FeaturesAPI_ExtrusionBoolean Class Reference
Interface for ExtrusionBoolean feature. More...
#include <FeaturesAPI_ExtrusionBoolean.h>
Inheritance diagram for FeaturesAPI_ExtrusionBoolean:
virtual ~FeaturesAPI_ExtrusionBoolean ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeReference > sketch () const
 Sketch launcher. More...
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > baseObjects () const
 Base objects. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > direction () const
 Direction. More...
 Creation method. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > toSize () const
 To size. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > fromSize () const
 From size. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > toObject () const
 To object. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > toOffset () const
 To offset. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > fromObject () const
 From object. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > fromOffset () const
 From offset. More...
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > booleanObjects () const
 Boolean objects. More...
void setNestedSketch (const ModelHighAPI_Reference &theSketch)
 Modify base attribute of the feature. More...
void setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects)
void setDirection (const ModelHighAPI_Selection &theDirection)
 Modify direction_object attribute of the feature. More...
void setSizes (const ModelHighAPI_Double &theToSize, const ModelHighAPI_Double &theFromSize)
 Modify CreationMethod, to_size, from_size attributes of the feature. More...
void setSize (const ModelHighAPI_Double &theSize)
 Modify creation_method, to_size, from_size attributes of the feature. More...
void setPlanesAndOffsets (const ModelHighAPI_Selection &theToObject, const ModelHighAPI_Double &theToOffset, const ModelHighAPI_Selection &theFromObject, const ModelHighAPI_Double &theFromOffset)
 Modify creation_method, to_object, to_offset, from_object, from_offset attributes of the feature. More...
void setBooleanObjects (const std::list< ModelHighAPI_Selection > &theBooleanObjects)
 Modiyfy main_objects attribute of the feature. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
 FeaturesAPI_ExtrusionBoolean (const std::shared_ptr< ModelAPI_Feature > &theFeature)
std::shared_ptr< ModelAPI_AttributeReference > mysketch
std::shared_ptr< ModelAPI_AttributeSelectionList > mybaseObjects
std::shared_ptr< ModelAPI_AttributeSelection > mydirection
std::shared_ptr< ModelAPI_AttributeDouble > mytoSize
std::shared_ptr< ModelAPI_AttributeDouble > myfromSize
std::shared_ptr< ModelAPI_AttributeSelection > mytoObject
std::shared_ptr< ModelAPI_AttributeDouble > mytoOffset
std::shared_ptr< ModelAPI_AttributeSelection > myfromObject
std::shared_ptr< ModelAPI_AttributeDouble > myfromOffset
std::shared_ptr< ModelAPI_AttributeSelectionList > mybooleanObjects
◆ ~FeaturesAPI_ExtrusionBoolean()
FeaturesAPI_ExtrusionBoolean::~FeaturesAPI_ExtrusionBoolean ( )
◆ FeaturesAPI_ExtrusionBoolean()
FeaturesAPI_ExtrusionBoolean::FeaturesAPI_ExtrusionBoolean ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicitprotected
◆ sketch()
virtual std::shared_ptr< ModelAPI_AttributeReference > FeaturesAPI_ExtrusionBoolean::sketch ( ) const
Sketch launcher.
◆ baseObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_ExtrusionBoolean::baseObjects ( ) const
Base objects.
◆ direction()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_ExtrusionBoolean::direction ( ) const
Direction.
◆ creationMethod()
virtual std::shared_ptr< ModelAPI_AttributeString > FeaturesAPI_ExtrusionBoolean::creationMethod ( ) const
Creation method.
◆ toSize()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_ExtrusionBoolean::toSize ( ) const
To size.
◆ fromSize()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_ExtrusionBoolean::fromSize ( ) const
From size.
◆ toObject()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_ExtrusionBoolean::toObject ( ) const
To object.
◆ toOffset()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_ExtrusionBoolean::toOffset ( ) const
To offset.
◆ fromObject()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_ExtrusionBoolean::fromObject ( ) const
From object.
◆ fromOffset()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_ExtrusionBoolean::fromOffset ( ) const
From offset.
◆ booleanObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_ExtrusionBoolean::booleanObjects ( ) const
Boolean objects.
◆ setNestedSketch()
void FeaturesAPI_ExtrusionBoolean::setNestedSketch ( const ModelHighAPI_Reference &  theSketch)
◆ setBase()
void FeaturesAPI_ExtrusionBoolean::setBase ( const std::list< ModelHighAPI_Selection > &  theBaseObjects)
◆ setDirection()
void FeaturesAPI_ExtrusionBoolean::setDirection ( const ModelHighAPI_Selection &  theDirection)
◆ setSizes()
void FeaturesAPI_ExtrusionBoolean::setSizes ( const ModelHighAPI_Double &  theToSize,
const ModelHighAPI_Double &  theFromSize
◆ setSize()
void FeaturesAPI_ExtrusionBoolean::setSize ( const ModelHighAPI_Double &  theSize)
◆ setPlanesAndOffsets()
void FeaturesAPI_ExtrusionBoolean::setPlanesAndOffsets ( const ModelHighAPI_Selection &  theToObject,
const ModelHighAPI_Double &  theToOffset,
const ModelHighAPI_Selection &  theFromObject,
const ModelHighAPI_Double &  theFromOffset
◆ setBooleanObjects()
void FeaturesAPI_ExtrusionBoolean::setBooleanObjects ( const std::list< ModelHighAPI_Selection > &  theBooleanObjects)
◆ dump()
void FeaturesAPI_ExtrusionBoolean::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
