Interpolation ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > baseObjects () const
 Base objects. More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > closed () const
 Closed flag. More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > reorder () const
 Reorder flag. More...
virtual std::shared_ptr< ModelAPI_AttributeString > useTangents () const
 Use tangents flag. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > startTangent () const
 Start point tangent. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > endTangent () const
 End point tangent. More...
virtual std::shared_ptr< ModelAPI_AttributeString > xt () const
 xt expression More...
virtual std::shared_ptr< ModelAPI_AttributeString > yt () const
 yt expression More...
virtual std::shared_ptr< ModelAPI_AttributeString > zt () const
 zt expression More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > mint () const
 Min. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > maxt () const
 Max. More...
virtual std::shared_ptr< ModelAPI_AttributeInteger > numstep () const
 Number of steps. More...
virtual std::shared_ptr< ModelAPI_AttributeString > creationmethod () const
 Creation method. More...
void setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects)
 Modify base attribute of the feature. More...
void setClosed (const bool theIsClosed)
 Set closed flag. More...
void setReorder (const bool theIsToReorder)
 Set reorder flag. More...
void setUseTangents (const bool theIsToUseTangents)
 Set use tangents flag. More...
void setTangents (const ModelHighAPI_Selection &theStartTangent, const ModelHighAPI_Selection &theEndTangent)
 Set start and end tangents. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > mybaseObjects
std::shared_ptr< ModelAPI_AttributeBoolean > myclosed
std::shared_ptr< ModelAPI_AttributeBoolean > myreorder
std::shared_ptr< ModelAPI_AttributeString > myuseTangents
std::shared_ptr< ModelAPI_AttributeSelection > mystartTangent
std::shared_ptr< ModelAPI_AttributeSelection > myendTangent
std::shared_ptr< ModelAPI_AttributeString > myxt
std::shared_ptr< ModelAPI_AttributeString > myyt
std::shared_ptr< ModelAPI_AttributeString > myzt
std::shared_ptr< ModelAPI_AttributeDouble > mymint
std::shared_ptr< ModelAPI_AttributeDouble > mymaxt
std::shared_ptr< ModelAPI_AttributeInteger > mynumstep
std::shared_ptr< ModelAPI_AttributeString > mycreationmethod
◆ BuildAPI_Interpolation() [1/4]
BuildAPI_Interpolation::BuildAPI_Interpolation ( const FeaturePtr &  theFeature)
explicit
◆ BuildAPI_Interpolation() [2/4]
BuildAPI_Interpolation::BuildAPI_Interpolation ( const FeaturePtr &  theFeature,
const std::list< ModelHighAPI_Selection > &  theBaseObjects,
const ModelHighAPI_Selection &  theStartTangent,
const ModelHighAPI_Selection &  theEndTangent,
explicit
◆ BuildAPI_Interpolation() [3/4]
explicit
◆ BuildAPI_Interpolation() [4/4]
const std::string &  theXTexpression,
const std::string &  theYTexpression,
const std::string &  theZTexpression,
const ModelHighAPI_Double &  theMinT,
const ModelHighAPI_Double &  theMaxT,
const ModelHighAPI_Integer &  theNbStep
explicit
◆ ~BuildAPI_Interpolation()
BuildAPI_Interpolation::~BuildAPI_Interpolation ( )
◆ baseObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > BuildAPI_Interpolation::baseObjects ( ) const
Base objects.
◆ closed()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > BuildAPI_Interpolation::closed ( ) const
Closed flag.
◆ reorder()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > BuildAPI_Interpolation::reorder ( ) const
Reorder flag.
◆ useTangents()
virtual std::shared_ptr< ModelAPI_AttributeString > BuildAPI_Interpolation::useTangents ( ) const
Use tangents flag.
◆ startTangent()
virtual std::shared_ptr< ModelAPI_AttributeSelection > BuildAPI_Interpolation::startTangent ( ) const
◆ endTangent()
virtual std::shared_ptr< ModelAPI_AttributeSelection > BuildAPI_Interpolation::endTangent ( ) const
End point tangent.
◆ xt()
virtual std::shared_ptr< ModelAPI_AttributeString > BuildAPI_Interpolation::xt ( ) const
xt expression
◆ yt()
virtual std::shared_ptr< ModelAPI_AttributeString > BuildAPI_Interpolation::yt ( ) const
yt expression
◆ zt()
virtual std::shared_ptr< ModelAPI_AttributeString > BuildAPI_Interpolation::zt ( ) const
zt expression
◆ mint()
virtual std::shared_ptr< ModelAPI_AttributeDouble > BuildAPI_Interpolation::mint ( ) const
Min.
◆ maxt()
virtual std::shared_ptr< ModelAPI_AttributeDouble > BuildAPI_Interpolation::maxt ( ) const
Max.
◆ numstep()
virtual std::shared_ptr< ModelAPI_AttributeInteger > BuildAPI_Interpolation::numstep ( ) const
Number of steps.
◆ creationmethod()
virtual std::shared_ptr< ModelAPI_AttributeString > BuildAPI_Interpolation::creationmethod ( ) const
Creation method.
◆ setBase()
void BuildAPI_Interpolation::setBase ( const std::list< ModelHighAPI_Selection > &  theBaseObjects)
◆ setClosed()
void BuildAPI_Interpolation::setClosed ( const bool  theIsClosed)
Set closed flag.
◆ setReorder()
void BuildAPI_Interpolation::setReorder ( const bool  theIsToReorder)
Set reorder flag.
◆ setUseTangents()
void BuildAPI_Interpolation::setUseTangents ( const bool  theIsToUseTangents)
◆ setTangents()
void BuildAPI_Interpolation::setTangents ( const ModelHighAPI_Selection &  theStartTangent,
◆ dump()
void BuildAPI_Interpolation::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
