20#ifndef FeaturesAPI_Revolution_H_
21#define FeaturesAPI_Revolution_H_
23#include "FeaturesAPI.h"
25#include <FeaturesPlugin_Revolution.h>
47 const std::list<ModelHighAPI_Selection>& theBaseObjects,
54 const std::list<ModelHighAPI_Selection>& theBaseObjects,
58 const std::string& theSelectionType = std::string());
63 const std::list<ModelHighAPI_Selection>& theBaseObjects,
69 const std::string& theSelectionType = std::string());
131 void execIfBaseNotEmpty();
153 const std::
string());
165 const std::
string());
Interface for Revolution feature.
Definition: FeaturesAPI_Revolution.h:38
virtual std::shared_ptr< ModelAPI_AttributeSelection > axis() const
Axis.
Definition: FeaturesAPI_Revolution.h:95
virtual std::shared_ptr< ModelAPI_AttributeDouble > toAngle() const
To angle.
void setBase(const std::list< ModelHighAPI_Selection > &theBaseObjects)
Modify base attribute of the feature.
Definition: FeaturesAPI_Revolution.cpp:116
virtual std::shared_ptr< ModelAPI_AttributeString > creationMethod() const
Creation method.
virtual std::shared_ptr< ModelAPI_AttributeDouble > fromAngle() const
From angle.
void setAxis(const ModelHighAPI_Selection &theAxis)
Modify axis_object attribute of the feature.
Definition: FeaturesAPI_Revolution.cpp:126
FeaturesAPI_Revolution(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_Revolution.cpp:28
void setNestedSketch(const ModelHighAPI_Reference &theSketch)
Definition: FeaturesAPI_Revolution.cpp:96
virtual std::shared_ptr< ModelAPI_AttributeSelection > toObject() const
To object.
void setAngles(const ModelHighAPI_Double &theToAngle, const ModelHighAPI_Double &theFromAngle)
Modify CreationMethod, to_angle, from_angle attributes of the feature.
Definition: FeaturesAPI_Revolution.cpp:134
virtual std::shared_ptr< ModelAPI_AttributeDouble > fromOffset() const
From offset.
virtual std::shared_ptr< ModelAPI_AttributeReference > sketch() const
Sketch launcher.
virtual ~FeaturesAPI_Revolution()
Definition: FeaturesAPI_Revolution.cpp:90
virtual std::shared_ptr< ModelAPI_AttributeDouble > toOffset() const
To offset.
void setPlanesAndOffsets(const ModelHighAPI_Selection &theToObject, const ModelHighAPI_Double &theToOffset, const ModelHighAPI_Selection &theFromObject, const ModelHighAPI_Double &theFromOffset)
Modify CreationMethod, to_object, to_offset, from_object, from_offset attributes of the feature.
Definition: FeaturesAPI_Revolution.cpp:151
void setAngle(const ModelHighAPI_Double &theAngle)
Definition: FeaturesAPI_Revolution.cpp:145
Dump wrapped feature.
Definition: FeaturesAPI_Revolution.cpp:166
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > baseObjects() const
Base objects.
virtual std::shared_ptr< ModelAPI_AttributeSelection > fromObject() const
From object.
Definition: FeaturesPlugin_CompositeSketch.h:43
static const std::string & SKETCH_ID()
Attribute name of sketch feature.
Definition: FeaturesPlugin_CompositeSketch.h:36
static const std::string & FROM_ANGLE_ID()
Attribute name of revolution from angle.
Definition: FeaturesPlugin_Revolution.h:87
Feature kind.
Definition: FeaturesPlugin_Revolution.h:38
static const std::string & TO_ANGLE_ID()
Attribute name of revolution to angle.
Definition: FeaturesPlugin_Revolution.h:80
static const std::string & TO_OFFSET_ID()
Attribute name of revolution offset.
Definition: FeaturesPlugin_Revolution.h:101
static const std::string & FROM_OFFSET_ID()
Definition: FeaturesPlugin_Revolution.h:115
static const std::string & AXIS_OBJECT_ID()
Attribute name of an revolution axis.
Definition: FeaturesPlugin_Revolution.h:73
static const std::string & TO_OBJECT_ID()
Attribute name of an object to which the revolution grows.
Definition: FeaturesPlugin_Revolution.h:94
Definition: FeaturesPlugin_Revolution.h:45
static const std::string & FROM_OBJECT_ID()
Attribute name of an object from which the revolution grows.
Definition: FeaturesPlugin_Revolution.h:108
Attribute that contains reference to feature (located in the same document).
Definition: ModelAPI_AttributeReference.h:32
Dump engine for the model.
Class for filling ModelAPI_AttributeReference.
Definition: ModelHighAPI_Reference.h:41
RevolutionPtr addRevolution(const std::shared_ptr< ModelAPI_Document > &thePart, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &theAxis, const ModelHighAPI_Double &theAngle)
Create Revolution feature.
Definition: FeaturesAPI_Revolution.cpp:228
