| | FeaturesAPI_ExtrusionFuse (const std::shared_ptr< ModelAPI_Feature > &theFeature) |
| | Constructor without values. More...
| | FeaturesAPI_ExtrusionFuse (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const std::list< ModelHighAPI_Selection > &theBooleanObjects) |
| | Constructor with values. More...
| | FeaturesAPI_ExtrusionFuse (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Double &theSize, const std::list< ModelHighAPI_Selection > &theBooleanObjects) |
| | FeaturesAPI_ExtrusionFuse (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &theDirection, const std::list< ModelHighAPI_Selection > &theBooleanObjects) |
| | FeaturesAPI_ExtrusionFuse (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &theDirection, const ModelHighAPI_Double &theSize, const std::list< ModelHighAPI_Selection > &theBooleanObjects) |
| | FeaturesAPI_ExtrusionFuse (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Double &theToSize, const ModelHighAPI_Double &theFromSize, const std::list< ModelHighAPI_Selection > &theBooleanObjects) |
| | FeaturesAPI_ExtrusionFuse (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &theDirection, const ModelHighAPI_Double &theToSize, const ModelHighAPI_Double &theFromSize, const std::list< ModelHighAPI_Selection > &theBooleanObjects) |
| | FeaturesAPI_ExtrusionFuse (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &theToObject, const ModelHighAPI_Double &theToOffset, const ModelHighAPI_Selection &theFromObject, const ModelHighAPI_Double &theFromOffset, const std::list< ModelHighAPI_Selection > &theBooleanObjects) |
| | FeaturesAPI_ExtrusionFuse (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &theDirection, const ModelHighAPI_Selection &theToObject, const ModelHighAPI_Double &theToOffset, const ModelHighAPI_Selection &theFromObject, const ModelHighAPI_Double &theFromOffset, const std::list< ModelHighAPI_Selection > &theBooleanObjects) |
| virtual std::shared_ptr< ModelAPI_AttributeReference > | sketch () const |
| | Sketch launcher. More...
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | baseObjects () const |
| | Base objects. More...
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | direction () const |
| | Direction. More...
| virtual std::shared_ptr< ModelAPI_AttributeString > | creationMethod () const |
| | Creation method. More...
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | toSize () const |
| | To size. More...
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | fromSize () const |
| | From size. More...
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | toObject () const |
| | To object. More...
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | toOffset () const |
| | To offset. More...
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | fromObject () const |
| | From object. More...
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | fromOffset () const |
| | From offset. More...
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | booleanObjects () const |
| | Boolean objects. More...
| void | setNestedSketch (const ModelHighAPI_Reference &theSketch) |
| | Modify base attribute of the feature. More...
| void | setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects) |
| void | setDirection (const ModelHighAPI_Selection &theDirection) |
| | Modify direction_object attribute of the feature. More...
| void | setSizes (const ModelHighAPI_Double &theToSize, const ModelHighAPI_Double &theFromSize) |
| | Modify CreationMethod, to_size, from_size attributes of the feature. More...
| void | setSize (const ModelHighAPI_Double &theSize) |
| | Modify creation_method, to_size, from_size attributes of the feature. More...
| void | setPlanesAndOffsets (const ModelHighAPI_Selection &theToObject, const ModelHighAPI_Double &theToOffset, const ModelHighAPI_Selection &theFromObject, const ModelHighAPI_Double &theFromOffset) |
| | Modify creation_method, to_object, to_offset, from_object, from_offset attributes of the feature. More...
| void | setBooleanObjects (const std::list< ModelHighAPI_Selection > &theBooleanObjects) |
| | Modiyfy main_objects attribute of the feature. More...
| | Dump wrapped feature. More...
| | Return ModelAPI_Feature. More...
| | If feature is composite return intefrace for sub-feature by zero-based index, or empty pointer if feature not composite or does not have sub-feature with such index. More...
| | Shortcut for feature()->getKind() More...
| | Shortcut for feature()->execute() More...
| | Shortcut for feature()->data()->setName() More...
| | Shortcut for feature()->data()->name() More...
| | Return firts object of the feature. More...
| | Return all objects of the feature. More...
| | Return default result. Default implementation feature()->lastResult() More...
| | Throw exception to event loop. More...
| | Return name of getter for specified attribute. More...
| | Returns all the vertices produced by this feature. More...
| | Returns all the edges produced by this feature. More...
| | Returns all the wires produced by this feature. More...
| | Returns all the faces produced by this feature. More...
| | Returns all the shells produced by this feature. More...
| | Returns all the solids produced by this feature. More...
Interface for ExtrusionFuse feature.
