FeaturesAPI_Translation Class Reference
Interface for Translation feature. More...
#include <FeaturesAPI_Translation.h>
Inheritance diagram for FeaturesAPI_Translation:
 FeaturesAPI_Translation (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 FeaturesAPI_Translation (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const ModelHighAPI_Selection &theAxisObject, const ModelHighAPI_Double &theDistance)
 FeaturesAPI_Translation (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const ModelHighAPI_Double &theDx, const ModelHighAPI_Double &theDy, const ModelHighAPI_Double &theDz)
 FeaturesAPI_Translation (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const ModelHighAPI_Selection &theStartPoint, const ModelHighAPI_Selection &theEndPoint)
virtual ~FeaturesAPI_Translation ()
virtual std::string getID ()
 Creation method. More...
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > mainObjects () const
 Main objects. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > axisObject () const
 Axis object. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > distance () const
 Distance. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > dx () const
 Dimension in X. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > dy () const
 Dimension in Y. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > dz () const
 Dimension in Z. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > startPoint () const
 Start point object. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > endPoint () const
 End point object. More...
void setMainObjects (const std::list< ModelHighAPI_Selection > &theMainObjects)
 Set main objects. More...
void setAxisAndDistance (const ModelHighAPI_Selection &theAxisObject, const ModelHighAPI_Double &theDistance)
 Modify CreationMethod, axis_object, distance attributes of the feature. More...
void setDimensions (const ModelHighAPI_Double &theDx, const ModelHighAPI_Double &theDy, const ModelHighAPI_Double &theDz)
 Modify CreationMethod, dx, dy, dz attributes of the feature. More...
void setPoints (const ModelHighAPI_Selection &theStartPoint, const ModelHighAPI_Selection &theEndPoint)
 Modify CreationMethod, start_point, end_point attributes of the feature. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > mymainObjects
std::shared_ptr< ModelAPI_AttributeSelection > myaxisObject
std::shared_ptr< ModelAPI_AttributeDouble > mydistance
std::shared_ptr< ModelAPI_AttributeDouble > mydx
std::shared_ptr< ModelAPI_AttributeDouble > mydy
std::shared_ptr< ModelAPI_AttributeDouble > mydz
std::shared_ptr< ModelAPI_AttributeSelection > mystartPoint
std::shared_ptr< ModelAPI_AttributeSelection > myendPoint
◆ FeaturesAPI_Translation() [1/4]
FeaturesAPI_Translation::FeaturesAPI_Translation ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ FeaturesAPI_Translation() [2/4]
FeaturesAPI_Translation::FeaturesAPI_Translation ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< ModelHighAPI_Selection > &  theMainObjects,
const ModelHighAPI_Selection &  theAxisObject,
const ModelHighAPI_Double &  theDistance
explicit
◆ FeaturesAPI_Translation() [3/4]
const ModelHighAPI_Double &  theDx,
const ModelHighAPI_Double &  theDy,
const ModelHighAPI_Double &  theDz
explicit
◆ FeaturesAPI_Translation() [4/4]
const ModelHighAPI_Selection &  theStartPoint,
const ModelHighAPI_Selection &  theEndPoint
explicit
◆ ~FeaturesAPI_Translation()
FeaturesAPI_Translation::~FeaturesAPI_Translation ( )
◆ creationMethod()
virtual std::shared_ptr< ModelAPI_AttributeString > FeaturesAPI_Translation::creationMethod ( ) const
Creation method.
◆ mainObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_Translation::mainObjects ( ) const
Main objects.
◆ axisObject()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_Translation::axisObject ( ) const
Axis object.
◆ distance()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Translation::distance ( ) const
Distance.
◆ dx()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Translation::dx ( ) const
Dimension in X.
◆ dy()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Translation::dy ( ) const
Dimension in Y.
◆ dz()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Translation::dz ( ) const
Dimension in Z.
◆ startPoint()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_Translation::startPoint ( ) const
Start point object.
◆ endPoint()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_Translation::endPoint ( ) const
End point object.
◆ setMainObjects()
void FeaturesAPI_Translation::setMainObjects ( const std::list< ModelHighAPI_Selection > &  theMainObjects)
Set main objects.
◆ setAxisAndDistance()
void FeaturesAPI_Translation::setAxisAndDistance ( const ModelHighAPI_Selection &  theAxisObject,
◆ setDimensions()
void FeaturesAPI_Translation::setDimensions ( const ModelHighAPI_Double &  theDx,
◆ setPoints()
void FeaturesAPI_Translation::setPoints ( const ModelHighAPI_Selection &  theStartPoint,
◆ dump()
void FeaturesAPI_Translation::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
