20#ifndef FEATURESAPI_MULTITRANSLATION_H_
21#define FEATURESAPI_MULTITRANSLATION_H_
23#include "FeaturesAPI.h"
25#include <FeaturesPlugin_MultiTranslation.h>
27#include <ModelHighAPI_Double.h>
28#include <ModelHighAPI_Integer.h>
29#include <ModelHighAPI_Interface.h>
30#include <ModelHighAPI_Macro.h>
31#include <ModelHighAPI_Selection.h>
48 const std::list<ModelHighAPI_Selection>& theMainObjects,
56 const std::list<ModelHighAPI_Selection>& theMainObjects,
128 const
bool keepSubResults = false);
Interface for Translation feature.
Definition: FeaturesAPI_MultiTranslation.h:39
void setFirstNumber(const ModelHighAPI_Integer &theFirstNumber)
Modify CreationMethod, nb_first_dir attribute of the feature.
Definition: FeaturesAPI_MultiTranslation.cpp:112
void setFirstAxisAndDistance(const ModelHighAPI_Selection &theAxisObject, const ModelHighAPI_Double &theDistance)
Modify CreationMethod, axis_first_dir, step_first_dir attributes of the feature.
Definition: FeaturesAPI_MultiTranslation.cpp:90
Dump wrapped feature.
Definition: FeaturesAPI_MultiTranslation.cpp:128
virtual std::shared_ptr< ModelAPI_AttributeInteger > firstNumber() const
First number of copies.
Definition: FeaturesAPI_MultiTranslation.h:85
void setSecondAxisAndDistance(const ModelHighAPI_Selection &theAxisObject, const ModelHighAPI_Double &theDistance)
Modify CreationMethod, axis_second_dir, step_second_dir attributes of the feature.
Definition: FeaturesAPI_MultiTranslation.cpp:101
void setMainObjects(const std::list< ModelHighAPI_Selection > &theMainObjects)
Set main objects.
Definition: FeaturesAPI_MultiTranslation.cpp:81
virtual std::shared_ptr< ModelAPI_AttributeDouble > secondStep() const
Second step.
virtual std::shared_ptr< ModelAPI_AttributeString > useSecondDir() const
Use the second dir.
virtual ~FeaturesAPI_MultiTranslation()
Definition: FeaturesAPI_MultiTranslation.cpp:76
virtual std::shared_ptr< ModelAPI_AttributeDouble > firstStep() const
First step.
virtual std::shared_ptr< ModelAPI_AttributeSelection > secondAxisObject() const
Second axis object.
void setSecondNumber(const ModelHighAPI_Integer &theSecondNumber)
Modify CreationMethod, nb_second_dir attribute of the feature.
Definition: FeaturesAPI_MultiTranslation.cpp:120
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > mainObjects() const
Main objects.
virtual std::shared_ptr< ModelAPI_AttributeInteger > secondNumber() const
Second number of copies.
FeaturesAPI_MultiTranslation(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_MultiTranslation.cpp:26
virtual std::shared_ptr< ModelAPI_AttributeSelection > firstAxisObject() const
First axis object.
Multi-translation kind.
Definition: FeaturesPlugin_MultiTranslation.h:38
static const std::string & AXIS_SECOND_DIR_ID()
Attribute name of a second direction.
Definition: FeaturesPlugin_MultiTranslation.h:80
static const std::string & STEP_SECOND_DIR_ID()
Attribute name of step for the second direction.
Definition: FeaturesPlugin_MultiTranslation.h:87
static const std::string & NB_COPIES_FIRST_DIR_ID()
Attribute name of number of copies for the first direction.
Definition: FeaturesPlugin_MultiTranslation.h:66
static const std::string & USE_SECOND_DIR_ID()
Attribute name for use second dir.
Definition: FeaturesPlugin_MultiTranslation.h:73
static const std::string & STEP_FIRST_DIR_ID()
Attribute name of step for the first direction.
Definition: FeaturesPlugin_MultiTranslation.h:59
Attribute name of referenced objects.
Definition: FeaturesPlugin_MultiTranslation.h:45
static const std::string & AXIS_FIRST_DIR_ID()
Attribute name of a first direction.
Definition: FeaturesPlugin_MultiTranslation.h:52
static const std::string & NB_COPIES_SECOND_DIR_ID()
Attribute name of number of copies for the second direction.
Definition: FeaturesPlugin_MultiTranslation.h:94
API for the attribute that contains integer (int).
Definition: ModelAPI_AttributeInteger.h:34
Dump engine for the model.
Class for filling ModelAPI_AttributeInteger.
Definition: ModelHighAPI_Integer.h:36
MultiTranslationPtr addMultiTranslation(const std::shared_ptr< ModelAPI_Document > &thePart, const std::list< ModelHighAPI_Selection > &theMainObjects, const ModelHighAPI_Selection &theFirstAxisObject, const ModelHighAPI_Double &theFirstStep, const ModelHighAPI_Integer &theFirstNumber, const ModelHighAPI_Selection &theSecondAxisObject=ModelHighAPI_Selection(), const ModelHighAPI_Double &theSecondStep=ModelHighAPI_Double(), const ModelHighAPI_Integer &theSecondNumber=ModelHighAPI_Integer(), const bool keepSubResults=false)
Create MultiTranslation feature.
Definition: FeaturesAPI_MultiTranslation.cpp:165
