FeaturesAPI_Fillet2D Class Reference
Interface for Fillet feature - fillet edges on a solid. More...
#include <FeaturesAPI_Fillet.h>
Inheritance diagram for FeaturesAPI_Fillet2D:
 FeaturesAPI_Fillet2D (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 FeaturesAPI_Fillet2D (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Double &theRadius)
 FeaturesAPI_Fillet2D (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Double &theRadius1, const ModelHighAPI_Double &theRadius2)
virtual ~FeaturesAPI_Fillet2D ()
virtual std::string getID ()
 Creation method. More...
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > baseObjects () const
 Base objects. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > radius () const
 Value of the fixed radius fillet. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > startRadius () const
 Start radius of the varying radius fillet. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > endRadius () const
 End radius of the varying radius fillet. More...
virtual void setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects)
 Modify base objects of the fillet. More...
virtual void setRadius (const ModelHighAPI_Double &theRadius)
 Modify fillet to have fixed radius. More...
void setRadius (const ModelHighAPI_Double &theRadius1, const ModelHighAPI_Double &theRadius2)
 Modify fillet to have varying radius. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > mybaseObjects
std::shared_ptr< ModelAPI_AttributeDouble > myradius
std::shared_ptr< ModelAPI_AttributeDouble > mystartRadius
std::shared_ptr< ModelAPI_AttributeDouble > myendRadius
◆ FeaturesAPI_Fillet2D() [1/3]
FeaturesAPI_Fillet2D::FeaturesAPI_Fillet2D ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ FeaturesAPI_Fillet2D() [2/3]
FeaturesAPI_Fillet2D::FeaturesAPI_Fillet2D ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< ModelHighAPI_Selection > &  theBaseObjects,
const ModelHighAPI_Double &  theRadius
explicit
◆ FeaturesAPI_Fillet2D() [3/3]
const ModelHighAPI_Double &  theRadius1,
const ModelHighAPI_Double &  theRadius2
explicit
◆ ~FeaturesAPI_Fillet2D()
FeaturesAPI_Fillet2D::~FeaturesAPI_Fillet2D ( )
◆ creationMethod()
virtual std::shared_ptr< ModelAPI_AttributeString > FeaturesAPI_Fillet2D::creationMethod ( ) const
Creation method.
◆ baseObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_Fillet2D::baseObjects ( ) const
Base objects.
◆ radius()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Fillet2D::radius ( ) const
Implements FeaturesAPI_Fillet.
◆ startRadius()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Fillet2D::startRadius ( ) const
◆ endRadius()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Fillet2D::endRadius ( ) const
◆ setBase()
void FeaturesAPI_Fillet2D::setBase ( const std::list< ModelHighAPI_Selection > &  theBaseObjects)
◆ setRadius() [1/2]
void FeaturesAPI_Fillet2D::setRadius ( const ModelHighAPI_Double &  theRadius)
◆ setRadius() [2/2]
void FeaturesAPI_Fillet2D::setRadius ( const ModelHighAPI_Double &  theRadius1,
◆ dump()
void FeaturesAPI_Fillet2D::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
