GeomAlgoAPI_EdgeBuilder Class Reference
Allows to create face-shapes by different parameters. More...
#include <GeomAlgoAPI_EdgeBuilder.h>
static std::shared_ptr< GeomAPI_Edge > line (std::shared_ptr< GeomAPI_Pnt > theStart, std::shared_ptr< GeomAPI_Pnt > theEnd)
 Creates linear edge by two points. More...
static std::shared_ptr< GeomAPI_Edge > line (double theDX, double theDY, double theDZ)
 Creates linear edge by three dimensions. More...
static std::shared_ptr< GeomAPI_Edge > line (const std::shared_ptr< GeomAPI_Lin > theLin)
 Creates linear edge by GeomAPI_Lin. More...
static std::shared_ptr< GeomAPI_Edge > cylinderAxis (std::shared_ptr< GeomAPI_Shape > theCylindricalFace)
 Creates edge - axis of the given cylindrical face. The result axis edge is infinite. More...
static std::shared_ptr< GeomAPI_Edge > lineCircle (std::shared_ptr< GeomAPI_Pnt > theCenter, std::shared_ptr< GeomAPI_Dir > theNormal, double theRadius, double theRotationAngle=0.)
 Creates linear edge in a form of a circle by a point and a circle radius. More...
static std::shared_ptr< GeomAPI_Edge > lineCircle (std::shared_ptr< GeomAPI_Circ > theCircle)
 Creates linear edge in a form of a circle by GeomAPI_Circle. More...
static std::shared_ptr< GeomAPI_Edge > lineCircleArc (std::shared_ptr< GeomAPI_Pnt > theCenter, std::shared_ptr< GeomAPI_Pnt > theStartPoint, std::shared_ptr< GeomAPI_Pnt > theEndPoint, std::shared_ptr< GeomAPI_Dir > theNormal)
 Creates linear edge in a form of a circle arc by a three points. More...
static std::shared_ptr< GeomAPI_Edge > ellipse (const std::shared_ptr< GeomAPI_Pnt > &theCenter, const std::shared_ptr< GeomAPI_Dir > &theNormal, const std::shared_ptr< GeomAPI_Dir > &theMajorAxis, const double theMajorRadius, const double theMinorRadius)
 Creates elliptic edge. More...
static std::shared_ptr< GeomAPI_Edge > ellipticArc (const std::shared_ptr< GeomAPI_Pnt > &theCenter, const std::shared_ptr< GeomAPI_Dir > &theNormal, const std::shared_ptr< GeomAPI_Dir > &theMajorAxis, const double theMajorRadius, const double theMinorRadius, const std::shared_ptr< GeomAPI_Pnt > &theStart, const std::shared_ptr< GeomAPI_Pnt > &theEnd)
static GeomEdgePtr bsplineOnPlane (const std::shared_ptr< GeomAPI_Ax3 > &thePlane, const std::list< std::shared_ptr< GeomAPI_Pnt2d > > &thePoles, const std::list< double > &theWeights, const std::list< double > &theKnots, const std::list< int > &theMults, const int theDegree, const bool thePeriodic)
 Creates planar B-spline edge. More...
static GeomEdgePtr bsplineOnPlane (const std::shared_ptr< GeomAPI_Ax3 > &thePlane, const std::shared_ptr< GeomAPI_BSpline2d > &theCurve)
◆ line() [1/3]
std::shared_ptr< GeomAPI_Edge > GeomAlgoAPI_EdgeBuilder::line ( std::shared_ptr< GeomAPI_Pnt >  theStart,
theStarta first point of an edge
theEndan end point of an edge
◆ line() [2/3]
std::shared_ptr< GeomAPI_Edge > GeomAlgoAPI_EdgeBuilder::line ( double  theDX,
double  theDY,
double  theDZ
theXthe X dimension
theYthe Y dimension
theZthe Z dimension
◆ line() [3/3]
std::shared_ptr< GeomAPI_Edge > GeomAlgoAPI_EdgeBuilder::line ( const std::shared_ptr< GeomAPI_Lin >  theLin)
theLinline.
◆ cylinderAxis()
std::shared_ptr< GeomAPI_Edge > GeomAlgoAPI_EdgeBuilder::cylinderAxis ( std::shared_ptr< GeomAPI_Shape >  theCylindricalFace)
◆ lineCircle() [1/2]
std::shared_ptr< GeomAPI_Edge > GeomAlgoAPI_EdgeBuilder::lineCircle ( std::shared_ptr< GeomAPI_Pnt >  theCenter,
double  theRadius,
double  theRotationAngle = 0.
◆ lineCircle() [2/2]
std::shared_ptr< GeomAPI_Edge > GeomAlgoAPI_EdgeBuilder::lineCircle ( std::shared_ptr< GeomAPI_Circ >  theCircle)
◆ lineCircleArc()
std::shared_ptr< GeomAPI_Edge > GeomAlgoAPI_EdgeBuilder::lineCircleArc ( std::shared_ptr< GeomAPI_Pnt >  theCenter,
OCCT creates an edge on a circle with empty radius, but visualization is not able to process it
◆ ellipse()
std::shared_ptr< GeomAPI_Edge > GeomAlgoAPI_EdgeBuilder::ellipse ( const std::shared_ptr< GeomAPI_Pnt > &  theCenter,
const std::shared_ptr< GeomAPI_Dir > &  theNormal,
const std::shared_ptr< GeomAPI_Dir > &  theMajorAxis,
◆ ellipticArc()
std::shared_ptr< GeomAPI_Edge > GeomAlgoAPI_EdgeBuilder::ellipticArc ( const std::shared_ptr< GeomAPI_Pnt > &  theCenter,
const std::shared_ptr< GeomAPI_Pnt > &  theStart,
const std::shared_ptr< GeomAPI_Pnt > &  theEnd
◆ bsplineOnPlane() [1/2]
GeomEdgePtr GeomAlgoAPI_EdgeBuilder::bsplineOnPlane ( const std::shared_ptr< GeomAPI_Ax3 > &  thePlane,
const std::list< std::shared_ptr< GeomAPI_Pnt2d > > &  thePoles,
const std::list< double > &  theWeights,
const std::list< double > &  theKnots,
const std::list< int > &  theMults,
◆ bsplineOnPlane() [2/2]
const std::shared_ptr< GeomAPI_BSpline2d > &  theCurve
