GeomAlgoAPI_ShapeTools Class Reference
Useful tools for working with shapes. More...
#include <GeomAlgoAPI_ShapeTools.h>
typedef std::map< std::shared_ptr< GeomAPI_Pnt >, std::pair< std::list< std::shared_ptr< GeomDataAPI_Point2D > >, std::list< std::shared_ptr< ModelAPI_Object > > > > PointToRefsMap
static double length (const std::shared_ptr< GeomAPI_Shape > theShape)
static double volume (const std::shared_ptr< GeomAPI_Shape > theShape)
static double area (const std::shared_ptr< GeomAPI_Shape > theShape)
static bool isContinuousFaces (const GeomShapePtr &theFace1, const GeomShapePtr &theFace2, const GeomPointPtr &thePoint, const double &theAngle, std::string &theError)
 indicate if two faces are continuous with an angular tolerance used for G1 continuity to compare the angle between the normals More...
static std::shared_ptr< GeomAPI_Pnt > centreOfMass (const std::shared_ptr< GeomAPI_Shape > theShape)
static double radius (const std::shared_ptr< GeomAPI_Face > &theCylinder)
 Obtain radius of cylindrical face. More...
static double minimalDistance (const GeomShapePtr &theShape1, const GeomShapePtr &theShape2)
 Calculate minimal distance between shapes. More...
static double minimalDistance (const GeomShapePtr &theShape1, const GeomShapePtr &theShape2, std::array< double, 3 > &fromShape1To2)
static double shapeProximity (const GeomShapePtr &theShape1, const GeomShapePtr &theShape2)
 Calculate maximal value of all possible distances between shapes. More...
static std::shared_ptr< GeomAPI_Shape > combineShapes (const std::shared_ptr< GeomAPI_Shape > theCompound, const GeomAPI_Shape::ShapeType theType, ListOfShape &theResults)
 Combines faces with common edges to shells, or solids to compsolids. More...
static std::shared_ptr< GeomAPI_Shape > groupSharedTopology (const std::shared_ptr< GeomAPI_Shape > theCompound)
 Groups shapes with shared topology to compounds. More...
static bool hasSharedTopology (const ListOfShape &theShapes, const GeomAPI_Shape::ShapeType theShapeType)
 Check group of shapes has shared sub-shapes of the given type. More...
static std::list< std::shared_ptr< GeomAPI_Pnt > > getBoundingBox (const ListOfShape &theShapes, const double theEnlarge=0.0)
 Calculates bounding box for theShapes. More...
static std::shared_ptr< GeomAPI_Face > fitPlaneToBox (const std::shared_ptr< GeomAPI_Shape > thePlane, const std::list< std::shared_ptr< GeomAPI_Pnt > > &thePoints)
 Enlarges or reduces plane to fit bounding box. More...
static void findBounds (const std::shared_ptr< GeomAPI_Shape > theShape, std::shared_ptr< GeomAPI_Vertex > &theV1, std::shared_ptr< GeomAPI_Vertex > &theV2)
 Finds the start and end vertices of theShape. More...
static void makeFacesWithHoles (const std::shared_ptr< GeomAPI_Pnt > theOrigin, const std::shared_ptr< GeomAPI_Dir > theDirection, const ListOfShape &theWires, ListOfShape &theFaces)
 Creates faces with holes from wires. More...
static std::shared_ptr< GeomAPI_Pln > findPlane (const ListOfShape &theShapes)
 Return a plane for list of shapes if they are all planar. More...
static bool isSubShapeInsideShape (const std::shared_ptr< GeomAPI_Shape > theSubShape, const std::shared_ptr< GeomAPI_Shape > theBaseShape)
 Checks that vertex/edge is inside face or vertex inside wire. More...
static bool isShapeValid (const std::shared_ptr< GeomAPI_Shape > theShape)
static std::shared_ptr< GeomAPI_Shape > getFaceOuterWire (const std::shared_ptr< GeomAPI_Shape > theFace)
static bool isTangent (const std::shared_ptr< GeomAPI_Edge > theEdge1, const std::shared_ptr< GeomAPI_Edge > theEdge2, const std::shared_ptr< GeomAPI_Vertex > theTgPoint)
static bool isParallel (const std::shared_ptr< GeomAPI_Edge > theEdge, const std::shared_ptr< GeomAPI_Face > theFace)
static std::list< std::shared_ptr< GeomAPI_Vertex > > intersect (const std::shared_ptr< GeomAPI_Edge > theEdge, const std::shared_ptr< GeomAPI_Face > theFace)
 Computes intersection point between the edge curve and a face surface (only one point, with preferences to point that belongs to edge and face boundaries. More...
static void splitShape (const std::shared_ptr< GeomAPI_Shape > &theBaseShape, const PointToRefsMap &thePointsInfo, std::set< std::shared_ptr< GeomAPI_Shape > > &theShapes)
 Performs the split of the shape by points. More...
static void splitShape_p (const std::shared_ptr< GeomAPI_Shape > &theBaseShape, const std::list< std::shared_ptr< GeomAPI_Pnt > > &thePoints, std::set< std::shared_ptr< GeomAPI_Shape > > &theShapes)
static std::shared_ptr< GeomAPI_Shape > findShape (const std::list< std::shared_ptr< GeomAPI_Pnt > > &thePoints, const std::set< std::shared_ptr< GeomAPI_Shape > > &theShapes)
static std::shared_ptr< GeomAPI_Edge > wireToEdge (const std::shared_ptr< GeomAPI_Wire > &theWire)
 Re-approximate a wire to build a single edge. More...
static ListOfShape getLowLevelSubShapes (const GeomShapePtr &theShape)
 Get non-composite sub-shapes of the given shape. More...
static void computeThroughAll (const ListOfShape &theObjects, const ListOfShape &theBaseShapes, const std::shared_ptr< GeomAPI_Dir > theDir, double &theToSize, double &theFromSize)
 Calculate prism sizes to ensure that it passes through all objects. More...
static ListOfShape getSharedFaces (const GeomShapePtr &theShape)
 Get shared faces of a shape. More...
◆ length()
double GeomAlgoAPI_ShapeTools::length ( const std::shared_ptr< GeomAPI_Shape >  theShape)
the length of the edges of the current shape or 0.0 if it cannot be computed.
◆ volume()
double GeomAlgoAPI_ShapeTools::volume ( const std::shared_ptr< GeomAPI_Shape >  theShape)
the total volume of the solids of the current shape or 0.0 if it cannot be computed.
◆ area()
double GeomAlgoAPI_ShapeTools::area ( const std::shared_ptr< GeomAPI_Shape >  theShape)
the total area of the faces of the current shape or 0.0 if it cannot be computed.
◆ isContinuousFaces()
bool GeomAlgoAPI_ShapeTools::isContinuousFaces ( const GeomShapePtr &  theFace1,
const GeomShapePtr &  theFace2,
const GeomPointPtr &  thePoint,
const double &  theAngle,
std::string &  theError
theFace1the first face
theFace2the second face
thePointthe point for the normal
theAnglethe angular tolerance
theErrorerror
◆ centreOfMass()
std::shared_ptr< GeomAPI_Pnt > GeomAlgoAPI_ShapeTools::centreOfMass ( const std::shared_ptr< GeomAPI_Shape >  theShape)
the center of mass of the current face. The coordinates returned for the center of mass are expressed in the absolute Cartesian coordinate system. (This function works only for surfaces).
◆ radius()
double GeomAlgoAPI_ShapeTools::radius ( const std::shared_ptr< GeomAPI_Face > &  theCylinder)
Return negative value if the face is not a cylinder
◆ minimalDistance()
double GeomAlgoAPI_ShapeTools::minimalDistance ( const GeomShapePtr &  theShape1,
const GeomShapePtr &  theShape2
◆ shapeProximity()
double GeomAlgoAPI_ShapeTools::shapeProximity ( const GeomShapePtr &  theShape1,
The shapes can be two edges or two faces only.
◆ combineShapes()
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeTools::combineShapes ( const std::shared_ptr< GeomAPI_Shape >  theCompound,
ListOfShape &  theResults
[in]theCompoundcompound of shapes.
[in]theTypetype of combine.
[out]theResultsresulting shapes.
◆ groupSharedTopology()
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeTools::groupSharedTopology ( const std::shared_ptr< GeomAPI_Shape >  theCompound)
compound of compounds with shared topology.
◆ hasSharedTopology()
bool GeomAlgoAPI_ShapeTools::hasSharedTopology ( const ListOfShape &  theShapes,
[in]theShapeslist of shapes
[in]theShapeTypetype of sub-shapes to check
true if shared topology exists
◆ getBoundingBox()
std::list< std::shared_ptr< GeomAPI_Pnt > > GeomAlgoAPI_ShapeTools::getBoundingBox ( const ListOfShape &  theShapes,
const double  theEnlarge = 0.0
list of eight points.
[in]theShapeslist of shapes.
[in]theEnlargeenlarges bounding box size.
◆ fitPlaneToBox()
std::shared_ptr< GeomAPI_Face > GeomAlgoAPI_ShapeTools::fitPlaneToBox ( const std::shared_ptr< GeomAPI_Shape >  thePlane,
const std::list< std::shared_ptr< GeomAPI_Pnt > > &  thePoints
plane that fits to bounding box.
[in]thePlanebase plane.
[in]thePointsbounding box points (should be eight).
◆ findBounds()
void GeomAlgoAPI_ShapeTools::findBounds ( const std::shared_ptr< GeomAPI_Shape >  theShape,
std::shared_ptr< GeomAPI_Vertex > &  theV1,
std::shared_ptr< GeomAPI_Vertex > &  theV2
theShape can be of the following type:
Vertex: theV1 and theV2 are the same and equal to theShape;
Edge : theV1 is start and theV2 is end vertex;
Wire : theV1 is start vertex of the first edge, theV2 is end vertex of the last edge. If wire contains no edges theV1 and theV2 are nullified.
If none of the above theV1 and theV2 are nullified.
◆ makeFacesWithHoles()
void GeomAlgoAPI_ShapeTools::makeFacesWithHoles ( const std::shared_ptr< GeomAPI_Pnt >  theOrigin,
const ListOfShape &  theWires,
ListOfShape &  theFaces
[in]theWiresbase wires.
[out]theFacesresulting faces.
◆ findPlane()
std::shared_ptr< GeomAPI_Pln > GeomAlgoAPI_ShapeTools::findPlane ( const ListOfShape &  theShapes)
[in]theShapesshapes to find plane.
plane where all shapes lie or empty pointer if they not planar.
◆ isSubShapeInsideShape()
bool GeomAlgoAPI_ShapeTools::isSubShapeInsideShape ( const std::shared_ptr< GeomAPI_Shape >  theSubShape,
[in]theSubShapeshape that should be inside.
[in]theBaseShapebase shape.
true if edge inside the face.
◆ isShapeValid()
bool GeomAlgoAPI_ShapeTools::isShapeValid ( const std::shared_ptr< GeomAPI_Shape >  theShape)
true if theShape is valid.
◆ getFaceOuterWire()
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeTools::getFaceOuterWire ( const std::shared_ptr< GeomAPI_Shape >  theFace)
outer wire for face. If theShape has different type returns empty pointer.
◆ isTangent()
bool GeomAlgoAPI_ShapeTools::isTangent ( const std::shared_ptr< GeomAPI_Edge >  theEdge1,
true if edges are tangent in the specified point
◆ isParallel()
bool GeomAlgoAPI_ShapeTools::isParallel ( const std::shared_ptr< GeomAPI_Edge >  theEdge,
true if edge is parallel to face.
◆ intersect()
std::list< std::shared_ptr< GeomAPI_Vertex > > GeomAlgoAPI_ShapeTools::intersect ( const std::shared_ptr< GeomAPI_Edge >  theEdge,
null if there is no intersection
◆ splitShape()
void GeomAlgoAPI_ShapeTools::splitShape ( const std::shared_ptr< GeomAPI_Shape > &  theBaseShape,
const PointToRefsMap &  thePointsInfo,
std::set< std::shared_ptr< GeomAPI_Shape > > &  theShapes
[in]theBaseShapeshape that should be divided.
[in]thePointscontainer of points to split
[out]theShapescontainer of shapes after split
◆ splitShape_p()
void GeomAlgoAPI_ShapeTools::splitShape_p ( const std::shared_ptr< GeomAPI_Shape > &  theBaseShape,
const std::list< std::shared_ptr< GeomAPI_Pnt > > &  thePoints,
◆ wireToEdge()
std::shared_ptr< GeomAPI_Edge > GeomAlgoAPI_ShapeTools::wireToEdge ( const std::shared_ptr< GeomAPI_Wire > &  theWire)
◆ getLowLevelSubShapes()
ListOfShape GeomAlgoAPI_ShapeTools::getLowLevelSubShapes ( const GeomShapePtr &  theShape)
[in]theShapeshape that should be exploded
list of sub-shapes (vertices, edges, faces, solids)
◆ computeThroughAll()
void GeomAlgoAPI_ShapeTools::computeThroughAll ( const ListOfShape &  theObjects,
const ListOfShape &  theBaseShapes,
double &  theToSize,
double &  theFromSize
[in]theObjectsobjects to be joined/cut by the prism
[in]theBaseShapesbases of the prism
[in]theDirdirection of the prism
[out]theToSizeupper offset of the prism
[out]theFromSizelower offset of the prism
◆ getSharedFaces()
ListOfShape GeomAlgoAPI_ShapeTools::getSharedFaces ( const GeomShapePtr &  theShape)
list of shared faces
