SALOME_Fake_NamingService Class Reference
#include <SALOME_Fake_NamingService.hxx>
Inheritance diagram for SALOME_Fake_NamingService:
 SALOME_Fake_NamingService (CORBA::ORB_ptr orb)
 SALOME_Fake_NamingService ()=default
bool IsTrueNS () const override
std::vector< std::string > repr () override
void init_orb (CORBA::ORB_ptr orb=0) override
void Register (CORBA::Object_ptr ObjRef, const char *Path) override
CORBA::Object_ptr Resolve (const char *Path) override
CORBA::Object_ptr ResolveFirst (const char *Path) override
void Destroy_Name (const char *Path) override
void Destroy_Directory (const char *Path) override
void Destroy_FullDirectory (const char *Path) override
bool Change_Directory (const char *Path) override
std::vector< std::string > list_subdirs () override
std::vector< std::string > list_directory () override
std::vector< std::string > list_directory_recurs () override
SALOME_NamingService_Abstract * clone () override
CORBA::Object_ptr ResolveComponent (const char *hostname, const char *containerName, const char *componentName, const int nbproc=0) override
SALOME_NamingService_Abstract * cloneCoVar ()
static void SetLogContainersFile (const std::string &logFileName)
static std::string GetLogContainersFile ()
static void FlushLogContainersFile ()
static std::string ContainerName (const Engines::ContainerParameters &params)
 build a container name, given a ContainerParameters struct. More...
static std::string ContainerName (const char *ContainerName)
 provide a default container name if empty. More...
static std::string BuildContainerNameForNS (const char *ContainerName, const char *hostname)
 build a string representing a container in Naming Service. More...
static std::string BuildContainerNameForNS (const Engines::ContainerParameters &params, const char *hostname)
static std::string BuildComponentName (const char *hostname, const char *containerName, const char *componentName, const int nbproc)
Static Public Attributes
static constexpr char SEP = '/'
static std::string ReprOfContainersIORS_NoThreadSafe ()
static std::string ReprOfContainersIORS ()
static std::vector< std::pair< std::string, Engines::Container_var > > ListOfContainersInNS_NoThreadSafe ()
static void FlushLogContainersFile_NoThreadSafe ()
static std::vector< std::string > SplitDir (const std::string &fullPath)
std::string _current_dir
Static Private Attributes
static std::mutex _mutex
static std::map< std::string, CORBA::Object_var > _map
static bool _log_container_file_thread_launched = false
static std::string _log_container_file_name
◆ SALOME_Fake_NamingService() [1/2]
SALOME_Fake_NamingService::SALOME_Fake_NamingService ( CORBA::ORB_ptr  orb)
◆ SALOME_Fake_NamingService() [2/2]
SALOME_Fake_NamingService::SALOME_Fake_NamingService ( )
default
Referenced by clone().
◆ BuildComponentName()
std::string SALOME_NamingService_Abstract::BuildComponentName ( const char *  hostname,
const char *  containerName,
const char *  componentName,
const int  nbproc
◆ BuildContainerNameForNS() [1/2]
std::string SALOME_NamingService_Abstract::BuildContainerNameForNS ( const char *  containerName,
Build a string representing the absolute pathname of a container in SALOME_NamingService. This form gives a suffixed containerName in case of multi processor machine.
containerNamename of the container in which the component is instantiated.
hostnamename of the host of the container, without domain names.
the path under the form /Containers/hostname/containerName
See also
ContainerName(const Engines::MachineParameters& params)
References SALOME_ContainerPy::containerName, SALOME_NamingService_Abstract::ContainerName(), test::hostname, and TestKernelHelpers::ret.
Referenced by Abstract_Engines_Container_i::Abstract_Engines_Container_i(), Container_proxy_impl_final::Container_proxy_impl_final(), Engines_MPIContainer_i::Engines_MPIContainer_i(), Engines_Parallel_Container_i::Engines_Parallel_Container_i(), SALOME_ContainerManager::FindContainer(), SALOME_ContainerManager::GiveContainer(), main(), NamingServiceTest::testBuildContainerNameForNS(), and NamingServiceTest::testBuildContainerNameForNSParams().
◆ BuildContainerNameForNS() [2/2]
std::string SALOME_NamingService_Abstract::BuildContainerNameForNS ( const Engines::ContainerParameters &  params,
paramsused as it is, or replaced by FactoryServer if empty.
See also
ContainerName(const char *containerName)
References SALOME_NamingService_Abstract::ContainerName(), test::hostname, and TestKernelHelpers::ret.
◆ Change_Directory()
bool SALOME_Fake_NamingService::Change_Directory ( const char *  Path)
overridevirtual
Implements SALOME_NamingService_Abstract.
References _current_dir, and _mutex.
◆ clone()
SALOME_NamingService_Abstract * SALOME_Fake_NamingService::clone ( )
overridevirtual
◆ cloneCoVar()
◆ ContainerName() [1/2]
std::string SALOME_NamingService_Abstract::ContainerName ( const char *  containerName)
the given container name is returned unchanged, unless it is empty.
containerName
container name, where empty input is replaced by "FactoryServer", without the path.
See also
BuildContainerNameForNS(const char *containerName, const char *hostname)
References SALOME_ContainerPy::containerName, and TestKernelHelpers::ret.
◆ ContainerName() [2/2]
std::string SALOME_NamingService_Abstract::ContainerName ( const Engines::ContainerParameters &  params)
◆ Destroy_Directory()
void SALOME_Fake_NamingService::Destroy_Directory ( const char *  Path)
overridevirtual
◆ Destroy_FullDirectory()
void SALOME_Fake_NamingService::Destroy_FullDirectory ( const char *  Path)
overridevirtual
◆ Destroy_Name()
void SALOME_Fake_NamingService::Destroy_Name ( const char *  Path)
overridevirtual
◆ FlushLogContainersFile()
void SALOME_Fake_NamingService::FlushLogContainersFile ( )
◆ FlushLogContainersFile_NoThreadSafe()
void SALOME_Fake_NamingService::FlushLogContainersFile_NoThreadSafe ( )
staticprivate
◆ GetLogContainersFile()
std::string SALOME_Fake_NamingService::GetLogContainersFile ( )
◆ init_orb()
void SALOME_Fake_NamingService::init_orb ( CORBA::ORB_ptr  orb = 0)
overridevirtual
◆ IsTrueNS()
bool SALOME_Fake_NamingService::IsTrueNS ( ) const
overridevirtual
◆ list_directory()
std::vector< std::string > SALOME_Fake_NamingService::list_directory ( )
overridevirtual
◆ list_directory_recurs()
std::vector< std::string > SALOME_Fake_NamingService::list_directory_recurs ( )
overridevirtual
References _current_dir, and _map.
◆ list_subdirs()
std::vector< std::string > SALOME_Fake_NamingService::list_subdirs ( )
overridevirtual
◆ ListOfContainersInNS_NoThreadSafe()
std::vector< std::pair< std::string, Engines::Container_var > > SALOME_Fake_NamingService::ListOfContainersInNS_NoThreadSafe ( )
staticprivate
◆ Register()
void SALOME_Fake_NamingService::Register ( CORBA::Object_ptr  ObjRef,
const char *  Path
overridevirtual
◆ repr()
std::vector< std::string > SALOME_Fake_NamingService::repr ( )
overridevirtual
◆ ReprOfContainersIORS()
std::string SALOME_Fake_NamingService::ReprOfContainersIORS ( )
staticprivate
◆ ReprOfContainersIORS_NoThreadSafe()
std::string SALOME_Fake_NamingService::ReprOfContainersIORS_NoThreadSafe ( )
staticprivate
◆ Resolve()
◆ ResolveComponent()
CORBA::Object_ptr SALOME_Fake_NamingService::ResolveComponent ( const char *  hostname,
const int  nbproc = 0
overridevirtual
◆ ResolveFirst()
CORBA::Object_ptr SALOME_Fake_NamingService::ResolveFirst ( const char *  Path)
overridevirtual
◆ SetLogContainersFile()
void SALOME_Fake_NamingService::SetLogContainersFile ( const std::string &  logFileName)
◆ SplitDir()
std::vector< std::string > SALOME_Fake_NamingService::SplitDir ( const std::string &  fullPath)
staticprivate
◆ _current_dir
std::string SALOME_Fake_NamingService::_current_dir
mutableprivate
◆ _log_container_file_name
std::string SALOME_Fake_NamingService::_log_container_file_name
staticprivate
◆ _log_container_file_thread_launched
bool SALOME_Fake_NamingService::_log_container_file_thread_launched = false
staticprivate
◆ _map
◆ _mutex
std::mutex SALOME_Fake_NamingService::_mutex
staticprivate
◆ SEP
constexpr char SALOME_NamingService_Container_Abstract::SEP = '/'
staticconstexprinherited
