FeaturesAPI_RevolutionBoolean Class Reference
Interface for RevolutionBoolean feature. More...
#include <FeaturesAPI_RevolutionBoolean.h>
Inheritance diagram for FeaturesAPI_RevolutionBoolean:
virtual ~FeaturesAPI_RevolutionBoolean ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeReference > sketch () const
 Sketch launcher. More...
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > baseObjects () const
 Base objects. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > axis () const
 Axis. More...
 Creation method. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > toAngle () const
 To angle. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > fromAngle () const
 From angle. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > toObject () const
 To object. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > toOffset () const
 To offset. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > fromObject () const
 From object. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > fromOffset () const
 From offset. More...
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > booleanObjects () const
 Boolean objects. More...
void setNestedSketch (const ModelHighAPI_Reference &theSketch)
 Modify base attribute of the feature. More...
void setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects)
void setAxis (const ModelHighAPI_Selection &theAxis)
 Modify axis_object attribute of the feature. More...
void setAngles (const ModelHighAPI_Double &theToAngle, const ModelHighAPI_Double &theFromAngle)
 Modify CreationMethod, to_angle, from_angle attributes of the feature. More...
void setAngle (const ModelHighAPI_Double &theAngle)
 Modify creation_method, to_angle, from_angle attributes of the feature. More...
void setPlanesAndOffsets (const ModelHighAPI_Selection &theToObject, const ModelHighAPI_Double &theToOffset, const ModelHighAPI_Selection &theFromObject, const ModelHighAPI_Double &theFromOffset)
 Modify creation_method, to_object, to_offset, from_object, from_offset attributes of the feature. More...
void setBooleanObjects (const std::list< ModelHighAPI_Selection > &theBooleanObjects)
 Modiyfy main_objects attribute of the feature. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
 FeaturesAPI_RevolutionBoolean (const std::shared_ptr< ModelAPI_Feature > &theFeature)
std::shared_ptr< ModelAPI_AttributeReference > mysketch
std::shared_ptr< ModelAPI_AttributeSelectionList > mybaseObjects
std::shared_ptr< ModelAPI_AttributeSelection > myaxis
std::shared_ptr< ModelAPI_AttributeDouble > mytoAngle
std::shared_ptr< ModelAPI_AttributeDouble > myfromAngle
std::shared_ptr< ModelAPI_AttributeSelection > mytoObject
std::shared_ptr< ModelAPI_AttributeDouble > mytoOffset
std::shared_ptr< ModelAPI_AttributeSelection > myfromObject
std::shared_ptr< ModelAPI_AttributeDouble > myfromOffset
std::shared_ptr< ModelAPI_AttributeSelectionList > mybooleanObjects
◆ ~FeaturesAPI_RevolutionBoolean()
FeaturesAPI_RevolutionBoolean::~FeaturesAPI_RevolutionBoolean ( )
◆ FeaturesAPI_RevolutionBoolean()
FeaturesAPI_RevolutionBoolean::FeaturesAPI_RevolutionBoolean ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicitprotected
◆ sketch()
virtual std::shared_ptr< ModelAPI_AttributeReference > FeaturesAPI_RevolutionBoolean::sketch ( ) const
Sketch launcher.
◆ baseObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_RevolutionBoolean::baseObjects ( ) const
Base objects.
◆ axis()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_RevolutionBoolean::axis ( ) const
Axis.
◆ creationMethod()
virtual std::shared_ptr< ModelAPI_AttributeString > FeaturesAPI_RevolutionBoolean::creationMethod ( ) const
Creation method.
◆ toAngle()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_RevolutionBoolean::toAngle ( ) const
To angle.
◆ fromAngle()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_RevolutionBoolean::fromAngle ( ) const
From angle.
◆ toObject()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_RevolutionBoolean::toObject ( ) const
To object.
◆ toOffset()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_RevolutionBoolean::toOffset ( ) const
To offset.
◆ fromObject()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_RevolutionBoolean::fromObject ( ) const
From object.
◆ fromOffset()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_RevolutionBoolean::fromOffset ( ) const
From offset.
◆ booleanObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_RevolutionBoolean::booleanObjects ( ) const
Boolean objects.
◆ setNestedSketch()
void FeaturesAPI_RevolutionBoolean::setNestedSketch ( const ModelHighAPI_Reference &  theSketch)
◆ setBase()
void FeaturesAPI_RevolutionBoolean::setBase ( const std::list< ModelHighAPI_Selection > &  theBaseObjects)
◆ setAxis()
void FeaturesAPI_RevolutionBoolean::setAxis ( const ModelHighAPI_Selection &  theAxis)
◆ setAngles()
void FeaturesAPI_RevolutionBoolean::setAngles ( const ModelHighAPI_Double &  theToAngle,
const ModelHighAPI_Double &  theFromAngle
◆ setAngle()
void FeaturesAPI_RevolutionBoolean::setAngle ( const ModelHighAPI_Double &  theAngle)
◆ setPlanesAndOffsets()
void FeaturesAPI_RevolutionBoolean::setPlanesAndOffsets ( const ModelHighAPI_Selection &  theToObject,
const ModelHighAPI_Double &  theToOffset,
const ModelHighAPI_Selection &  theFromObject,
const ModelHighAPI_Double &  theFromOffset
◆ setBooleanObjects()
void FeaturesAPI_RevolutionBoolean::setBooleanObjects ( const std::list< ModelHighAPI_Selection > &  theBooleanObjects)
◆ dump()
void FeaturesAPI_RevolutionBoolean::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
