FIELDS module implementation layer
FIELDS module uses Python API of the ParaVis module to build presentations. Internally any presentation of the FIELDS module is implemented as a particular pipeline of the ParaVis filters, which always starts with the MEDReader. At the implementation level, a pipeline which represents presentation is built via a sequence of the Python commands. These command are executed in the builtin Python interpreter.
The hierarchical structure of the presentation classes is shown on the diagram:
The base class for all presentations is MEDPresentation; it contains base functionalities for all presentations. All others classes implement functionalities of particular presentations.
