YACS::HMI::SchemaReferenceItem Class Reference
#include <SchemaReferenceItem.hxx>
Inheritance diagram for YACS::HMI::SchemaReferenceItem:
Collaboration diagram for YACS::HMI::SchemaReferenceItem:
 SchemaReferenceItem (SchemaItem *parent, QString label, Subject *subject)
virtual void popupMenu (QWidget *caller, const QPoint &globalPos)
- Public Member Functions inherited from YACS::HMI::SchemaItem
 SchemaItem (SchemaItem *parent, QString label, Subject *subject)
virtual ~SchemaItem ()
virtual void appendChild (SchemaItem *child)
virtual void removeChild (SchemaItem *child)
virtual void insertChild (int row, SchemaItem *child)
virtual SchemaItem * child (int row)
virtual int childCount () const
virtual int columnCount () const
virtual QVariant data (int column, int role) const
virtual Qt::ItemFlags flags (const QModelIndex &index)
virtual int row () const
virtual SchemaItem * parent ()
virtual void toggleState ()
QModelIndex modelIndex (int column=0)
virtual ItemMimeData * mimeData (ItemMimeData *mime)
virtual bool dropMimeData (const QMimeData *data, Qt::DropAction action)
virtual void reparent (SchemaItem *parent)
virtual void setCaseValue ()
 used in node derived classes More...
bool isEmphasized ()
void setEmphasize (bool emphasize)
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
static void setEventMap ()
- Protected Member Functions inherited from YACS::HMI::SchemaItem
virtual QVariant editionToolTip (int column) const
virtual QVariant runToolTip (int column) const
virtual QVariant editionWhatsThis (int column) const
virtual QVariant runWhatsThis (int column) const
virtual QString getMimeFormat ()
virtual void setExecState (int execState)
- Protected Attributes inherited from YACS::HMI::SchemaItem
QList< SchemaItem * > _childItems
QList< QVariant > _itemData
QList< QVariant > _itemDeco
QList< QVariant > _itemForeground
QList< QVariant > _itemBackground
QList< QVariant > _itemCheckState
QList< QVariant > _itemToolTip
QList< QVariant > _itemWhatsThis
QString _label
SchemaItem * _parentItem
Subject * _subject
int _execState
bool _emphasized
bool _destructible
Definition at line 29 of file SchemaReferenceItem.hxx.
◆ SchemaReferenceItem()
SchemaReferenceItem::SchemaReferenceItem ( SchemaItem *  parent,
QString  label,
Subject *  subject
Definition at line 32 of file SchemaReferenceItem.cxx.
33 : SchemaItem(parent, label, subject)
34{
35 _itemDeco.replace(YLabel, QIcon("icons:ob_service_node.png"));
36 _itemForeground.replace(YLabel,QColor("green"));
37}
Definition: SchemaItem.hxx:78
virtual SchemaItem * parent()
Definition: SchemaItem.cxx:163
SchemaItem(SchemaItem *parent, QString label, Subject *subject)
Definition: SchemaItem.cxx:39
Definition: SchemaItem.hxx:79
References YACS::HMI::SchemaItem::_itemDeco, YACS::HMI::SchemaItem::_itemForeground, and YACS::HMI::YLabel.
◆ popupMenu()
void SchemaReferenceItem::popupMenu ( QWidget *  caller,
const QPoint &  globalPos
Reimplemented from YACS::HMI::SchemaItem.
Definition at line 53 of file SchemaReferenceItem.cxx.
54{
56 m.popupMenu(caller, globalPos);
57}
References gui.GraphViewer::m.
◆ update()
void SchemaReferenceItem::update ( GuiEvent  event,
int  type,
Subject *  son
Definition at line 39 of file SchemaReferenceItem.cxx.
40{
41 DEBTRACE("SchemaReferenceItem::update "<< eventName(event) <<" "<<type<<" "<<son);
42 if(event==RENAME)
43 {
45 _label = son->getName().c_str();
46 _itemData.replace(YLabel, _label);
47 model->setData(modelIndex(YLabel), 0); // --- to emit dataChanged signal
48 }
49 else
50 SchemaItem::update(event, type, son);
51}
Definition: SchemaItem.cxx:253
Definition: SchemaItem.cxx:174
Definition: SchemaItem.hxx:77
virtual bool setData(const QModelIndex &index, const QVariant &value, int role=Qt::EditRole)
virtual std::string getName()
References YACS::HMI::SchemaItem::_itemData, YACS::HMI::SchemaItem::_label, DEBTRACE, YACS::HMI::GuiObserver::eventName(), YACS::HMI::Subject::getName(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getSchemaModel(), YACS::HMI::SchemaItem::modelIndex(), YACS::HMI::RENAME, YACS::HMI::SchemaModel::setData(), YACS::HMI::SchemaItem::update(), and YACS::HMI::YLabel.
Referenced by gui.graph.MyCanvas::customEvent().
