FormHPContainer Class Reference
#include <FormHPContainer.hxx>
Inheritance diagram for FormHPContainer:
Collaboration diagram for FormHPContainer:
Public Slots
void onModifySzOfPool (const QString &newSz)
void initSciptChanged ()
- Public Slots inherited from FormContainerBase
void on_ch_advance_stateChanged (int state)
void onModifyName (const QString &text)
 FormHPContainer (QWidget *parent=0)
virtual ~FormHPContainer ()
void FillPanel (YACS::ENGINE::Container *container)
QString getTypeStr () const
bool onApply ()
- Public Member Functions inherited from FormContainerBase
 FormContainerBase (QWidget *parent=0)
virtual ~FormContainerBase ()
virtual void FillPanel (YACS::ENGINE::Container *container)
virtual void onModified ()
virtual bool onApply ()
virtual void onCancel ()
virtual QString getTypeStr () const =0
static std::string BuildWithFinalEndLine (const std::string &script)
QLineEdit * _poolSz
QTextEdit * _initScript
bool _initScriptModified
bool _initScriptLoaded
- Protected Attributes inherited from FormContainerBase
bool _advanced
YACS::ENGINE::Container * _container
std::map< std::string, std::string > _properties
FormAdvParamContainer * _advancedParams
Definition at line 40 of file FormHPContainer.hxx.
◆ FormHPContainer()
FormHPContainer::FormHPContainer ( QWidget *  parent = 0)
Definition at line 41 of file FormHPContainer.cxx.
42{
43 QIntValidator *iv(new QIntValidator(_poolSz)); iv->setRange(1,INT_MAX);
44 _poolSz->setValidator(iv);
45 label_15->setText("Size of pool :");
46 gridLayout_2_2->addWidget(_poolSz);
47 FormHPContainer::FillPanel(0); // --- set widgets before signal connexion to avoid false modif detection
48 connect(_poolSz, SIGNAL(textChanged(const QString&)),this, SLOT(onModifySzOfPool(const QString&)));
49 ch_aoc->setEnabled(false);
50 ch_aoc->setCheckState(Qt::Checked);
51 //
52#ifdef HAS_PYEDITOR
53 _initScript=new PyEditor_Editor(_advancedParams->tw_advance);
54#else
55 _initScript=new QTextEdit(this);
56#endif
57 connect(_initScript,SIGNAL(textChanged()),this,SLOT(initSciptChanged()));
58 QGridLayout *gridLayout(new QGridLayout(_initScript));
59 _advancedParams->tw_advance->addTab(_initScript,"Init Script");
60}
FormContainerBase(QWidget *parent=0)
void FillPanel(YACS::ENGINE::Container *container)
void onModifySzOfPool(const QString &newSz)
QLineEdit * _poolSz
References FormContainerBase::_advancedParams, _initScript, _poolSz, FillPanel(), initSciptChanged(), and onModifySzOfPool().
◆ ~FormHPContainer()
FormHPContainer::~FormHPContainer ( )
Definition at line 62 of file FormHPContainer.cxx.
63{
64}
◆ BuildWithFinalEndLine()
std::string FormHPContainer::BuildWithFinalEndLine ( const std::string &  script)
Definition at line 136 of file FormHPContainer.cxx.
137{
138 if(script.empty())
139 return std::string("\n");
140 std::size_t sz(script.length());
141 if(script[sz-1]!='\n')
142 {
143 std::string ret(script);
144 ret+="\n";
145 return ret;
146 }
147 else
148 return script;
149}
Referenced by FillPanel(), and onApply().
◆ FillPanel()
void FormHPContainer::FillPanel ( YACS::ENGINE::Container *  container)
Reimplemented from FormContainerBase.
Definition at line 66 of file FormHPContainer.cxx.
67{
68 DEBTRACE("FormHPContainer::FillPanel");
70 if(!container)
71 return ;
73 if(!hpc)
74 throw YACS::Exception("FormHPContainer::FillPanel : not a HP Container !");
75 _poolSz->setText(QString("%1").arg(hpc->getSizeOfPool()));
76 std::string initScript;
79 std::string initScript2(BuildWithFinalEndLine(initScript));
80 _initScript->blockSignals(true);
81 _initScript->setText(initScript2.c_str());
82 _initScript->blockSignals(false);
83 if (!YACS::HMI::QtGuiContext::getQtCurrent()->isEdition())
84 {
85 //if the schema is in execution do not allow editing
86 _poolSz->setEnabled(false);
87 _initScript->setEnabled(false);
88 }
89}
virtual void FillPanel(YACS::ENGINE::Container *container)
static std::string BuildWithFinalEndLine(const std::string &script)
References _initScript, _poolSz, FormContainerBase::_properties, BuildWithFinalEndLine(), DEBTRACE, FormContainerBase::FillPanel(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::ENGINE::HomogeneousPoolContainer::getSizeOfPool(), and YACS::ENGINE::HomogeneousPoolContainer::INITIALIZE_SCRIPT_KEY.
Referenced by FormHPContainer().
◆ getTypeStr()
QString FormHPContainer::getTypeStr ( ) const
Implements FormContainerBase.
Definition at line 91 of file FormHPContainer.cxx.
92{
93 return QString("Container (HP)");
94}
◆ initSciptChanged
void FormHPContainer::initSciptChanged ( )
slot
Definition at line 130 of file FormHPContainer.cxx.
131{
133 onModified();
134}
virtual void onModified()
References _initScriptModified, and FormContainerBase::onModified().
◆ onApply()
bool FormHPContainer::onApply ( )
Definition at line 111 of file FormHPContainer.cxx.
112{
114 YASSERT(scont);
115 bool ret(scont->setName(le_name->text().toStdString()));
116 std::map<std::string,std::string> properties(_properties);
118 {
119 std::string text(_initScript->toPlainText().toStdString());
120 std::string text2(BuildWithFinalEndLine(text));
122 }
124 DEBTRACE(ret);
125 if(ret)
126 ret = scont->setProperties(properties);
127 return ret;
128}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
References FormContainerBase::_container, _initScript, _initScriptModified, FormContainerBase::_properties, BuildWithFinalEndLine(), DEBTRACE, YACS::HMI::QtGuiContext::getQtCurrent(), YACS::ENGINE::HomogeneousPoolContainer::INITIALIZE_SCRIPT_KEY, YACS::HMI::SubjectContainerBase::setName(), YACS::HMI::SubjectContainerBase::setProperties(), and YASSERT.
◆ onModifySzOfPool
void FormHPContainer::onModifySzOfPool ( const QString &  newSz)
slot
Definition at line 96 of file FormHPContainer.cxx.
97{
98 if (!_container)
99 return;
100 map<string,string> properties(_container->getProperties());
101 uint sz;
102 bool isOK;
103 sz=newSz.toUInt(&isOK);
104 if(!isOK)
105 return ;
107 if(properties[YACS::ENGINE::HomogeneousPoolContainer::SIZE_OF_POOL_KEY] != newSz.toStdString())
108 onModified();
109}
virtual std::map< std::string, std::string > getProperties() const =0
References FormContainerBase::_container, FormContainerBase::_properties, YACS::ENGINE::Container::getProperties(), FormContainerBase::onModified(), and YACS::ENGINE::HomogeneousPoolContainer::SIZE_OF_POOL_KEY.
◆ _initScript
QTextEdit* FormHPContainer::_initScript
Definition at line 60 of file FormHPContainer.hxx.
Referenced by FillPanel(), FormHPContainer(), and onApply().
◆ _initScriptLoaded
bool FormHPContainer::_initScriptLoaded
Definition at line 63 of file FormHPContainer.hxx.
◆ _initScriptModified
bool FormHPContainer::_initScriptModified
Definition at line 62 of file FormHPContainer.hxx.
Referenced by initSciptChanged(), and onApply().
◆ _poolSz
QLineEdit* FormHPContainer::_poolSz
Definition at line 56 of file FormHPContainer.hxx.
Referenced by FillPanel(), and FormHPContainer().
