YACS::ENGINE::DeploymentTreeOnHeap Class Reference
#include <DeploymentTree.hxx>
Collaboration diagram for YACS::ENGINE::DeploymentTreeOnHeap:
 DeploymentTreeOnHeap ()
 ~DeploymentTreeOnHeap ()
bool decrRef ()
void incrRef () const
unsigned char appendTask (Task *task, Scheduler *cloner)
unsigned getNumberOfCTDefContainer () const
unsigned getNumberOfRTODefContainer () const
unsigned getNumberOfCTDefComponentInstances () const
unsigned getNumberOfRTODefComponentInstances () const
std::vector< Container * > getAllContainers () const
std::vector< Container * > getAllCTDefContainers () const
std::vector< Container * > getAllRTODefContainers () const
std::vector< Task * > getTasksLinkedToComponent (ComponentInstance *comp) const
std::vector< Task * > getTasksLinkedToContainer (Container *cont) const
std::vector< ComponentInstance * > getComponentsLinkedToContainer (Container *cont) const
bool presenceOfDefaultContainer () const
std::vector< Task * > getFreeDeployableTasks () const
int _cnt
std::vector< std::pair< Task *, Scheduler * > > _freePlacableTasks
std::vector< std::vector< std::vector< std::pair< Task *, Scheduler * > > > > _tree
 internal representation of tree. Scheduler is the duplicating Task, if it exists, on runtime unpredictable times on compil-time More...
Definition at line 36 of file DeploymentTree.hxx.
◆ DeploymentTreeOnHeap()
DeploymentTreeOnHeap::DeploymentTreeOnHeap ( )
Definition at line 32 of file DeploymentTree.cxx.
◆ ~DeploymentTreeOnHeap()
DeploymentTreeOnHeap::~DeploymentTreeOnHeap ( )
Definition at line 36 of file DeploymentTree.cxx.
37{
38}
◆ appendTask()
unsigned char DeploymentTreeOnHeap::appendTask ( Task *  task,
Scheduler *  cloner
Definition at line 53 of file DeploymentTree.cxx.
54{
55 DEBTRACE( "DeploymentTreeOnHeap::appendTask: " << task );
56 if(!task)
58 if(!task->isDeployable())//Task not needed to be placed.
61 Container *cont=task->getContainer();
62 DEBTRACE( "DeploymentTreeOnHeap::appendTask component: " << ci );
63 DEBTRACE( "DeploymentTreeOnHeap::appendTask container: " << cont );
64 if(!ci && !cont)//Task is not attached to a Component or a Container -> not needed to be placed.
65 {
66 _freePlacableTasks.push_back(pair<Task *,Scheduler *>(task,cloner));
68 }
69 DEBTRACE( "DeploymentTreeOnHeap::appendTask container: " << cont );
70
71 // an iterator for Container level
72 vector< vector< vector< pair<Task *, Scheduler *> > > >::iterator iter1;
73 // an iterator for Component instance level
74 vector< vector< pair<Task *, Scheduler * > > >::iterator iter2;
75 // an iterator for a vector of tasks with same container and component instance
76 vector< pair<Task *, Scheduler *> >::iterator iter3;
77
78 // search an existing vector of tasks with container == cont
79 for(iter1=_tree.begin();iter1!=_tree.end();iter1++)
80 {
81 Task* task=(*iter1)[0][0].first;
82 if(task->getContainer() == cont)
83 break;
84 }
85 if(iter1==_tree.end())
86 {
87 // the vector does not exist : create it
88 DEBTRACE("create a vector of vector of tasks for container " << cont);
89 _tree.push_back(vector< vector< pair< Task *, Scheduler *> > >());
90 iter1=_tree.end();
91 iter1--;
92 }
93
94 // search a vector of tasks with component instance == ci
95 for(iter2=(*iter1).begin();iter2!=(*iter1).end();iter2++)
96 if(((*iter2)[0]).first->getComponent()==ci)
97 break;
98 if(iter2==(*iter1).end())
99 {
100 // the vector does not exist : create it
101 DEBTRACE("create a vector of tasks for component instance " << ci);
102 (*iter1).push_back(vector< pair< Task *, Scheduler *> >());
103 iter2=(*iter1).end();
104 iter2--;
105 }
106
107 // search the task in the vector. If it exists return
108 for(iter3=(*iter2).begin();iter3!=(*iter2).end();iter3++)
109 if((*iter3).first==task)
111
112 DEBTRACE("add task to vector of tasks " << task);
113 (*iter2).push_back(pair<Task *,Scheduler *>(task,cloner));
115}
internal representation of tree. Scheduler is the duplicating Task, if it exists, on runtime unpredic...
static const unsigned char NOT_DEPLOYABLE_TASK
static const unsigned char ALREADY_IN_TREE
static const unsigned char NULL_TASK
static const unsigned char DEPLOYABLE_BUT_NOT_SPECIFIED
static const unsigned char APPEND_OK
virtual bool isDeployable() const =0
virtual Container * getContainer()=0
virtual ComponentInstance * getComponent()=0
References _freePlacableTasks, _tree, YACS::ENGINE::DeploymentTree::ALREADY_IN_TREE, YACS::ENGINE::DeploymentTree::APPEND_OK, DEBTRACE, YACS::ENGINE::DeploymentTree::DEPLOYABLE_BUT_NOT_SPECIFIED, YACS::ENGINE::Task::getComponent(), YACS::ENGINE::Task::getContainer(), YACS::ENGINE::Task::isDeployable(), YACS::ENGINE::DeploymentTree::NOT_DEPLOYABLE_TASK, and YACS::ENGINE::DeploymentTree::NULL_TASK.
Referenced by YACS::ENGINE::DeploymentTree::appendTask().
◆ decrRef()
bool DeploymentTreeOnHeap::decrRef ( )
Definition at line 40 of file DeploymentTree.cxx.
41{
42 bool ret=(--_cnt==0);
43 if(ret)
44 delete this;
45 return ret;
46}
References _cnt.
Referenced by YACS::ENGINE::DeploymentTree::operator=(), and YACS::ENGINE::DeploymentTree::~DeploymentTree().
◆ getAllContainers()
std::vector< Container * > DeploymentTreeOnHeap::getAllContainers ( ) const
Definition at line 235 of file DeploymentTree.cxx.
236{
237 vector<Container *> ret;
238 vector< vector< vector< pair<Task *, Scheduler *> > > >::const_iterator iter1;
239 for(iter1=_tree.begin();iter1!=_tree.end();iter1++)
240 {
241 Task* task=(*iter1)[0][0].first;
242 ret.push_back(task->getContainer());
243 }
244 return ret;
245}
References _tree, and YACS::ENGINE::Task::getContainer().
Referenced by YACS::ENGINE::DeploymentTree::getAllContainers().
◆ getAllCTDefContainers()
std::vector< Container * > DeploymentTreeOnHeap::getAllCTDefContainers ( ) const
Definition at line 247 of file DeploymentTree.cxx.
248{
249 DEBTRACE("getAllCTDefContainers");
250 vector<Container *> ret;
251 vector< vector< vector< pair<Task *, Scheduler *> > > >::const_iterator iter1;
252 vector< vector< pair<Task *, Scheduler * > > >::const_iterator iter2;
253 vector< pair<Task *, Scheduler *> >::const_iterator iter3;
254 for(iter1=_tree.begin();iter1!=_tree.end();iter1++)
255 {
256 bool isCTDefSurely1=true;
257 for(iter2=(*iter1).begin();iter2!=(*iter1).end() && isCTDefSurely1;iter2++)
258 {
259 bool isCTDefSurely2=true;
260 for(iter3=(*iter2).begin();iter3!=(*iter2).end() && isCTDefSurely2;iter3++)
261 if((*iter3).second!=0)
262 isCTDefSurely2=false;
263 if(isCTDefSurely2)
264 isCTDefSurely1=true;
265 else if(((*iter2)[0].first)->getComponent())
266 isCTDefSurely1=(((*iter2)[0].first)->getComponent()->isAttachedOnCloning());
267 else
268 isCTDefSurely1=false;
269 }
270 Container *cont=((*iter1)[0][0].first)->getContainer();
271 if(isCTDefSurely1)
272 {
273 if(cont)
274 ret.push_back(cont);
275 }
276 else
277 if(cont)
278 if(cont->isAttachedOnCloning())
279 ret.push_back(cont);
280 }
281 return ret;
282}
virtual bool isAttachedOnCloning() const
Definition: Container.cxx:89
References _tree, DEBTRACE, and YACS::ENGINE::Container::isAttachedOnCloning().
Referenced by YACS::ENGINE::DeploymentTree::getAllCTDefContainers().
◆ getAllRTODefContainers()
std::vector< Container * > DeploymentTreeOnHeap::getAllRTODefContainers ( ) const
Definition at line 284 of file DeploymentTree.cxx.
285{
286 DEBTRACE("getAllRTODefContainers");
287 vector< vector< vector< pair<Task *, Scheduler *> > > >::const_iterator iter1;
288 vector< vector< pair<Task *, Scheduler * > > >::const_iterator iter2;
289 vector< pair<Task *, Scheduler *> >::const_iterator iter3;
290 vector<Container *> ret;
291 for(iter1=_tree.begin();iter1!=_tree.end();iter1++)
292 {
293 bool isRTODefSurely1=true;
294 for(iter2=(*iter1).begin();iter2!=(*iter1).end() && isRTODefSurely1;iter2++)
295 {
296 bool isRTODefSurely2=true;
297 for(iter3=(*iter2).begin();iter3!=(*iter2).end() && isRTODefSurely2;iter3++)
298 if((*iter3).second==0)
299 isRTODefSurely2=false;
300 if(isRTODefSurely2)
301 {
302 if(((*iter2)[0].first)->getComponent())
303 isRTODefSurely1=!(((*iter2)[0].first)->getComponent()->isAttachedOnCloning());
304 else
305 isRTODefSurely1=false;
306 }
307 else
308 isRTODefSurely1=false;
309 }
310 if(isRTODefSurely1)
311 {
312 Container* cont= (*iter1)[0][0].first->getContainer();
313 if(cont)
314 if(!cont->isAttachedOnCloning())
315 ret.push_back(cont);
316 }
317 }
318 return ret;
319}
Referenced by YACS::ENGINE::DeploymentTree::getAllRTODefContainers().
◆ getComponentsLinkedToContainer()
std::vector< ComponentInstance * > DeploymentTreeOnHeap::getComponentsLinkedToContainer ( Container *  cont) const
Definition at line 354 of file DeploymentTree.cxx.
355{
356 DEBTRACE("DeploymentTreeOnHeap::getComponentsLinkedToContainer ");
357 vector<ComponentInstance *> ret;
358 vector< vector< vector< pair<Task *, Scheduler *> > > >::const_iterator iter1;
359 vector< vector< pair<Task *, Scheduler * > > >::const_iterator iter2;
360 //iterate on containers
361 for(iter1=_tree.begin();iter1!=_tree.end();++iter1)
362 {
363 //iterate on components
364 for(iter2=(*iter1).begin();iter2!=(*iter1).end();++iter2)
365 {
366 ComponentInstance *compo=(*iter2)[0].first->getComponent();
367 if(compo)
368 {
369 //it's a real component, add it if its container is the right one
370 if(compo->getContainer()==cont)
371 ret.push_back(compo);
372 else
373 break;
374 }
375 }
376 }
377
378 return ret;
379}
References _tree, DEBTRACE, and YACS::ENGINE::ComponentInstance::getContainer().
Referenced by YACS::ENGINE::DeploymentTree::getComponentsLinkedToContainer().
◆ getFreeDeployableTasks()
std::vector< Task * > DeploymentTreeOnHeap::getFreeDeployableTasks ( ) const
Definition at line 391 of file DeploymentTree.cxx.
392{
393 vector<Task *> ret;
394 for(vector< pair<Task *,Scheduler *> >::const_iterator iter=_freePlacableTasks.begin();iter!=_freePlacableTasks.end();iter++)
395 ret.push_back((*iter).first);
396 return ret;
397}
References _freePlacableTasks.
Referenced by YACS::ENGINE::DeploymentTree::getFreeDeployableTasks().
◆ getNumberOfCTDefComponentInstances()
unsigned DeploymentTreeOnHeap::getNumberOfCTDefComponentInstances ( ) const
Definition at line 192 of file DeploymentTree.cxx.
193{
194 DEBTRACE("getNumberOfCTDefComponentInstances");
195 vector< vector< vector< pair<Task *, Scheduler *> > > >::const_iterator iter1;
196 vector< vector< pair<Task *, Scheduler * > > >::const_iterator iter2;
197 vector< pair<Task *, Scheduler *> >::const_iterator iter3;
198 unsigned ret=0;
199 for(iter1=_tree.begin();iter1!=_tree.end();iter1++)
200 for(iter2=(*iter1).begin();iter2!=(*iter1).end();iter2++)
201 {
202 bool isCTDefSurely=true;
203 for(iter3=(*iter2).begin();iter3!=(*iter2).end() && isCTDefSurely;iter3++)
204 if((*iter3).second!=0)
205 isCTDefSurely=false;
206 if(isCTDefSurely)
207 ret++;
208 else
209 if(((*iter2)[0].first)->getComponent() && ((*iter2)[0].first)->getComponent()->isAttachedOnCloning())
210 ret++;
211 }
212 return ret;
213}
References _tree, and DEBTRACE.
Referenced by YACS::ENGINE::DeploymentTree::getNumberOfCTDefComponentInstances().
◆ getNumberOfCTDefContainer()
unsigned DeploymentTreeOnHeap::getNumberOfCTDefContainer ( ) const
Definition at line 117 of file DeploymentTree.cxx.
118{
119 DEBTRACE("getNumberOfCTDefContainer ");
120 vector< vector< vector< pair<Task *, Scheduler *> > > >::const_iterator iter1;
121 vector< vector< pair<Task *, Scheduler * > > >::const_iterator iter2;
122 vector< pair<Task *, Scheduler *> >::const_iterator iter3;
123 unsigned ret=0;
124 for(iter1=_tree.begin();iter1!=_tree.end();iter1++)
125 {
126 bool isCTDefSurely1=true;
127 for(iter2=(*iter1).begin();iter2!=(*iter1).end() && isCTDefSurely1;iter2++)
128 {
129 bool isCTDefSurely2=true;
130 for(iter3=(*iter2).begin();iter3!=(*iter2).end() && isCTDefSurely2;iter3++)
131 if((*iter3).second!=0)
132 isCTDefSurely2=false;
133 if(isCTDefSurely2)
134 isCTDefSurely1=true;
135 else if(((*iter2)[0].first)->getComponent())
136 isCTDefSurely1=(((*iter2)[0].first)->getComponent()->isAttachedOnCloning());
137 else
138 isCTDefSurely1=false;
139 }
140 Container *cont=((*iter1)[0][0].first)->getContainer();
141 if(isCTDefSurely1)
142 {
143 if(cont)
144 ret++;
145 }
146 else
147 if(cont)
148 if(cont->isAttachedOnCloning())
149 ret++;
150 else
151 {
152 unsigned val;
153 if((*iter1)[0][0].second->isMultiplicitySpecified(val))
154 ret+=val;
155 }
156 }
157 return ret;
158}
Referenced by YACS::ENGINE::DeploymentTree::getNumberOfCTDefContainer().
◆ getNumberOfRTODefComponentInstances()
unsigned DeploymentTreeOnHeap::getNumberOfRTODefComponentInstances ( ) const
Definition at line 215 of file DeploymentTree.cxx.
216{
217 DEBTRACE("getNumberOfRTODefComponentInstances");
218 vector< vector< vector< pair<Task *, Scheduler *> > > >::const_iterator iter1;
219 vector< vector< pair<Task *, Scheduler * > > >::const_iterator iter2;
220 vector< pair<Task *, Scheduler *> >::const_iterator iter3;
221 unsigned ret=0;
222 for(iter1=_tree.begin();iter1!=_tree.end();iter1++)
223 for(iter2=(*iter1).begin();iter2!=(*iter1).end();iter2++)
224 {
225 bool isRTODef=false;
226 for(iter3=(*iter2).begin();iter3!=(*iter2).end() && !isRTODef;iter3++)
227 if((*iter3).second!=0)
228 isRTODef=true;
229 if(isRTODef && ((*iter2)[0].first)->getComponent() && !((*iter2)[0].first)->getComponent()->isAttachedOnCloning())
230 ret++;
231 }
232 return ret;
233}
Referenced by YACS::ENGINE::DeploymentTree::getNumberOfRTODefComponentInstances().
◆ getNumberOfRTODefContainer()
unsigned DeploymentTreeOnHeap::getNumberOfRTODefContainer ( ) const
Definition at line 160 of file DeploymentTree.cxx.
161{
162 DEBTRACE("getNumberOfRTODefContainer");
163 vector< vector< vector< pair<Task *, Scheduler *> > > >::const_iterator iter1;
164 vector< vector< pair<Task *, Scheduler * > > >::const_iterator iter2;
165 vector< pair<Task *, Scheduler *> >::const_iterator iter3;
166 unsigned ret=0;
167 for(iter1=_tree.begin();iter1!=_tree.end();iter1++)
168 {
169 bool isRTODefSurely1=true;
170 for(iter2=(*iter1).begin();iter2!=(*iter1).end() && isRTODefSurely1;iter2++)
171 {
172 bool isRTODefSurely2=true;
173 for(iter3=(*iter2).begin();iter3!=(*iter2).end() && isRTODefSurely2;iter3++)
174 if((*iter3).second==0)
175 isRTODefSurely2=false;
176 if(isRTODefSurely2)
177 if(((*iter2)[0].first)->getComponent())
178 isRTODefSurely1=!(((*iter2)[0].first)->getComponent()->isAttachedOnCloning());
179 else
180 isRTODefSurely1=false;
181 else
182 isRTODefSurely1=false;
183 }
184 if(isRTODefSurely1)
185 if(((*iter1)[0][0].first)->getContainer())
186 if(!((*iter1)[0][0].first)->getContainer()->isAttachedOnCloning())
187 ret++;
188 }
189 return ret;
190}
Referenced by YACS::ENGINE::DeploymentTree::getNumberOfRTODefContainer().
◆ getTasksLinkedToComponent()
std::vector< Task * > DeploymentTreeOnHeap::getTasksLinkedToComponent ( ComponentInstance *  comp) const
Definition at line 339 of file DeploymentTree.cxx.
340{
341 vector< vector< vector< pair<Task *, Scheduler *> > > >::const_iterator iter1;
342 vector< vector< pair<Task *, Scheduler * > > >::const_iterator iter2;
343 vector< pair<Task *, Scheduler *> >::const_iterator iter3;
344
345 std::vector<Task *> ret;
346 for(iter1=_tree.begin();iter1!=_tree.end();iter1++)
347 for(iter2=(*iter1).begin();iter2!=(*iter1).end();iter2++)
348 if(((*iter2)[0].first)->getComponent()==comp)
349 for(iter3=(*iter2).begin();iter3!=(*iter2).end();iter3++)
350 ret.push_back((*iter3).first);
351 return ret;
352}
References _tree, and yacsorb.CORBAEngineTest::comp.
Referenced by YACS::ENGINE::DeploymentTree::getTasksLinkedToComponent().
◆ getTasksLinkedToContainer()
std::vector< Task * > DeploymentTreeOnHeap::getTasksLinkedToContainer ( Container *  cont) const
Definition at line 321 of file DeploymentTree.cxx.
322{
323 vector< vector< vector< pair<Task *, Scheduler *> > > >::const_iterator iter1;
324 vector< vector< pair<Task *, Scheduler * > > >::const_iterator iter2;
325 vector< pair<Task *, Scheduler *> >::const_iterator iter3;
326
327 std::vector<Task *> ret;
328 for(iter1=_tree.begin();iter1!=_tree.end();iter1++)
329 {
330 if(((*iter1)[0][0].first)->getContainer()==cont)
331 for(iter2=(*iter1).begin();iter2!=(*iter1).end();iter2++)
332 if(((*iter2)[0].first)->getComponent()==0)
333 for(iter3=(*iter2).begin();iter3!=(*iter2).end();iter3++)
334 ret.push_back((*iter3).first);
335 }
336 return ret;
337}
References _tree.
Referenced by YACS::ENGINE::DeploymentTree::getTasksLinkedToContainer().
◆ incrRef()
void DeploymentTreeOnHeap::incrRef ( ) const
Definition at line 48 of file DeploymentTree.cxx.
49{
50 _cnt++;
51}
References _cnt.
Referenced by YACS::ENGINE::DeploymentTree::DeploymentTree(), and YACS::ENGINE::DeploymentTree::operator=().
◆ presenceOfDefaultContainer()
bool DeploymentTreeOnHeap::presenceOfDefaultContainer ( ) const
Definition at line 381 of file DeploymentTree.cxx.
382{
383 DEBTRACE("presenceOfDefaultContainer");
384 vector< vector< vector< pair<Task *, Scheduler *> > > >::const_iterator iter1;
385 for(iter1=_tree.begin();iter1!=_tree.end();iter1++)
386 if(!((*iter1)[0][0].first)->getContainer())
387 return true;
388 return false;
389}
Referenced by YACS::ENGINE::DeploymentTree::presenceOfDefaultContainer().
◆ _cnt
int YACS::ENGINE::DeploymentTreeOnHeap::_cnt
mutableprivate
Definition at line 61 of file DeploymentTree.hxx.
Referenced by decrRef(), and incrRef().
◆ _freePlacableTasks
std::vector< std::pair<Task *,Scheduler *> > YACS::ENGINE::DeploymentTreeOnHeap::_freePlacableTasks
Definition at line 62 of file DeploymentTree.hxx.
Referenced by appendTask(), and getFreeDeployableTasks().
◆ _tree
std::vector< std::vector< std::vector< std::pair<Task *, Scheduler * > > > > YACS::ENGINE::DeploymentTreeOnHeap::_tree
