| | SketchAPI_BSplinePeriodic (const std::shared_ptr< ModelAPI_Feature > &theFeature) |
| | Constructor without values. More...
| virtual | ~SketchAPI_BSplinePeriodic () |
| | Destructor. More...
| virtual std::shared_ptr< GeomDataAPI_Point2DArray > | poles () const |
| | B-spline poles. More...
| virtual std::shared_ptr< ModelAPI_AttributeDoubleArray > | weights () const |
| | B-spline weights. More...
| virtual std::shared_ptr< ModelAPI_AttributeDoubleArray > | knots () const |
| | B-spline knots. More...
| virtual std::shared_ptr< ModelAPI_AttributeIntArray > | multiplicities () const |
| | Knots multiplicities. More...
| virtual std::shared_ptr< ModelAPI_AttributeInteger > | degree () const |
| | B-spline degree. More...
| virtual std::shared_ptr< GeomDataAPI_Point2D > | startPoint () const |
| | First pole of B-spline. More...
| virtual std::shared_ptr< GeomDataAPI_Point2D > | endPoint () const |
| | Last pole of B-spline. More...
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | external () const |
| | External. More...
| void | setByDegreePolesAndWeights (const ModelHighAPI_Integer &theDegree, const std::list< std::shared_ptr< GeomAPI_Pnt2d > > &thePoles, const std::list< ModelHighAPI_Double > &theWeights) |
| | Set by poles and weights. More...
| void | setByParameters (const ModelHighAPI_Integer &theDegree, const std::list< std::shared_ptr< GeomAPI_Pnt2d > > &thePoles, const std::list< ModelHighAPI_Double > &theWeights, const std::list< ModelHighAPI_Double > &theKnots, const std::list< ModelHighAPI_Integer > &theMults) |
| | Initialize by full set of B-spline parameters. More...
| void | setByExternal (const ModelHighAPI_Selection &theExternal) |
| | Set by external. More...
| std::list< std::shared_ptr< SketchAPI_SketchEntity > > | controlPoles (const std::list< int > ®ular=std::list< int >(), const std::list< int > &auxiliary=std::list< int >()) const |
| | Generate list of construction points coincident with B-spline poles. More...
| std::list< std::shared_ptr< SketchAPI_SketchEntity > > | controlPolygon (const std::list< int > ®ular=std::list< int >(), const std::list< int > &auxiliary=std::list< int >()) const |
| | Generate control polygon for B-spline curve. More...
| bool | insertPole (const int theIndex, const std::shared_ptr< GeomAPI_Pnt2d > &theCoordinates, const ModelHighAPI_Double &theWeight=ModelHighAPI_Double(1.0)) |
| | Insert new pole after the pole with the given index. More...
| | Dump wrapped feature. More...
| std::shared_ptr< ModelAPI_AttributeBoolean > | auxiliary () const |
| | Auxiliary. More...
| void | setAuxiliary (bool theAuxiliary) |
| | Set auxiliary. More...
| | Return ModelAPI_Feature. More...
| | If feature is composite return intefrace for sub-feature by zero-based index, or empty pointer if feature not composite or does not have sub-feature with such index. More...
| | Shortcut for feature()->getKind() More...
| | Shortcut for feature()->execute() More...
| | Shortcut for feature()->data()->setName() More...
| | Shortcut for feature()->data()->name() More...
| | Return firts object of the feature. More...
| | Return all objects of the feature. More...
| | Return default result. Default implementation feature()->lastResult() More...
| | Throw exception to event loop. More...
| | Return name of getter for specified attribute. More...
| | Returns all the vertices produced by this feature. More...
| | Returns all the edges produced by this feature. More...
| | Returns all the wires produced by this feature. More...
| | Returns all the faces produced by this feature. More...
| | Returns all the shells produced by this feature. More...
| | Returns all the solids produced by this feature. More...
Interface for BSplinePeriodic feature.
