SALOME_NamingService_Abstract_Decorator Class Reference
#include <SALOME_NamingService_Abstract.hxx>
Inheritance diagram for SALOME_NamingService_Abstract_Decorator:
 SALOME_NamingService_Abstract_Decorator (SALOME_NamingService_Container_Abstract *ns_cont)
void init_orb (CORBA::ORB_ptr orb=0) override
SALOME_NamingService_Container_Abstract * clone () override
void Register (CORBA::Object_ptr ObjRef, const char *Path) override
void Destroy_FullDirectory (const char *Path) override
void Destroy_Name (const char *Path) override
CORBA::Object_ptr Resolve (const char *Path) override
CORBA::Object_ptr ResolveFirst (const char *Path) override
bool IsTrueNS () const override
std::vector< std::string > repr () override
void Destroy_Directory (const char *Path) override
bool Change_Directory (const char *Path) override
std::vector< std::string > list_subdirs () override
std::vector< std::string > list_directory () override
std::vector< std::string > list_directory_recurs () override
CORBA::Object_ptr ResolveComponent (const char *hostname, const char *containerName, const char *componentName, const int nbproc=0) override
SALOME_NamingService_Abstract * cloneCoVar ()
static std::string ContainerName (const Engines::ContainerParameters &params)
 build a container name, given a ContainerParameters struct. More...
static std::string ContainerName (const char *ContainerName)
 provide a default container name if empty. More...
static std::string BuildContainerNameForNS (const char *ContainerName, const char *hostname)
 build a string representing a container in Naming Service. More...
static std::string BuildContainerNameForNS (const Engines::ContainerParameters &params, const char *hostname)
static std::string BuildComponentName (const char *hostname, const char *containerName, const char *componentName, const int nbproc)
Static Public Attributes
static constexpr char SEP = '/'
SALOME_NamingService_Container_Abstract * _ns_cont = nullptr
 take no ownership of decoree More...
◆ SALOME_NamingService_Abstract_Decorator()
SALOME_NamingService_Abstract_Decorator::SALOME_NamingService_Abstract_Decorator ( SALOME_NamingService_Container_Abstract *  ns_cont)
◆ BuildComponentName()
std::string SALOME_NamingService_Abstract::BuildComponentName ( const char *  hostname,
const char *  containerName,
const char *  componentName,
const int  nbproc
◆ BuildContainerNameForNS() [1/2]
std::string SALOME_NamingService_Abstract::BuildContainerNameForNS ( const char *  containerName,
Build a string representing the absolute pathname of a container in SALOME_NamingService. This form gives a suffixed containerName in case of multi processor machine.
containerNamename of the container in which the component is instantiated.
hostnamename of the host of the container, without domain names.
the path under the form /Containers/hostname/containerName
See also
ContainerName(const Engines::MachineParameters& params)
References SALOME_ContainerPy::containerName, SALOME_NamingService_Abstract::ContainerName(), test::hostname, and TestKernelHelpers::ret.
Referenced by Abstract_Engines_Container_i::Abstract_Engines_Container_i(), Container_proxy_impl_final::Container_proxy_impl_final(), Engines_MPIContainer_i::Engines_MPIContainer_i(), Engines_Parallel_Container_i::Engines_Parallel_Container_i(), SALOME_ContainerManager::FindContainer(), SALOME_ContainerManager::GiveContainer(), main(), NamingServiceTest::testBuildContainerNameForNS(), and NamingServiceTest::testBuildContainerNameForNSParams().
◆ BuildContainerNameForNS() [2/2]
std::string SALOME_NamingService_Abstract::BuildContainerNameForNS ( const Engines::ContainerParameters &  params,
paramsused as it is, or replaced by FactoryServer if empty.
See also
ContainerName(const char *containerName)
References SALOME_NamingService_Abstract::ContainerName(), test::hostname, and TestKernelHelpers::ret.
◆ Change_Directory()
bool SALOME_NamingService_Abstract_Decorator::Change_Directory ( const char *  Path)
overridevirtual
◆ clone()
SALOME_NamingService_Container_Abstract * SALOME_NamingService_Abstract_Decorator::clone ( )
overridevirtual
◆ cloneCoVar()
◆ ContainerName() [1/2]
std::string SALOME_NamingService_Abstract::ContainerName ( const char *  containerName)
the given container name is returned unchanged, unless it is empty.
containerName
container name, where empty input is replaced by "FactoryServer", without the path.
See also
BuildContainerNameForNS(const char *containerName, const char *hostname)
References SALOME_ContainerPy::containerName, and TestKernelHelpers::ret.
◆ ContainerName() [2/2]
std::string SALOME_NamingService_Abstract::ContainerName ( const Engines::ContainerParameters &  params)
◆ Destroy_Directory()
void SALOME_NamingService_Abstract_Decorator::Destroy_Directory ( const char *  Path)
overridevirtual
◆ Destroy_FullDirectory()
void SALOME_NamingService_Abstract_Decorator::Destroy_FullDirectory ( const char *  Path)
overridevirtual
◆ Destroy_Name()
void SALOME_NamingService_Abstract_Decorator::Destroy_Name ( const char *  Path)
overridevirtual
◆ init_orb()
void SALOME_NamingService_Abstract_Decorator::init_orb ( CORBA::ORB_ptr  orb = 0)
overridevirtual
◆ IsTrueNS()
bool SALOME_NamingService_Abstract_Decorator::IsTrueNS ( ) const
overridevirtual
◆ list_directory()
std::vector< std::string > SALOME_NamingService_Abstract_Decorator::list_directory ( )
overridevirtual
◆ list_directory_recurs()
std::vector< std::string > SALOME_NamingService_Abstract_Decorator::list_directory_recurs ( )
overridevirtual
◆ list_subdirs()
std::vector< std::string > SALOME_NamingService_Abstract_Decorator::list_subdirs ( )
overridevirtual
◆ Register()
void SALOME_NamingService_Abstract_Decorator::Register ( CORBA::Object_ptr  ObjRef,
const char *  Path
overridevirtual
◆ repr()
std::vector< std::string > SALOME_NamingService_Abstract_Decorator::repr ( )
overridevirtual
◆ Resolve()
CORBA::Object_ptr SALOME_NamingService_Abstract_Decorator::Resolve ( const char *  Path)
overridevirtual
◆ ResolveComponent()
CORBA::Object_ptr SALOME_NamingService_Abstract_Decorator::ResolveComponent ( const char *  hostname,
const int  nbproc = 0
overridevirtual
◆ ResolveFirst()
CORBA::Object_ptr SALOME_NamingService_Abstract_Decorator::ResolveFirst ( const char *  Path)
overridevirtual
◆ _ns_cont
SALOME_NamingService_Container_Abstract* SALOME_NamingService_Abstract_Decorator::_ns_cont = nullptr
Referenced by ResolveComponent().
◆ SEP
constexpr char SALOME_NamingService_Container_Abstract::SEP = '/'
staticconstexprinherited
