SketchAPI_Mirror Class Reference
Interface for Mirror feature. More...
#include <SketchAPI_Mirror.h>
Inheritance diagram for SketchAPI_Mirror:
 SketchAPI_Mirror (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 SketchAPI_Mirror (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_RefAttr &theMirrorLine, const std::list< std::shared_ptr< ModelAPI_Object > > &theObjects)
virtual ~SketchAPI_Mirror ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > mirrorLine () const
 Mirror line. More...
virtual std::shared_ptr< ModelAPI_AttributeRefList > mirrorList () const
 Mirror list. More...
virtual std::shared_ptr< ModelAPI_AttributeRefList > referenceObjects () const
 Reference objects. More...
virtual std::shared_ptr< ModelAPI_AttributeRefList > mirroredObjects () const
 Mirrored objects. More...
void setMirrorList (const std::list< std::shared_ptr< ModelAPI_Object > > &theObjects)
 Set list of original objects. More...
std::list< std::shared_ptr< SketchAPI_SketchEntity > > mirrored () const
 List of mirrored objects. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeRefAttr > mymirrorLine
std::shared_ptr< ModelAPI_AttributeRefList > mymirrorList
std::shared_ptr< ModelAPI_AttributeRefList > myreferenceObjects
std::shared_ptr< ModelAPI_AttributeRefList > mymirroredObjects
◆ SketchAPI_Mirror() [1/2]
SketchAPI_Mirror::SketchAPI_Mirror ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ SketchAPI_Mirror() [2/2]
SketchAPI_Mirror::SketchAPI_Mirror ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const ModelHighAPI_RefAttr &  theMirrorLine,
const std::list< std::shared_ptr< ModelAPI_Object > > &  theObjects
◆ ~SketchAPI_Mirror()
SketchAPI_Mirror::~SketchAPI_Mirror ( )
◆ mirrorLine()
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > SketchAPI_Mirror::mirrorLine ( ) const
Mirror line.
◆ mirrorList()
virtual std::shared_ptr< ModelAPI_AttributeRefList > SketchAPI_Mirror::mirrorList ( ) const
Mirror list.
◆ referenceObjects()
virtual std::shared_ptr< ModelAPI_AttributeRefList > SketchAPI_Mirror::referenceObjects ( ) const
Reference objects.
◆ mirroredObjects()
virtual std::shared_ptr< ModelAPI_AttributeRefList > SketchAPI_Mirror::mirroredObjects ( ) const
Mirrored objects.
◆ setMirrorList()
void SketchAPI_Mirror::setMirrorList ( const std::list< std::shared_ptr< ModelAPI_Object > > &  theObjects)
◆ mirrored()
std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_Mirror::mirrored ( ) const
◆ dump()
void SketchAPI_Mirror::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
