FeaturesAPI_Rotation Class Reference
Interface for Rotation feature. More...
#include <FeaturesAPI_Rotation.h>
Inheritance diagram for FeaturesAPI_Rotation:
 FeaturesAPI_Rotation (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 FeaturesAPI_Rotation (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const ModelHighAPI_Selection &theAxisObject, const ModelHighAPI_Double &theAngle)
 FeaturesAPI_Rotation (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const ModelHighAPI_Selection &theCenterPoint, const ModelHighAPI_Selection &theStartPoint, const ModelHighAPI_Selection &theEndPoint)
virtual ~FeaturesAPI_Rotation ()
virtual std::string getID ()
 Creation method. More...
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > mainObjects () const
 Main objects. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > axisObject () const
 Axis object. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > angle () const
 Angle. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > centerPoint () const
 Center point. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > startPoint () const
 Start point. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > endPoint () const
 End point. More...
void setMainObjects (const std::list< ModelHighAPI_Selection > &theMainObjects)
 Set main objects. More...
void setAxisObject (const ModelHighAPI_Selection &theAxisObject)
 Set axis object. More...
void setAngle (const ModelHighAPI_Double &theAngle)
 Set angle. More...
void setPoints (const ModelHighAPI_Selection &theCenterPoint, const ModelHighAPI_Selection &theStartPoint, const ModelHighAPI_Selection &theEndPoint)
 Set center point, start point and end point. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > mymainObjects
std::shared_ptr< ModelAPI_AttributeSelection > myaxisObject
std::shared_ptr< ModelAPI_AttributeDouble > myangle
std::shared_ptr< ModelAPI_AttributeSelection > mycenterPoint
std::shared_ptr< ModelAPI_AttributeSelection > mystartPoint
std::shared_ptr< ModelAPI_AttributeSelection > myendPoint
◆ FeaturesAPI_Rotation() [1/3]
FeaturesAPI_Rotation::FeaturesAPI_Rotation ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ FeaturesAPI_Rotation() [2/3]
FeaturesAPI_Rotation::FeaturesAPI_Rotation ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< ModelHighAPI_Selection > &  theMainObjects,
const ModelHighAPI_Selection &  theAxisObject,
const ModelHighAPI_Double &  theAngle
◆ FeaturesAPI_Rotation() [3/3]
const ModelHighAPI_Selection &  theCenterPoint,
const ModelHighAPI_Selection &  theStartPoint,
const ModelHighAPI_Selection &  theEndPoint
◆ ~FeaturesAPI_Rotation()
FeaturesAPI_Rotation::~FeaturesAPI_Rotation ( )
◆ creationMethod()
virtual std::shared_ptr< ModelAPI_AttributeString > FeaturesAPI_Rotation::creationMethod ( ) const
Creation method.
◆ mainObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_Rotation::mainObjects ( ) const
Main objects.
◆ axisObject()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_Rotation::axisObject ( ) const
Axis object.
◆ angle()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Rotation::angle ( ) const
Angle.
◆ centerPoint()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_Rotation::centerPoint ( ) const
Center point.
◆ startPoint()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_Rotation::startPoint ( ) const
Start point.
◆ endPoint()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_Rotation::endPoint ( ) const
End point.
◆ setMainObjects()
void FeaturesAPI_Rotation::setMainObjects ( const std::list< ModelHighAPI_Selection > &  theMainObjects)
Set main objects.
◆ setAxisObject()
void FeaturesAPI_Rotation::setAxisObject ( const ModelHighAPI_Selection &  theAxisObject)
Set axis object.
◆ setAngle()
void FeaturesAPI_Rotation::setAngle ( const ModelHighAPI_Double &  theAngle)
Set angle.
◆ setPoints()
void FeaturesAPI_Rotation::setPoints ( const ModelHighAPI_Selection &  theCenterPoint,
◆ dump()
void FeaturesAPI_Rotation::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
