20#ifndef SRC_SKETCHAPI_SKETCHAPI_ROTATION_H_
21#define SRC_SKETCHAPI_SKETCHAPI_ROTATION_H_
25#include "SketchAPI_SketchEntity.h"
29#include <SketchPlugin_MultiRotation.h>
31#include <ModelHighAPI_Interface.h>
32#include <ModelHighAPI_Macro.h>
52 const std::list<std::shared_ptr<ModelAPI_Object> > & theObjects,
56 bool theFullValue =
false,
57 bool theReversed =
false);
API for the attribute that contains integer (int).
Definition: ModelAPI_AttributeInteger.h:34
Attribute that contains reference to an attribute of a feature or reference to a feature (switchable)
Definition: ModelAPI_AttributeRefAttr.h:33
Attribute that contains list of references to features (located in the same document).
Definition: ModelAPI_AttributeRefList.h:33
Represents any object in the data model and in the object browser.
Definition: ModelAPI_Object.h:45
Dump engine for the model.
Class for filling ModelAPI_AttributeInteger.
Definition: ModelHighAPI_Integer.h:36
Class for filling ModelAPI_AttributeRefAttr.
Definition: ModelHighAPI_RefAttr.h:41
Interface for Rotation feature.
Definition: SketchAPI_Rotation.h:44
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > center() const
Center.
Definition: SketchAPI_Rotation.h:79
virtual std::shared_ptr< ModelAPI_AttributeInteger > numberOfObjects() const
Number of objects.
virtual std::shared_ptr< ModelAPI_AttributeRefList > rotatedObjects() const
Rotated objects.
virtual std::shared_ptr< ModelAPI_AttributeRefList > referenceObjects() const
Reference objects.
std::list< std::shared_ptr< SketchAPI_SketchEntity > > rotatedList() const
List of rotated objects.
Definition: SketchAPI_Rotation.cpp:83
virtual std::shared_ptr< ModelAPI_AttributeDouble > angle() const
Angle.
virtual std::shared_ptr< ModelAPI_AttributeRefList > rotationList() const
Rotation list.
Dump wrapped feature.
Definition: SketchAPI_Rotation.cpp:105
virtual std::shared_ptr< ModelAPI_AttributeString > valueType() const
Value type.
virtual ~SketchAPI_Rotation()
Definition: SketchAPI_Rotation.cpp:56
virtual std::shared_ptr< ModelAPI_AttributeBoolean > reversed() const
Negative angle.
SketchAPI_Rotation(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: SketchAPI_Rotation.cpp:28
std::list< std::shared_ptr< SketchAPI_SketchEntity > > rotated() const
Definition: SketchAPI_Rotation.cpp:68
void setRotationList(const std::list< std::shared_ptr< ModelAPI_Object > > &theObjects)
Set list of objects to be rotated.
Definition: SketchAPI_Rotation.cpp:61
static const std::string & ENTITY_A()
First entity for the constraint.
Definition: SketchPlugin_Constraint.h:58
static const std::string & ENTITY_B()
Second entity for the constraint.
Definition: SketchPlugin_Constraint.h:64
static const std::string & REVERSED_ID()
Name of the flag to reverse rotation.
Definition: SketchPlugin_MultiRotation.h:90
static const std::string & NUMBER_OF_OBJECTS_ID()
Total number of objects, initial and translated objects.
Definition: SketchPlugin_MultiRotation.h:83
static const std::string & ANGLE_TYPE()
attribute name for first point
Definition: SketchPlugin_MultiRotation.h:69
static const std::string & ROTATION_LIST_ID()
List of objects to be mirrored.
Definition: SketchPlugin_MultiRotation.h:56
static const std::string & ANGLE_ID()
End point of translation.
Definition: SketchPlugin_MultiRotation.h:76
static const std::string & CENTER_ID()
Center of rotation.
Definition: SketchPlugin_MultiRotation.h:63
Multi-rotation kind.
Definition: SketchPlugin_MultiRotation.h:43
