YACSPMMLBasicsTest1 Class Reference
#include <YACSPMMLBasicsTest1.hxx>
Inheritance diagram for YACSPMMLBasicsTest1:
Collaboration diagram for YACSPMMLBasicsTest1:
void setUp ()
void tearDown ()
void testYACSdriverLinearRegression ()
void testYACSdriverNeuralNetwork ()
void testYACSdriver_LRANN ()
void testYACSdriver_PmmlDoesNotExist ()
 CPPUNIT_TEST_SUITE (YACSPMMLBasicsTest1)
 CPPUNIT_TEST (testYACSdriverLinearRegression)
 CPPUNIT_TEST (testYACSdriverNeuralNetwork)
 CPPUNIT_TEST (testYACSdriver_LRANN)
 CPPUNIT_TEST (testYACSdriver_PmmlDoesNotExist)
 CPPUNIT_TEST_SUITE_END ()
std::string resourcesDir
Definition at line 30 of file YACSPMMLBasicsTest1.hxx.
◆ CPPUNIT_TEST() [1/4]
YACSPMMLBasicsTest1::CPPUNIT_TEST ( testYACSdriver_LRANN  )
◆ CPPUNIT_TEST() [2/4]
YACSPMMLBasicsTest1::CPPUNIT_TEST ( testYACSdriver_PmmlDoesNotExist  )
◆ CPPUNIT_TEST() [3/4]
YACSPMMLBasicsTest1::CPPUNIT_TEST ( testYACSdriverLinearRegression  )
◆ CPPUNIT_TEST() [4/4]
YACSPMMLBasicsTest1::CPPUNIT_TEST ( testYACSdriverNeuralNetwork  )
◆ CPPUNIT_TEST_SUITE()
YACSPMMLBasicsTest1::CPPUNIT_TEST_SUITE ( YACSPMMLBasicsTest1  )
◆ CPPUNIT_TEST_SUITE_END()
YACSPMMLBasicsTest1::CPPUNIT_TEST_SUITE_END ( )
◆ setUp()
void YACSPMMLBasicsTest1::setUp ( )
Definition at line 126 of file YACSPMMLBasicsTest1.cxx.
127{
128 resourcesDir = "samples/";
129}
References resourcesDir.
◆ tearDown()
void YACSPMMLBasicsTest1::tearDown ( )
Definition at line 131 of file YACSPMMLBasicsTest1.cxx.
132{
133}
◆ testYACSdriver_LRANN()
void YACSPMMLBasicsTest1::testYACSdriver_LRANN ( )
Definition at line 174 of file YACSPMMLBasicsTest1.cxx.
175{
176 std::string xmlFilename = resourcesDir + "schemaANNLR2.xml";
177 Proc *p = 0;
178 int ret = driverTest(p, xmlFilename.c_str() );
179 CPPUNIT_ASSERT(ret == 0);
180 DEBTRACE("Proc *p = " << p);
181 CPPUNIT_ASSERT(p != 0);
182 if (p)
183 {
184 YACS::ENGINE::Node* node = p->nodeMap[string("PyGetRes")];
185 YACS::ENGINE::OutputPort* outputPort = node->getOutputPort(string("res"));
186 string str = outputPort->getAsString();
187 DEBTRACE("str = " << str);
188 CPPUNIT_ASSERT_EQUAL(str, string("True"));
189 delete p;
190 }
191}
int driverTest(Proc *&p, const char *schema)
Definition: DataPort.cxx:84
Base class for all nodes.
Definition: Node.hxx:70
virtual OutputPort * getOutputPort(const std::string &name) const =0
Definition: Proc.hxx:44
std::map< std::string, Node * > nodeMap
Definition: Proc.hxx:87
Proc * p
Definition: driver.cxx:216
References DEBTRACE, driverTest(), YACS::ENGINE::DataPort::getAsString(), YACS::ENGINE::Node::getOutputPort(), YACS::ENGINE::Proc::nodeMap, p, and resourcesDir.
◆ testYACSdriver_PmmlDoesNotExist()
void YACSPMMLBasicsTest1::testYACSdriver_PmmlDoesNotExist ( )
Definition at line 193 of file YACSPMMLBasicsTest1.cxx.
194{
195 std::string xmlFilename = resourcesDir + "schemaPmmlDoesNotExist.xml";
196 Proc *p = 0;
197 int ret = driverTest(p, xmlFilename.c_str() );
198 CPPUNIT_ASSERT(ret == 0);
199 DEBTRACE("Proc *p = " << p);
200 CPPUNIT_ASSERT(p != 0);
201 if (p)
202 {
203 YACS::ENGINE::Node* node = p->nodeMap[string("PyGetRes")];
204 YACS::ENGINE::OutputPort* outputPort = node->getOutputPort(string("res"));
205 string str = outputPort->getAsString();
206 DEBTRACE("str = " << str);
207 CPPUNIT_ASSERT_EQUAL(str, string("None"));
208 delete p;
209 }
210}
◆ testYACSdriverLinearRegression()
void YACSPMMLBasicsTest1::testYACSdriverLinearRegression ( )
Definition at line 136 of file YACSPMMLBasicsTest1.cxx.
137{
138 std::string xmlFilename = resourcesDir + "schemaLR2.xml";
139 Proc *p = 0;
140 int ret = driverTest(p, xmlFilename.c_str() );
141 CPPUNIT_ASSERT(ret == 0);
142 DEBTRACE("Proc *p = " << p);
143 CPPUNIT_ASSERT(p != 0);
144 if (p)
145 {
146 YACS::ENGINE::Node* node = p->nodeMap[string("PyGetRes")];
147 YACS::ENGINE::OutputPort* outputPort = node->getOutputPort(string("res"));
148 string str = outputPort->getAsString();
149 DEBTRACE("str = " << str);
150 CPPUNIT_ASSERT_EQUAL(str, string("True"));
151 delete p;
152 }
153}
◆ testYACSdriverNeuralNetwork()
void YACSPMMLBasicsTest1::testYACSdriverNeuralNetwork ( )
Definition at line 155 of file YACSPMMLBasicsTest1.cxx.
156{
157 std::string xmlFilename = resourcesDir + "schemaANN2.xml";
158 Proc *p = 0;
159 int ret = driverTest(p, xmlFilename.c_str() );
160 CPPUNIT_ASSERT(ret == 0);
161 DEBTRACE("Proc *p = " << p);
162 CPPUNIT_ASSERT(p != 0);
163 if (p)
164 {
165 YACS::ENGINE::Node* node = p->nodeMap[string("PyGetRes")];
166 YACS::ENGINE::OutputPort* outputPort = node->getOutputPort(string("res"));
167 string str = outputPort->getAsString();
168 DEBTRACE("str = " << str);
169 CPPUNIT_ASSERT_EQUAL(str, string("True"));
170 delete p;
171 }
172}
◆ resourcesDir
