FeaturesAPI_Scale Class Reference
Interface for Scale feature. More...
#include <FeaturesAPI_Scale.h>
Inheritance diagram for FeaturesAPI_Scale:
 FeaturesAPI_Scale (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 FeaturesAPI_Scale (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const ModelHighAPI_Selection &theCenterPoint, const ModelHighAPI_Double &theScaleFactor)
 FeaturesAPI_Scale (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const ModelHighAPI_Selection &theCenterPoint, const ModelHighAPI_Double &theScaleFactorX, const ModelHighAPI_Double &theScaleFactorY, const ModelHighAPI_Double &theScaleFactorZ)
virtual ~FeaturesAPI_Scale ()
virtual std::string getID ()
 Creation method. More...
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > mainObjects () const
 Main objects. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > centerPoint () const
 Center point. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > scaleFactor () const
 Scale factor. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > scaleFactorX () const
 Scale factor in X. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > scaleFactorY () const
 Scale factor in Y. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > scaleFactorZ () const
 Scale factor in Z. More...
void setMainObjects (const std::list< ModelHighAPI_Selection > &theMainObjects)
 Set main objects. More...
void setCenterPoint (const ModelHighAPI_Selection &theCenterPoint)
 Modify center_point attribute of the feature. More...
void setScaleFactor (const ModelHighAPI_Double &theScaleFactor)
 Modify Creation Method and scale_factor attribute of the feature. More...
void setDimensions (const ModelHighAPI_Double &theScaleFactorX, const ModelHighAPI_Double &theScaleFactorY, const ModelHighAPI_Double &theScaleFactorZ)
 Modify Creation Method and scale_factor_x, scale_factor_y and scale_factor_z attributes of the feature. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelectionList > mymainObjects
std::shared_ptr< ModelAPI_AttributeSelection > mycenterPoint
std::shared_ptr< ModelAPI_AttributeDouble > myscaleFactor
std::shared_ptr< ModelAPI_AttributeDouble > myscaleFactorX
std::shared_ptr< ModelAPI_AttributeDouble > myscaleFactorY
std::shared_ptr< ModelAPI_AttributeDouble > myscaleFactorZ
◆ FeaturesAPI_Scale() [1/3]
FeaturesAPI_Scale::FeaturesAPI_Scale ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ FeaturesAPI_Scale() [2/3]
FeaturesAPI_Scale::FeaturesAPI_Scale ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< ModelHighAPI_Selection > &  theMainObjects,
const ModelHighAPI_Selection &  theCenterPoint,
const ModelHighAPI_Double &  theScaleFactor
explicit
◆ FeaturesAPI_Scale() [3/3]
const ModelHighAPI_Double &  theScaleFactorX,
const ModelHighAPI_Double &  theScaleFactorY,
const ModelHighAPI_Double &  theScaleFactorZ
explicit
◆ ~FeaturesAPI_Scale()
FeaturesAPI_Scale::~FeaturesAPI_Scale ( )
◆ creationMethod()
virtual std::shared_ptr< ModelAPI_AttributeString > FeaturesAPI_Scale::creationMethod ( ) const
Creation method.
◆ mainObjects()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > FeaturesAPI_Scale::mainObjects ( ) const
Main objects.
◆ centerPoint()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_Scale::centerPoint ( ) const
Center point.
◆ scaleFactor()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Scale::scaleFactor ( ) const
Scale factor.
◆ scaleFactorX()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Scale::scaleFactorX ( ) const
Scale factor in X.
◆ scaleFactorY()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Scale::scaleFactorY ( ) const
Scale factor in Y.
◆ scaleFactorZ()
virtual std::shared_ptr< ModelAPI_AttributeDouble > FeaturesAPI_Scale::scaleFactorZ ( ) const
Scale factor in Z.
◆ setMainObjects()
void FeaturesAPI_Scale::setMainObjects ( const std::list< ModelHighAPI_Selection > &  theMainObjects)
Set main objects.
◆ setCenterPoint()
void FeaturesAPI_Scale::setCenterPoint ( const ModelHighAPI_Selection &  theCenterPoint)
◆ setScaleFactor()
void FeaturesAPI_Scale::setScaleFactor ( const ModelHighAPI_Double &  theScaleFactor)
◆ setDimensions()
void FeaturesAPI_Scale::setDimensions ( const ModelHighAPI_Double &  theScaleFactorX,
◆ dump()
void FeaturesAPI_Scale::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
