SketchAPI_Translation Class Reference
Interface for Translation feature. More...
#include <SketchAPI_Translation.h>
Inheritance diagram for SketchAPI_Translation:
 SketchAPI_Translation (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 SketchAPI_Translation (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< std::shared_ptr< ModelAPI_Object > > &theObjects, const ModelHighAPI_RefAttr &thePoint1, const ModelHighAPI_RefAttr &thePoint2, const ModelHighAPI_Integer &theNumberOfObjects, bool theFullValue=false)
virtual ~SketchAPI_Translation ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeRefList > translationList () const
 Translation list. More...
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > startPoint () const
 Start point. More...
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > endPoint () const
virtual std::shared_ptr< ModelAPI_AttributeInteger > numberOfObjects () const
 Number of objects. More...
virtual std::shared_ptr< ModelAPI_AttributeString > valueType () const
 Value type. More...
virtual std::shared_ptr< ModelAPI_AttributeRefList > referenceObjects () const
 Reference objects. More...
virtual std::shared_ptr< ModelAPI_AttributeRefList > translatedObjects () const
 Translationed objects. More...
void setTranslationList (const std::list< std::shared_ptr< ModelAPI_Object > > &theObjects)
 Set list of objects to be translated. More...
std::list< std::shared_ptr< SketchAPI_SketchEntity > > translated () const
 List of translated objects. More...
std::list< std::shared_ptr< SketchAPI_SketchEntity > > translatedList () const
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeRefList > mytranslationList
std::shared_ptr< ModelAPI_AttributeRefAttr > mystartPoint
std::shared_ptr< ModelAPI_AttributeRefAttr > myendPoint
std::shared_ptr< ModelAPI_AttributeInteger > mynumberOfObjects
std::shared_ptr< ModelAPI_AttributeString > myvalueType
std::shared_ptr< ModelAPI_AttributeRefList > myreferenceObjects
std::shared_ptr< ModelAPI_AttributeRefList > mytranslatedObjects
◆ SketchAPI_Translation() [1/2]
SketchAPI_Translation::SketchAPI_Translation ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ SketchAPI_Translation() [2/2]
SketchAPI_Translation::SketchAPI_Translation ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< std::shared_ptr< ModelAPI_Object > > &  theObjects,
const ModelHighAPI_RefAttr &  thePoint1,
const ModelHighAPI_RefAttr &  thePoint2,
const ModelHighAPI_Integer &  theNumberOfObjects,
bool  theFullValue = false
◆ ~SketchAPI_Translation()
SketchAPI_Translation::~SketchAPI_Translation ( )
◆ translationList()
virtual std::shared_ptr< ModelAPI_AttributeRefList > SketchAPI_Translation::translationList ( ) const
Translation list.
◆ startPoint()
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > SketchAPI_Translation::startPoint ( ) const
Start point.
◆ endPoint()
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > SketchAPI_Translation::endPoint ( ) const
Start point.
◆ numberOfObjects()
virtual std::shared_ptr< ModelAPI_AttributeInteger > SketchAPI_Translation::numberOfObjects ( ) const
Number of objects.
◆ valueType()
virtual std::shared_ptr< ModelAPI_AttributeString > SketchAPI_Translation::valueType ( ) const
Value type.
◆ referenceObjects()
virtual std::shared_ptr< ModelAPI_AttributeRefList > SketchAPI_Translation::referenceObjects ( ) const
Reference objects.
◆ translatedObjects()
virtual std::shared_ptr< ModelAPI_AttributeRefList > SketchAPI_Translation::translatedObjects ( ) const
◆ setTranslationList()
void SketchAPI_Translation::setTranslationList ( const std::list< std::shared_ptr< ModelAPI_Object > > &  theObjects)
◆ translated()
std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_Translation::translated ( ) const
[DEPRECATED]: use translatedList() instead.
◆ translatedList()
std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_Translation::translatedList ( ) const
◆ dump()
void SketchAPI_Translation::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
