20#ifndef SRC_SKETCHAPI_SKETCHAPI_OFFSET_H_
21#define SRC_SKETCHAPI_SKETCHAPI_OFFSET_H_
25#include "SketchAPI_SketchEntity.h"
29#include <SketchPlugin_Offset.h>
31#include <ModelHighAPI_Interface.h>
32#include <ModelHighAPI_Macro.h>
47 explicit SketchAPI_Offset(
const std::shared_ptr<ModelAPI_Feature> & theFeature);
51 const std::list<std::shared_ptr<ModelAPI_Object> > & theObjects,
53 const bool theIsReversed =
false,
55 const bool theIsApprox =
false);
Attribute that contains list of references to features (located in the same document).
Definition: ModelAPI_AttributeRefList.h:33
Represents any object in the data model and in the object browser.
Definition: ModelAPI_Object.h:45
Dump engine for the model.
Class for filling ModelAPI_AttributeRefAttr.
Definition: ModelHighAPI_RefAttr.h:41
Interface for Offset feature.
Definition: SketchAPI_Offset.h:43
virtual std::shared_ptr< ModelAPI_AttributeRefList > edgesList() const
Offset edges list.
Definition: SketchAPI_Offset.h:76
std::list< std::shared_ptr< SketchAPI_SketchEntity > > offset() const
List of created objects.
Definition: SketchAPI_Offset.cpp:57
virtual std::shared_ptr< ModelAPI_AttributeDouble > value() const
Value.
virtual std::shared_ptr< ModelAPI_AttributeBoolean > reversed() const
Negative value.
virtual std::shared_ptr< ModelAPI_AttributeString > joint() const
Joint type.
SketchAPI_Offset(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: SketchAPI_Offset.cpp:28
virtual std::shared_ptr< ModelAPI_AttributeBoolean > approx() const
Negative value.
Dump wrapped feature.
Definition: SketchAPI_Offset.cpp:71
virtual ~SketchAPI_Offset()
Definition: SketchAPI_Offset.cpp:53
static const std::string & APPROX_ID()
attribute to approx by segments and arcs
Definition: SketchPlugin_Offset.h:105
static const std::string & VALUE_ID()
attribute to store the offset value
Definition: SketchPlugin_Offset.h:91
static const std::string & REVERSED_ID()
attribute to store the reversed offset direction
Definition: SketchPlugin_Offset.h:98
static const std::string & EDGES_ID()
list of offset edges
Definition: SketchPlugin_Offset.h:84
Offset macro feature kind.
Definition: SketchPlugin_Offset.h:42
static const std::string & JOINT_ID()
Type of joint.
Definition: SketchPlugin_Offset.h:56
static const std::string & JOINT_KEEP_DISTANCE()
Keep distance joint (add arcs where needed)
Definition: SketchPlugin_Offset.h:63
