SketchAPI_Rotation Class Reference
Interface for Rotation feature. More...
#include <SketchAPI_Rotation.h>
Inheritance diagram for SketchAPI_Rotation:
 SketchAPI_Rotation (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 SketchAPI_Rotation (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< std::shared_ptr< ModelAPI_Object > > &theObjects, const ModelHighAPI_RefAttr &theCenter, const ModelHighAPI_Double &theAngle, const ModelHighAPI_Integer &theNumberOfObjects, bool theFullValue=false, bool theReversed=false)
virtual ~SketchAPI_Rotation ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeRefList > rotationList () const
 Rotation list. More...
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > center () const
 Center. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > angle () const
 Angle. More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > reversed () const
 Negative angle. More...
virtual std::shared_ptr< ModelAPI_AttributeInteger > numberOfObjects () const
 Number of objects. More...
virtual std::shared_ptr< ModelAPI_AttributeString > valueType () const
 Value type. More...
virtual std::shared_ptr< ModelAPI_AttributeRefList > referenceObjects () const
 Reference objects. More...
virtual std::shared_ptr< ModelAPI_AttributeRefList > rotatedObjects () const
 Rotated objects. More...
void setRotationList (const std::list< std::shared_ptr< ModelAPI_Object > > &theObjects)
 Set list of objects to be rotated. More...
std::list< std::shared_ptr< SketchAPI_SketchEntity > > rotated () const
 List of rotated objects. More...
std::list< std::shared_ptr< SketchAPI_SketchEntity > > rotatedList () const
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeRefList > myrotationList
std::shared_ptr< ModelAPI_AttributeRefAttr > mycenter
std::shared_ptr< ModelAPI_AttributeDouble > myangle
std::shared_ptr< ModelAPI_AttributeBoolean > myreversed
std::shared_ptr< ModelAPI_AttributeInteger > mynumberOfObjects
std::shared_ptr< ModelAPI_AttributeString > myvalueType
std::shared_ptr< ModelAPI_AttributeRefList > myreferenceObjects
std::shared_ptr< ModelAPI_AttributeRefList > myrotatedObjects
◆ SketchAPI_Rotation() [1/2]
SketchAPI_Rotation::SketchAPI_Rotation ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ SketchAPI_Rotation() [2/2]
SketchAPI_Rotation::SketchAPI_Rotation ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< std::shared_ptr< ModelAPI_Object > > &  theObjects,
const ModelHighAPI_RefAttr &  theCenter,
const ModelHighAPI_Double &  theAngle,
const ModelHighAPI_Integer &  theNumberOfObjects,
bool  theFullValue = false,
bool  theReversed = false
◆ ~SketchAPI_Rotation()
SketchAPI_Rotation::~SketchAPI_Rotation ( )
◆ rotationList()
virtual std::shared_ptr< ModelAPI_AttributeRefList > SketchAPI_Rotation::rotationList ( ) const
Rotation list.
◆ center()
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > SketchAPI_Rotation::center ( ) const
Center.
◆ angle()
virtual std::shared_ptr< ModelAPI_AttributeDouble > SketchAPI_Rotation::angle ( ) const
Angle.
◆ reversed()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > SketchAPI_Rotation::reversed ( ) const
Negative angle.
◆ numberOfObjects()
virtual std::shared_ptr< ModelAPI_AttributeInteger > SketchAPI_Rotation::numberOfObjects ( ) const
Number of objects.
◆ valueType()
virtual std::shared_ptr< ModelAPI_AttributeString > SketchAPI_Rotation::valueType ( ) const
Value type.
◆ referenceObjects()
virtual std::shared_ptr< ModelAPI_AttributeRefList > SketchAPI_Rotation::referenceObjects ( ) const
Reference objects.
◆ rotatedObjects()
virtual std::shared_ptr< ModelAPI_AttributeRefList > SketchAPI_Rotation::rotatedObjects ( ) const
Rotated objects.
◆ setRotationList()
void SketchAPI_Rotation::setRotationList ( const std::list< std::shared_ptr< ModelAPI_Object > > &  theObjects)
◆ rotated()
std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_Rotation::rotated ( ) const
[DEPRECATED]: use rotatedList() instead.
◆ rotatedList()
std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_Rotation::rotatedList ( ) const
◆ dump()
void SketchAPI_Rotation::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
