FeaturesAPI_MultiRotation Class Reference
Interface for Translation feature. More...
#include <FeaturesAPI_MultiRotation.h>
Inheritance diagram for FeaturesAPI_MultiRotation:
 FeaturesAPI_MultiRotation (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 FeaturesAPI_MultiRotation (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const ModelHighAPI_Selection &theAxis, const ModelHighAPI_Integer &theNumber)
 FeaturesAPI_MultiRotation (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const ModelHighAPI_Selection &theAxis, const ModelHighAPI_Double &theStep, const ModelHighAPI_Integer &theNumber)
virtual ~FeaturesAPI_MultiRotation ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > mainObjects () const
 Main objects. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > axisAngular () const
 Angular direction. More...
virtual std::shared_ptr< ModelAPI_AttributeString > useStepAngular () const
 Use step angular. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > stepAngular () const
 Step angular. More...
virtual std::shared_ptr< ModelAPI_AttributeInteger > nbAngular () const
 Number of copies for angular. More...
void setMainObjects (const std::list< ModelHighAPI_Selection > &theMainObjects)
 Set main objects. More...
void setAxisAngular (const ModelHighAPI_Selection &theAxis)
 Modify CreationMethod, axis_angular attribute of the feature. More...
void setStepAngular (const ModelHighAPI_Double &theStep)
 Modify CreationMethod, step_angular attribute of the feature. More...
void setNumberAngular (const ModelHighAPI_Integer &theNumber)
 Modify CreationMethod, nb_angular attribute of the feature. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > mymainObjects
std::shared_ptr< ModelAPI_AttributeSelection > myaxisAngular
std::shared_ptr< ModelAPI_AttributeString > myuseStepAngular
std::shared_ptr< ModelAPI_AttributeDouble > mystepAngular
std::shared_ptr< ModelAPI_AttributeInteger > mynbAngular
◆ FeaturesAPI_MultiRotation() [1/3]
FeaturesAPI_MultiRotation::FeaturesAPI_MultiRotation ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ FeaturesAPI_MultiRotation() [2/3]
FeaturesAPI_MultiRotation::FeaturesAPI_MultiRotation ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< ModelHighAPI_Selection > &  theMainObjects,
const ModelHighAPI_Selection &  theAxis,
const ModelHighAPI_Integer &  theNumber
◆ FeaturesAPI_MultiRotation() [3/3]
const ModelHighAPI_Double &  theStep,
◆ ~FeaturesAPI_MultiRotation()
FeaturesAPI_MultiRotation::~FeaturesAPI_MultiRotation ( )
◆ mainObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_MultiRotation::mainObjects ( ) const
Main objects.
◆ axisAngular()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_MultiRotation::axisAngular ( ) const
Angular direction.
◆ useStepAngular()
virtual std::shared_ptr< ModelAPI_AttributeString > FeaturesAPI_MultiRotation::useStepAngular ( ) const
Use step angular.
◆ stepAngular()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_MultiRotation::stepAngular ( ) const
Step angular.
◆ nbAngular()
virtual std::shared_ptr< ModelAPI_AttributeInteger > FeaturesAPI_MultiRotation::nbAngular ( ) const
◆ setMainObjects()
void FeaturesAPI_MultiRotation::setMainObjects ( const std::list< ModelHighAPI_Selection > &  theMainObjects)
Set main objects.
◆ setAxisAngular()
void FeaturesAPI_MultiRotation::setAxisAngular ( const ModelHighAPI_Selection &  theAxis)
◆ setStepAngular()
void FeaturesAPI_MultiRotation::setStepAngular ( const ModelHighAPI_Double &  theStep)
◆ setNumberAngular()
void FeaturesAPI_MultiRotation::setNumberAngular ( const ModelHighAPI_Integer &  theNumber)
◆ dump()
void FeaturesAPI_MultiRotation::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
