| | FeaturesAPI_RevolutionCut (const std::shared_ptr< ModelAPI_Feature > &theFeature) |
| | Constructor without values. More...
| | FeaturesAPI_RevolutionCut (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &theAxis, const std::list< ModelHighAPI_Selection > &theBooleanObjects) |
| | Constructor with values. More...
| | FeaturesAPI_RevolutionCut (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &theAxis, const ModelHighAPI_Double &theAngle, const std::list< ModelHighAPI_Selection > &theBooleanObjects) |
| | FeaturesAPI_RevolutionCut (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &theAxis, const ModelHighAPI_Double &theToAngle, const ModelHighAPI_Double &theFromAngle, const std::list< ModelHighAPI_Selection > &theBooleanObjects) |
| | FeaturesAPI_RevolutionCut (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Selection &theAxis, const ModelHighAPI_Selection &theToObject, const ModelHighAPI_Double &theToOffset, const ModelHighAPI_Selection &theFromObject, const ModelHighAPI_Double &theFromOffset, const std::list< ModelHighAPI_Selection > &theBooleanObjects) |
| virtual std::shared_ptr< ModelAPI_AttributeReference > | sketch () const |
| | Sketch launcher. More...
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | baseObjects () const |
| | Base objects. More...
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | axis () const |
| | Axis. More...
| virtual std::shared_ptr< ModelAPI_AttributeString > | creationMethod () const |
| | Creation method. More...
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | toAngle () const |
| | To angle. More...
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | fromAngle () const |
| | From angle. More...
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | toObject () const |
| | To object. More...
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | toOffset () const |
| | To offset. More...
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | fromObject () const |
| | From object. More...
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | fromOffset () const |
| | From offset. More...
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | booleanObjects () const |
| | Boolean objects. More...
| void | setNestedSketch (const ModelHighAPI_Reference &theSketch) |
| | Modify base attribute of the feature. More...
| void | setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects) |
| void | setAxis (const ModelHighAPI_Selection &theAxis) |
| | Modify axis_object attribute of the feature. More...
| void | setAngles (const ModelHighAPI_Double &theToAngle, const ModelHighAPI_Double &theFromAngle) |
| | Modify CreationMethod, to_angle, from_angle attributes of the feature. More...
| void | setAngle (const ModelHighAPI_Double &theAngle) |
| | Modify creation_method, to_angle, from_angle attributes of the feature. More...
| void | setPlanesAndOffsets (const ModelHighAPI_Selection &theToObject, const ModelHighAPI_Double &theToOffset, const ModelHighAPI_Selection &theFromObject, const ModelHighAPI_Double &theFromOffset) |
| | Modify creation_method, to_object, to_offset, from_object, from_offset attributes of the feature. More...
| void | setBooleanObjects (const std::list< ModelHighAPI_Selection > &theBooleanObjects) |
| | Modiyfy main_objects attribute of the feature. More...
| | Dump wrapped feature. More...
| | Return ModelAPI_Feature. More...
| | If feature is composite return intefrace for sub-feature by zero-based index, or empty pointer if feature not composite or does not have sub-feature with such index. More...
| | Shortcut for feature()->getKind() More...
| | Shortcut for feature()->execute() More...
| | Shortcut for feature()->data()->setName() More...
| | Shortcut for feature()->data()->name() More...
| | Return firts object of the feature. More...
| | Return all objects of the feature. More...
| | Return default result. Default implementation feature()->lastResult() More...
| | Throw exception to event loop. More...
| | Return name of getter for specified attribute. More...
| | Returns all the vertices produced by this feature. More...
| | Returns all the edges produced by this feature. More...
| | Returns all the wires produced by this feature. More...
| | Returns all the faces produced by this feature. More...
| | Returns all the shells produced by this feature. More...
| | Returns all the solids produced by this feature. More...
Interface for RevolutionCut feature.
