Interface for Fillet1D feature - fillet on vertices of a wire. More...
#include <FeaturesAPI_Fillet.h>
| FeaturesAPI_Fillet1D (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| FeaturesAPI_Fillet1D (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Double &theRadius) | |
| virtual | ~FeaturesAPI_Fillet1D () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeString > | creationMethod () const |
| Creation method. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | baseWires () const |
| Base objects. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | baseVertices () const |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | radius () const |
| Value of the fixed radius fillet. More... | |
| virtual void | setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects) |
| Modify base objects of the fillet. More... | |
| virtual void | setRadius (const ModelHighAPI_Double &theRadius) |
| Modify fillet to have fixed radius. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeString > | mycreationMethod |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mybaseWires |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mybaseVertices |
| std::shared_ptr< ModelAPI_AttributeDouble > | myradius |
explicit |
explicit |
inlinevirtual |
Creation method.
inlinevirtual |
Base objects.
inlinevirtual |
Base objects.
inlinevirtual |
Implements FeaturesAPI_Fillet.
protectedinherited |
