FeaturesAPI_Thickness Class Reference
Interface for Thickness feature. More...
#include <FeaturesAPI_Thickness.h>
Inheritance diagram for FeaturesAPI_Thickness:
 FeaturesAPI_Thickness (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 FeaturesAPI_Thickness (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theBaseObject, const ModelHighAPI_Double &theThickness, const bool isInside)
 FeaturesAPI_Thickness (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theBaseObject, const ModelHighAPI_Double &theThickness, const std::list< ModelHighAPI_Selection > &theFaces, const bool isInside)
virtual ~FeaturesAPI_Thickness ()
virtual std::string getID ()
 Creation method. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > baseObject () const
 Base object. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > thicknessValue () const
 Value of the thickness. More...
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > faces () const
 List of faces to remove in hollowed solid mode. More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > isInside () const
 Do thicken towards inside. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelection > mybaseObject
std::shared_ptr< ModelAPI_AttributeDouble > mythicknessValue
std::shared_ptr< ModelAPI_AttributeSelectionList > myfaces
std::shared_ptr< ModelAPI_AttributeBoolean > myisInside
◆ FeaturesAPI_Thickness() [1/3]
FeaturesAPI_Thickness::FeaturesAPI_Thickness ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ FeaturesAPI_Thickness() [2/3]
FeaturesAPI_Thickness::FeaturesAPI_Thickness ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const ModelHighAPI_Selection &  theBaseObject,
const ModelHighAPI_Double &  theThickness,
const bool  isInside
explicit
◆ FeaturesAPI_Thickness() [3/3]
const std::list< ModelHighAPI_Selection > &  theFaces,
const bool  isInside
explicit
◆ ~FeaturesAPI_Thickness()
FeaturesAPI_Thickness::~FeaturesAPI_Thickness ( )
◆ creationMethod()
virtual std::shared_ptr< ModelAPI_AttributeString > FeaturesAPI_Thickness::creationMethod ( ) const
Creation method.
◆ baseObject()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_Thickness::baseObject ( ) const
Base object.
◆ thicknessValue()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Thickness::thicknessValue ( ) const
◆ faces() [1/2]
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_Thickness::faces ( ) const
◆ isInside()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > FeaturesAPI_Thickness::isInside ( ) const
◆ dump()
void FeaturesAPI_Thickness::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces() [2/2]
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
