Interface for Fillet feature. More...
#include <FeaturesAPI_Fillet.h>
| virtual | ~FeaturesAPI_Fillet () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | radius () const =0 |
| virtual void | setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects)=0 |
| Modify base objects of the fillet. More... | |
| virtual void | setRadius (const ModelHighAPI_Double &theRadius)=0 |
| Modify fillet to have fixed radius. More... | |
| virtual void | dump (ModelHighAPI_Dumper &) const |
| FeaturesAPI_Fillet (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
Protected Attributes | |
inlinevirtual |
pure virtual |
Implemented in FeaturesAPI_Fillet1D, and FeaturesAPI_Fillet2D.
pure virtual |
pure virtual |
inlinevirtualinherited |
Reimplemented in BuildAPI_Compound, BuildAPI_CompSolid, BuildAPI_Edge, BuildAPI_Face, BuildAPI_Filling, BuildAPI_Interpolation, BuildAPI_Polyline, BuildAPI_Shell, BuildAPI_Solid, BuildAPI_SubShapes, BuildAPI_Vertex, BuildAPI_Wire, CollectionAPI_Field, CollectionAPI_Group, CollectionAPI_GroupAddition, CollectionAPI_GroupIntersection, CollectionAPI_GroupShape, CollectionAPI_GroupSubstraction, ConstructionAPI_Axis, ConstructionAPI_Plane, ConstructionAPI_Point, ExchangeAPI_Export, ExchangeAPI_Import, ExchangeAPI_Import_Image, FeaturesAPI_BooleanCommon, FeaturesAPI_BooleanCut, FeaturesAPI_BooleanFill, FeaturesAPI_BooleanFuse, FeaturesAPI_BooleanSmash, FeaturesAPI_BoundingBox, FeaturesAPI_Chamfer, FeaturesAPI_Copy, FeaturesAPI_Defeaturing, FeaturesAPI_Extrusion, FeaturesAPI_ExtrusionBoolean, FeaturesAPI_Fillet1D, FeaturesAPI_Fillet2D, FeaturesAPI_FusionFaces, FeaturesAPI_GlueFaces, FeaturesAPI_ImportResult, FeaturesAPI_Intersection, FeaturesAPI_LimitTolerance, FeaturesAPI_Loft, FeaturesAPI_MultiRotation, FeaturesAPI_MultiTranslation, FeaturesAPI_NormalToFace, FeaturesAPI_Offset, FeaturesAPI_Partition, FeaturesAPI_Pipe, FeaturesAPI_Placement, FeaturesAPI_PointCloudOnFace, FeaturesAPI_Recover, FeaturesAPI_RemoveExtraEdges, FeaturesAPI_RemoveResults, FeaturesAPI_RemoveSubShapes, FeaturesAPI_Revolution, FeaturesAPI_RevolutionBoolean, FeaturesAPI_Rotation, FeaturesAPI_Scale, FeaturesAPI_Sewing, FeaturesAPI_SharedFaces, FeaturesAPI_Symmetry, FeaturesAPI_Thickness, FeaturesAPI_Translation, FeaturesAPI_Union, FiltersAPI_Feature, GDMLAPI_ConeSegment, GDMLAPI_Ellipsoid, ModelHighAPI_Folder, ParametersAPI_Parameter, PartSetAPI_Part, PrimitivesAPI_Box, PrimitivesAPI_Cone, PrimitivesAPI_Cylinder, PrimitivesAPI_Sphere, PrimitivesAPI_Torus, PrimitivesAPI_Tube, SketchAPI_Arc, SketchAPI_BSpline, SketchAPI_Circle, SketchAPI_Constraint, SketchAPI_ConstraintAngle, SketchAPI_Ellipse, SketchAPI_EllipticArc, SketchAPI_IntersectionPoint, SketchAPI_Line, SketchAPI_Mirror, SketchAPI_Offset, SketchAPI_Point, SketchAPI_Projection, SketchAPI_Rotation, SketchAPI_Sketch, SketchAPI_SketchEntity, and SketchAPI_Translation.
protectedinherited |
