SketchAPI_Offset Class Reference
Interface for Offset feature. More...
#include <SketchAPI_Offset.h>
Inheritance diagram for SketchAPI_Offset:
 SketchAPI_Offset (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 SketchAPI_Offset (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< std::shared_ptr< ModelAPI_Object > > &theObjects, const ModelHighAPI_Double &theOffsetValue, const bool theIsReversed=false, const std::string &theJointType=SketchPlugin_Offset::JOINT_KEEP_DISTANCE(), const bool theIsApprox=false)
virtual ~SketchAPI_Offset ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeRefList > edgesList () const
 Offset edges list. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > value () const
 Value. More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > reversed () const
 Negative value. More...
virtual std::shared_ptr< ModelAPI_AttributeString > joint () const
 Joint type. More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > approx () const
std::list< std::shared_ptr< SketchAPI_SketchEntity > > offset () const
 List of created objects. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeRefList > myedgesList
std::shared_ptr< ModelAPI_AttributeDouble > myvalue
std::shared_ptr< ModelAPI_AttributeBoolean > myreversed
std::shared_ptr< ModelAPI_AttributeString > myjoint
std::shared_ptr< ModelAPI_AttributeBoolean > myapprox
◆ SketchAPI_Offset() [1/2]
SketchAPI_Offset::SketchAPI_Offset ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ SketchAPI_Offset() [2/2]
SketchAPI_Offset::SketchAPI_Offset ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< std::shared_ptr< ModelAPI_Object > > &  theObjects,
const ModelHighAPI_Double &  theOffsetValue,
const bool  theIsReversed = false,
const std::string &  theJointType = SketchPlugin_Offset::JOINT_KEEP_DISTANCE(),
const bool  theIsApprox = false
◆ ~SketchAPI_Offset()
SketchAPI_Offset::~SketchAPI_Offset ( )
◆ edgesList()
virtual std::shared_ptr< ModelAPI_AttributeRefList > SketchAPI_Offset::edgesList ( ) const
Offset edges list.
◆ value()
virtual std::shared_ptr< ModelAPI_AttributeDouble > SketchAPI_Offset::value ( ) const
Value.
◆ reversed()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > SketchAPI_Offset::reversed ( ) const
Negative value.
◆ joint()
virtual std::shared_ptr< ModelAPI_AttributeString > SketchAPI_Offset::joint ( ) const
Joint type.
◆ approx()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > SketchAPI_Offset::approx ( ) const
Negative value.
◆ offset()
std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_Offset::offset ( ) const
◆ dump()
void SketchAPI_Offset::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
