FIELDS module GUI
FIELDS module uses the following components to manage and display presentations:
Standard SALOME Object browser represents structure of MED file within FIELDS module. When MED file is loaded, the following steps are performed:
Reading structure of MED file. For these purpose,
MEDCALC::MedDataManagerCORBA service (which uses MEDCoupling library) is used.Creating structure of MED file (full path to MED file, name of a mesh, name and type (
ON_NODESorON_CELLS) of each field in MED file, and all timesteps for each field).MED_ORB::MEDCORBA component is used for that, and each item of the data tree structure is represented via standard SALOME data objectSObject.
Presentation Parameters panel allows managing parameters of presentations. This panel is implemented in the following way:
Interface of Presentation Parameters panel is described via Qt Designer tool; for details see
WidgetPresentationParameters.ui(UI form) andWidgetPresentationParameters.cxx(C++ wrapping of UI) files. The UI file contains all needed GUI controls which are used to manage parameters of all FIELDS presentations, i.e. single UI file is used for all types of presentations. All these parameters are hidden by default; and parameters, required for specific presentation are shown at first usage, for example:void WidgetPresentationParameters::setSliceOrientation(MEDCALC::SliceOrientationType orient) { ... // Show the widgets: _ui.labelSliceOrient->show(); _ui.comboBoxSliceOrient->show(); ... ... ... }
Widget which contains all these parameters is displayed inside the dockable window which is created during the initialization of FIELDS module.
Interaction between GUI controls and
medcalcPython package is implemented via several helper classes. The hierarchy of these classes is presented on the following diagram:
MEDWidgetHelper- base abstract class to manage common parameters of all FIELDS presentations.MEDWidgetHelperComponent- base abstract class to manage parameters of all presentations having only one component to change.These base classes contain one pure virtual method
virtual std::string getPythonTag() const = 0;
This method must be implemented in all descendant classes; it should return the type of a presentation (« ScalarMap », « Slices » and etc.)
All other classes (such as
MEDWidgetHelperScalarMap,MEDWidgetHelperSlicesetc.) are descendants of classesMEDWidgetHelperorMEDWidgetHelperComponent.
Helper classes send
PresentationEventevent via emittingpresentationUpdateSignalsignal on any user action made in Presentation Parameters panel.PresentationControllerclass is aimed for
Converting
PresentationEventevents to calls ofmedcalcPython package API, and executing related commands in the embedded Python console, for example:QStringList commands; ... if ( event->eventtype == PresentationEvent::EVENT_CHANGE_COMPONENT ) { // Get presentation type by calling getPythonTag() method std::string typ = getPresTypeFromWidgetHelper(event->presentationId); // Convert 'PresentationEvent' to set of python commands commands += QString("params = medcalc.Get%1Parameters(%2)").arg(QString::fromStdString(typ)).arg(event->presentationId); commands += QString("params.displayedComponent = '%1'").arg(QString::fromStdString(event->aString)); commands += QString("medcalc.Update%1(%2, params)").arg(QString::fromStdString(typ)).arg(event->presentationId); } ... _consoleDriver->exec(commands);
Updating content of Presentation Parameters panel according to the presentation, selected in the Object browser.
Standard SALOME Displayer mechanism is used to manage visiblity of FIELDS presentations in the ParaView viewer.
