GeomAlgoAPI_WireBuilder Class Reference
Allows to create wire-shapes by different parameters. More...
#include <GeomAlgoAPI_WireBuilder.h>
Inheritance diagram for GeomAlgoAPI_WireBuilder:
 Builder type enum. More...
 GeomAlgoAPI_WireBuilder (const ListOfShape &theShapes, const bool theForceOpenWire=false)
 Creates a wire from edges and wires. More...
GEOMALGOAPI_EXPORT void setResult (const GeomShapePtr theShape)
 Sets result shape. More...
GEOMALGOAPI_EXPORT bool addModified (const GeomShapePtr theOldShape, const GeomShapePtr theNewShape)
 Adds modified shape. More...
GEOMALGOAPI_EXPORT bool addGenerated (const GeomShapePtr theOldShape, const GeomShapePtr theNewShape)
 Adds generated shape. More...
GEOMALGOAPI_EXPORT bool addDeleted (const GeomShapePtr theOldShape)
 Adds deleted shape. More...
GEOMALGOAPI_EXPORT void generated (const GeomShapePtr theOldShape, ListOfShape &theNewShapes)
GEOMALGOAPI_EXPORT void modified (const GeomShapePtr theShape, ListOfShape &theNewShapes)
GEOMALGOAPI_EXPORT bool isDeleted (const GeomShapePtr theOldShape)
template<class T >
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
static GeomShapePtr wire (const ListOfShape &theShapes)
static bool isSelfIntersected (const GeomShapePtr &theWire)
 Checks if the wire is self-intersected. More...
 Sets builder type. More...
std::string myError
◆ BuilderType
Builder type enum.
◆ GeomAlgoAPI_WireBuilder()
GeomAlgoAPI_WireBuilder::GeomAlgoAPI_WireBuilder ( const ListOfShape &  theShapes,
const bool  theForceOpenWire = false
[in]theShapeslist of shapes. Only edges and wires allowed.
[in]theForceOpenWireindicates the necessity to split wire in the first vertex if it becomes closed. The edges are not to be consecutive. But they are to be all connected geometrically or topologically.
◆ wire()
GeomShapePtr GeomAlgoAPI_WireBuilder::wire ( const ListOfShape &  theShapes)
[in]theShapeslist of shapes. Only edges and wires allowed. The edges are not to be consecutive. But they are to be all connected geometrically or topologically.
wire created from theShapes. Empty in case of error or bad input.
◆ isSelfIntersected()
bool GeomAlgoAPI_WireBuilder::isSelfIntersected ( const GeomShapePtr &  theWire)
[in]theWirethe wire to be checked
true if the wire is self-intersected, otherwise - false.
◆ setResult()
void GeomAlgoAPI_MakeShapeCustom::setResult ( const GeomShapePtr  theShape)
Sets result shape.
◆ addModified()
bool GeomAlgoAPI_MakeShapeCustom::addModified ( const GeomShapePtr  theOldShape,
◆ addGenerated()
bool GeomAlgoAPI_MakeShapeCustom::addGenerated ( const GeomShapePtr  theOldShape,
◆ addDeleted()
bool GeomAlgoAPI_MakeShapeCustom::addDeleted ( const GeomShapePtr  theOldShape)
Adds deleted shape.
◆ generated()
void GeomAlgoAPI_MakeShapeCustom::generated ( const GeomShapePtr  theOldShape,
ListOfShape &  theNewShapes
the list of shapes generated from the shape theShape
◆ modified()
void GeomAlgoAPI_MakeShapeCustom::modified ( const GeomShapePtr  theShape,
the list of shapes modified from the shape theShape
◆ isDeleted()
bool GeomAlgoAPI_MakeShapeCustom::isDeleted ( const GeomShapePtr  theOldShape)
whether the shape is deleted
◆ initialize()
template<class T >
◆ build()
inlinevirtualinherited
◆ isDone()
status of builder.
◆ shape()
◆ isValid()
◆ mapOfSubShapes()
◆ modifiedCached()
[in]theOldShapebase shape.
◆ check()
◆ prepareNamingFaces()
◆ getCreatedFaces()
the list of created faces.
◆ getError()
the error.
◆ checkValid()
◆ isNewShapesCollected()
◆ collectNewShapes()
◆ cleanNewShapes()
◆ oldShapesForNew()
◆ fixOrientation()
◆ setBuilderType()
Sets builder type.
◆ setDone()
[in]theFlagnew status.
◆ setShape()
Sets result shape.
[in]theShapenew shape.
◆ isValidForHistory()
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
◆ myMap
◆ myError
◆ myCreatedFaces
