FeaturesAPI_Rotation.h
20#ifndef FeaturesAPI_Rotation_H_
21#define FeaturesAPI_Rotation_H_
23#include "FeaturesAPI.h"
24
25#include <FeaturesPlugin_Rotation.h>
26
27#include <ModelHighAPI_Double.h>
28#include <ModelHighAPI_Interface.h>
29#include <ModelHighAPI_Macro.h>
30#include <ModelHighAPI_Selection.h>
31
33
38{
39public:
41 FEATURESAPI_EXPORT
42 explicit FeaturesAPI_Rotation(const std::shared_ptr<ModelAPI_Feature>& theFeature);
43
45 FEATURESAPI_EXPORT
46 FeaturesAPI_Rotation(const std::shared_ptr<ModelAPI_Feature>& theFeature,
47 const std::list<ModelHighAPI_Selection>& theMainObjects,
48 const ModelHighAPI_Selection& theAxisObject,
49 const ModelHighAPI_Double& theAngle);
50
52 FEATURESAPI_EXPORT
53 FeaturesAPI_Rotation(const std::shared_ptr<ModelAPI_Feature>& theFeature,
54 const std::list<ModelHighAPI_Selection>& theMainObjects,
55 const ModelHighAPI_Selection& theCenterPoint,
56 const ModelHighAPI_Selection& theStartPoint,
57 const ModelHighAPI_Selection& theEndPoint);
58
60 FEATURESAPI_EXPORT
61 virtual ~FeaturesAPI_Rotation();
62
63 INTERFACE_7(FeaturesPlugin_Rotation::ID(),
78 )
79
80
81 FEATURESAPI_EXPORT
82 void setMainObjects(const std::list<ModelHighAPI_Selection>& theMainObjects);
83
85 FEATURESAPI_EXPORT
86 void setAxisObject(const ModelHighAPI_Selection& theAxisObject);
87
89 FEATURESAPI_EXPORT
90 void setAngle(const ModelHighAPI_Double& theAngle);
91
93 FEATURESAPI_EXPORT
94 void setPoints(const ModelHighAPI_Selection& theCenterPoint,
95 const ModelHighAPI_Selection& theStartPoint,
96 const ModelHighAPI_Selection& theEndPoint);
97
99 FEATURESAPI_EXPORT
100 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
101};
102
104typedef std::shared_ptr<FeaturesAPI_Rotation> RotationPtr;
105
106
107#define DUMMY std::pair<ModelHighAPI_Selection, ModelHighAPI_Double>()
108
111FEATURESAPI_EXPORT RotationPtr addRotation(
112 const std::shared_ptr<ModelAPI_Document>& part,
113 const std::list<ModelHighAPI_Selection>& objects,
115 const std::pair<ModelHighAPI_Selection, ModelHighAPI_Double>& angle = DUMMY,
119 const bool keepSubResults = false);
120
121#endif // FeaturesAPI_Rotation_H_
Interface for Rotation feature.
Definition: FeaturesAPI_Rotation.h:38
virtual std::shared_ptr< ModelAPI_AttributeString > creationMethod() const
Creation method.
Definition: FeaturesAPI_Rotation.h:78
void setAxisObject(const ModelHighAPI_Selection &theAxisObject)
Set axis object.
Definition: FeaturesAPI_Rotation.cpp:75
virtual std::shared_ptr< ModelAPI_AttributeSelection > startPoint() const
Start point.
virtual std::shared_ptr< ModelAPI_AttributeSelection > endPoint() const
End point.
Definition: FeaturesAPI_Rotation.cpp:61
virtual std::shared_ptr< ModelAPI_AttributeSelection > axisObject() const
Axis object.
void setPoints(const ModelHighAPI_Selection &theCenterPoint, const ModelHighAPI_Selection &theStartPoint, const ModelHighAPI_Selection &theEndPoint)
Set center point, start point and end point.
Definition: FeaturesAPI_Rotation.cpp:93
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > mainObjects() const
Main objects.
FeaturesAPI_Rotation(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_Rotation.cpp:26
Dump wrapped feature.
Definition: FeaturesAPI_Rotation.cpp:106
void setAngle(const ModelHighAPI_Double &theAngle)
Set angle.
Definition: FeaturesAPI_Rotation.cpp:84
virtual std::shared_ptr< ModelAPI_AttributeDouble > angle() const
Angle.
virtual std::shared_ptr< ModelAPI_AttributeSelection > centerPoint() const
Center point.
void setMainObjects(const std::list< ModelHighAPI_Selection > &theMainObjects)
Set main objects.
Definition: FeaturesAPI_Rotation.cpp:67
static const std::string & START_POINT_ID()
Attribute name of a center point.
Definition: FeaturesPlugin_Rotation.h:92
Attribute name of referenced objects.
Definition: FeaturesPlugin_Rotation.h:64
static const std::string & END_POINT_ID()
Definition: FeaturesPlugin_Rotation.h:99
static const std::string & AXIS_OBJECT_ID()
Attribute name of an axis.
Definition: FeaturesPlugin_Rotation.h:71
static const std::string & ANGLE_ID()
Attribute name of angle.
Definition: FeaturesPlugin_Rotation.h:78
Definition: FeaturesPlugin_Rotation.h:43
static const std::string & CENTER_POINT_ID()
Definition: FeaturesPlugin_Rotation.h:85
Rotation kind.
Definition: FeaturesPlugin_Rotation.h:36
Dump engine for the model.
RotationPtr addRotation(const std::shared_ptr< ModelAPI_Document > &part, const std::list< ModelHighAPI_Selection > &objects, const ModelHighAPI_Selection &axis=ModelHighAPI_Selection(), const std::pair< ModelHighAPI_Selection, ModelHighAPI_Double > &angle=std::pair< ModelHighAPI_Selection, ModelHighAPI_Double >(), const ModelHighAPI_Selection &center=ModelHighAPI_Selection(), const ModelHighAPI_Selection &start=ModelHighAPI_Selection(), const ModelHighAPI_Selection &end=ModelHighAPI_Selection(), const bool keepSubResults=false)
Create Rotation feature.
Definition: FeaturesAPI_Rotation.cpp:142
