FeaturesAPI_MultiTranslation Class Reference
Interface for Translation feature. More...
#include <FeaturesAPI_MultiTranslation.h>
Inheritance diagram for FeaturesAPI_MultiTranslation:
 FeaturesAPI_MultiTranslation (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 FeaturesAPI_MultiTranslation (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const ModelHighAPI_Selection &theAxisObject, const ModelHighAPI_Double &theStep, const ModelHighAPI_Integer &theNumber)
 FeaturesAPI_MultiTranslation (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const ModelHighAPI_Selection &theFirstAxisObject, const ModelHighAPI_Double &theFirstStep, const ModelHighAPI_Integer &theFirstNumber, const ModelHighAPI_Selection &theSecondAxisObject, const ModelHighAPI_Double &theSecondStep, const ModelHighAPI_Integer &theSecondNumber)
virtual ~FeaturesAPI_MultiTranslation ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > mainObjects () const
 Main objects. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > firstAxisObject () const
 First axis object. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > firstStep () const
 First step. More...
virtual std::shared_ptr< ModelAPI_AttributeInteger > firstNumber () const
 First number of copies. More...
virtual std::shared_ptr< ModelAPI_AttributeString > useSecondDir () const
 Use the second dir. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > secondAxisObject () const
 Second axis object. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > secondStep () const
 Second step. More...
virtual std::shared_ptr< ModelAPI_AttributeInteger > secondNumber () const
 Second number of copies. More...
void setMainObjects (const std::list< ModelHighAPI_Selection > &theMainObjects)
 Set main objects. More...
void setFirstAxisAndDistance (const ModelHighAPI_Selection &theAxisObject, const ModelHighAPI_Double &theDistance)
 Modify CreationMethod, axis_first_dir, step_first_dir attributes of the feature. More...
void setSecondAxisAndDistance (const ModelHighAPI_Selection &theAxisObject, const ModelHighAPI_Double &theDistance)
 Modify CreationMethod, axis_second_dir, step_second_dir attributes of the feature. More...
void setFirstNumber (const ModelHighAPI_Integer &theFirstNumber)
 Modify CreationMethod, nb_first_dir attribute of the feature. More...
void setSecondNumber (const ModelHighAPI_Integer &theSecondNumber)
 Modify CreationMethod, nb_second_dir attribute of the feature. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > mymainObjects
std::shared_ptr< ModelAPI_AttributeSelection > myfirstAxisObject
std::shared_ptr< ModelAPI_AttributeDouble > myfirstStep
std::shared_ptr< ModelAPI_AttributeInteger > myfirstNumber
std::shared_ptr< ModelAPI_AttributeString > myuseSecondDir
std::shared_ptr< ModelAPI_AttributeSelection > mysecondAxisObject
std::shared_ptr< ModelAPI_AttributeDouble > mysecondStep
std::shared_ptr< ModelAPI_AttributeInteger > mysecondNumber
◆ FeaturesAPI_MultiTranslation() [1/3]
FeaturesAPI_MultiTranslation::FeaturesAPI_MultiTranslation ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ FeaturesAPI_MultiTranslation() [2/3]
FeaturesAPI_MultiTranslation::FeaturesAPI_MultiTranslation ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< ModelHighAPI_Selection > &  theMainObjects,
const ModelHighAPI_Selection &  theAxisObject,
const ModelHighAPI_Double &  theStep,
const ModelHighAPI_Integer &  theNumber
explicit
◆ FeaturesAPI_MultiTranslation() [3/3]
const ModelHighAPI_Selection &  theFirstAxisObject,
const ModelHighAPI_Double &  theFirstStep,
const ModelHighAPI_Integer &  theFirstNumber,
const ModelHighAPI_Selection &  theSecondAxisObject,
const ModelHighAPI_Double &  theSecondStep,
const ModelHighAPI_Integer &  theSecondNumber
explicit
◆ ~FeaturesAPI_MultiTranslation()
FeaturesAPI_MultiTranslation::~FeaturesAPI_MultiTranslation ( )
◆ mainObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_MultiTranslation::mainObjects ( ) const
Main objects.
◆ firstAxisObject()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_MultiTranslation::firstAxisObject ( ) const
First axis object.
◆ firstStep()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_MultiTranslation::firstStep ( ) const
First step.
◆ firstNumber()
virtual std::shared_ptr< ModelAPI_AttributeInteger > FeaturesAPI_MultiTranslation::firstNumber ( ) const
◆ useSecondDir()
virtual std::shared_ptr< ModelAPI_AttributeString > FeaturesAPI_MultiTranslation::useSecondDir ( ) const
Use the second dir.
◆ secondAxisObject()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_MultiTranslation::secondAxisObject ( ) const
Second axis object.
◆ secondStep()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_MultiTranslation::secondStep ( ) const
Second step.
◆ secondNumber()
virtual std::shared_ptr< ModelAPI_AttributeInteger > FeaturesAPI_MultiTranslation::secondNumber ( ) const
◆ setMainObjects()
void FeaturesAPI_MultiTranslation::setMainObjects ( const std::list< ModelHighAPI_Selection > &  theMainObjects)
Set main objects.
◆ setFirstAxisAndDistance()
void FeaturesAPI_MultiTranslation::setFirstAxisAndDistance ( const ModelHighAPI_Selection &  theAxisObject,
const ModelHighAPI_Double &  theDistance
◆ setSecondAxisAndDistance()
void FeaturesAPI_MultiTranslation::setSecondAxisAndDistance ( const ModelHighAPI_Selection &  theAxisObject,
◆ setFirstNumber()
void FeaturesAPI_MultiTranslation::setFirstNumber ( const ModelHighAPI_Integer &  theFirstNumber)
◆ setSecondNumber()
void FeaturesAPI_MultiTranslation::setSecondNumber ( const ModelHighAPI_Integer &  theSecondNumber)
◆ dump()
void FeaturesAPI_MultiTranslation::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
