FeaturesAPI_MultiRotation.h
20// File: FeaturesAPI_MultiRotation.h
21// Created: 04 Apr 2017
22// Author: Clarisse Genrault (CEA)
23
24#ifndef FEATURESAPI_MULTIROTATION_H_
25#define FEATURESAPI_MULTIROTATION_H_
26
27#include "FeaturesAPI.h"
28
29#include <FeaturesPlugin_MultiRotation.h>
30
31#include <ModelHighAPI_Integer.h>
32#include <ModelHighAPI_Interface.h>
33#include <ModelHighAPI_Macro.h>
34
38
43{
44public:
46 FEATURESAPI_EXPORT
47 explicit FeaturesAPI_MultiRotation(const std::shared_ptr<ModelAPI_Feature>& theFeature);
48
50 FEATURESAPI_EXPORT
51 FeaturesAPI_MultiRotation(const std::shared_ptr<ModelAPI_Feature>& theFeature,
52 const std::list<ModelHighAPI_Selection>& theMainObjects,
53 const ModelHighAPI_Selection& theAxis,
54 const ModelHighAPI_Integer& theNumber);
55
57 FEATURESAPI_EXPORT
58 FeaturesAPI_MultiRotation(const std::shared_ptr<ModelAPI_Feature>& theFeature,
59 const std::list<ModelHighAPI_Selection>& theMainObjects,
60 const ModelHighAPI_Selection& theAxis,
61 const ModelHighAPI_Double& theStep,
62 const ModelHighAPI_Integer& theNumber);
63
65 FEATURESAPI_EXPORT
67
79 )
80
81
82 FEATURESAPI_EXPORT
83 void setMainObjects(const std::list<ModelHighAPI_Selection>& theMainObjects);
84
86 FEATURESAPI_EXPORT
87 void setAxisAngular(const ModelHighAPI_Selection& theAxis);
88
90 FEATURESAPI_EXPORT
91 void setStepAngular(const ModelHighAPI_Double& theStep);
92
94 FEATURESAPI_EXPORT
95 void setNumberAngular(const ModelHighAPI_Integer& theNumber);
96
98 FEATURESAPI_EXPORT
99 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
100};
101
103typedef std::shared_ptr<FeaturesAPI_MultiRotation> MultiRotationPtr;
104
107FEATURESAPI_EXPORT
108MultiRotationPtr addMultiRotation(const std::shared_ptr<ModelAPI_Document>& thePart,
109 const std::list<ModelHighAPI_Selection>& theMainObjects,
110 const ModelHighAPI_Selection& theAxis,
111 const ModelHighAPI_Double& theStep,
112 const ModelHighAPI_Integer& theNumber = ModelHighAPI_Integer(L""),
113 const bool keepSubResults = false);
114
115#endif // FEATURESAPI_MULTIROTATION_H_
Interface for Translation feature.
Definition: FeaturesAPI_MultiRotation.h:43
virtual std::shared_ptr< ModelAPI_AttributeString > useStepAngular() const
Use step angular.
Definition: FeaturesAPI_MultiRotation.h:79
virtual std::shared_ptr< ModelAPI_AttributeSelection > axisAngular() const
Angular direction.
void setStepAngular(const ModelHighAPI_Double &theStep)
Modify CreationMethod, step_angular attribute of the feature.
Definition: FeaturesAPI_MultiRotation.cpp:96
FeaturesAPI_MultiRotation(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_MultiRotation.cpp:31
virtual std::shared_ptr< ModelAPI_AttributeDouble > stepAngular() const
Step angular.
void setNumberAngular(const ModelHighAPI_Integer &theNumber)
Modify CreationMethod, nb_angular attribute of the feature.
Definition: FeaturesAPI_MultiRotation.cpp:104
virtual ~FeaturesAPI_MultiRotation()
Definition: FeaturesAPI_MultiRotation.cpp:74
Dump wrapped feature.
Definition: FeaturesAPI_MultiRotation.cpp:112
void setAxisAngular(const ModelHighAPI_Selection &theAxis)
Modify CreationMethod, axis_angular attribute of the feature.
Definition: FeaturesAPI_MultiRotation.cpp:88
void setMainObjects(const std::list< ModelHighAPI_Selection > &theMainObjects)
Set main objects.
Definition: FeaturesAPI_MultiRotation.cpp:79
virtual std::shared_ptr< ModelAPI_AttributeInteger > nbAngular() const
Number of copies for angular.
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > mainObjects() const
Main objects.
static const std::string & NB_COPIES_ANGULAR_ID()
Attribute name of number of copies for angular.
Definition: FeaturesPlugin_MultiRotation.h:79
Multi-rotation kind.
Definition: FeaturesPlugin_MultiRotation.h:44
static const std::string & USE_ANGULAR_STEP_ID()
Attribute name for use angular step.
Definition: FeaturesPlugin_MultiRotation.h:65
Attribute name of referenced objects.
Definition: FeaturesPlugin_MultiRotation.h:51
static const std::string & STEP_ANGULAR_ID()
Attribute name of step for the angular.
Definition: FeaturesPlugin_MultiRotation.h:72
static const std::string & AXIS_ANGULAR_ID()
Attribute name of the angular direction.
Definition: FeaturesPlugin_MultiRotation.h:58
API for the attribute that contains integer (int).
Definition: ModelAPI_AttributeInteger.h:34
Dump engine for the model.
Class for filling ModelAPI_AttributeInteger.
Definition: ModelHighAPI_Integer.h:36
MultiRotationPtr addMultiRotation(const std::shared_ptr< ModelAPI_Document > &thePart, const std::list< ModelHighAPI_Selection > &theMainObjects, const ModelHighAPI_Selection &theAxis, const ModelHighAPI_Double &theStep, const ModelHighAPI_Integer &theNumber=ModelHighAPI_Integer(L""), const bool keepSubResults=false)
Create MultiRotation feature.
Definition: FeaturesAPI_MultiRotation.cpp:143
