This class implements GUI module for CORBA engine-based Python SALOME modules. More...
#include <SALOME_PYQT_Module.h>
| SALOME_PYQT_Module () | |
| Constructor. More... | |
| ~SALOME_PYQT_Module () | |
| Destructor. More... | |
| QString | engineIOR () const |
| Get module engine IOR. More... | |
| void | initialize (CAM_Application *) |
| Initialization of the module. More... | |
| bool | activateModule (SUIT_Study *) |
| Activation of the module. More... | |
| bool | deactivateModule (SUIT_Study *) |
| Deactivation of the module. More... | |
| void | windows (QMap< int, int > &) const |
| Get the dockable windows associated with the module. More... | |
| void | viewManagers (QStringList &) const |
| Define the compatible view windows associated with the module. More... | |
| void | studyActivated () |
| Process study activation. More... | |
| void | contextMenuPopup (const QString &, QMenu *, QString &) |
| Process context popup menu request. More... | |
| void | createPreferences () |
| Export preferences for the Python module. More... | |
| void | preferencesChanged (const QString &, const QString &) |
| Process module's preferences changing. More... | |
| void | studyClosed (SUIT_Study *) |
| Called when study is closed. More... | |
| bool | isDraggable (const SUIT_DataObject *) const |
| Test if object what can be dragged by the user. More... | |
| bool | isDropAccepted (const SUIT_DataObject *) const |
| Test if drop operation can be done on the where object. More... | |
| void | dropObjects (const DataObjectList &, SUIT_DataObject *, const int, Qt::DropAction) |
| Perform drop operation. More... | |
Public Member Functions inherited from SalomeApp_Module | |
| SalomeApp_Module (const QString &) | |
| virtual | ~SalomeApp_Module () |
| virtual QString | engineIOR () const =0 |
| SalomeApp_Application * | getApp () const |
| virtual void | storeVisualParameters (int savePoint) |
| Virtual public. More... | |
| virtual void | restoreVisualParameters (int savePoint) |
| virtual LightApp_Selection * | createSelection () const |
Public Member Functions inherited from LightApp_Module | |
| LightApp_Module (const QString &) | |
| virtual | ~LightApp_Module () |
| virtual void | initialize (CAM_Application *) |
| virtual void | windows (QMap< int, int > &) const |
| virtual void | viewManagers (QStringList &) const |
| virtual void | contextMenuPopup (const QString &, QMenu *, QString &) |
| virtual void | createPreferences () |
| LightApp_Application * | getApp () const |
| virtual void | update (const int) |
| Update something in accordance with update flags. More... | |
| virtual void | updateObjBrowser (bool=true, SUIT_DataObject *=0) |
| virtual void | selectionChanged () |
| virtual void | preferencesChanged (const QString &, const QString &) |
| virtual void | message (const QString &) |
| virtual void | studyActivated () |
| virtual LightApp_Displayer * | displayer () |
| virtual bool | canCopy () const |
| virtual bool | canPaste () const |
| virtual bool | isDraggable (const SUIT_DataObject *) const |
| virtual bool | isDropAccepted (const SUIT_DataObject *) const |
| virtual void | dropObjects (const DataObjectList &, SUIT_DataObject *, const int, Qt::DropAction) |
| virtual void | copy () |
| Copies the current selection into clipboard. More... | |
| virtual void | paste () |
| Pastes the current data in the clipboard. More... | |
| virtual bool | renameAllowed (const QString &) const |
Return true if object can be renamed. More... | |
| virtual bool | renameObject (const QString &, const QString &) |
Return true if rename operation finished successfully, false otherwise. More... | |
| virtual void | updateModuleVisibilityState () |
Public Member Functions inherited from CAM_Module | |
| CAM_Module () | |
| CAM_Module (const QString &) | |
| virtual | ~CAM_Module () |
| Initialize module. More... | |
| QString | name () const |
| Get module (internal) name. More... | |
| QString | moduleName () const |
| Get module title (user name) More... | |
| virtual QPixmap | moduleIcon () const |
| Get module icon. More... | |
| virtual QString | iconName () const |
| Get module icon's name. More... | |
| CAM_DataModel * | dataModel () const |
| Get data model. More... | |
| CAM_Application * | application () const |
| Get application. More... | |
| Create context popup menu. More... | |
| virtual void | updateCommandsStatus () |
| Update menu/toolbar actions. More... | |
| virtual void | putInfo (const QString &, const int=-1) |
| Put the text message into the status bar of the application main window. More... | |
| int | showNotification (const QString &message, const QString &title, int timeout=-1) |
| Shows the notifications with spectified text, title and automatic close timeout. Notification will be automatically closed after specified timeout in msec. If timeout is zero then automatic closing doesn't performed. More... | |
| void | hideNotification (const QString &message) |
| Closes the notifications with spectified text. More... | |
| void | hideNotification (int id) |
| Closes the notifications with spectified identifier. More... | |
| bool | isActiveModule () const |
| Check if the module is active. More... | |
| virtual void | setMenuShown (const bool) |
| Show/hide all module's menus. More... | |
| void | setMenuShown (QAction *, const bool) |
| Show/hide specified menu item. More... | |
| void | setMenuShown (const int, const bool) |
| virtual void | setToolShown (const bool) |
| Show/hide all module's toolbars. More... | |
| void | setToolShown (QAction *, const bool) |
| Show/hide specified toolbar item. More... | |
| void | setToolShown (const int, const bool) |
| Update visibility state of the module objects. More... | |
| virtual bool | activateOperation (int actionId) |
| Activate GUI operation of module by its ID. This method is called from CAM_Application::startOperation(). More... | |
| virtual bool | activateOperation (const QString &actionId) |
| virtual bool | activateOperation (const QString &actionId, const QString &pluginName) |
| Activate GUI operation of module by its ID and pluginName. This method is called from CAM_Application::startOperation(). More... | |
| QtxActionMenuMgr * | menuMgr () const |
| Get menu manager. More... | |
| QtxActionToolMgr * | toolMgr () const |
| Get toolbar manager. More... | |
| QString | makeActionID (const QString &theInModuleActionID) const |
| virtual QAction * | action (const int) const |
| Get action by specified id. More... | |
| virtual int | actionId (const QAction *) const |
| Get action ID. More... | |
| virtual QAction * | createAction (const int, const QString &, const QIcon &, const QString &, const QString &, const int, QObject *=0, const bool=false, QObject *=0, const char *=0, const QString &=QString()) |
| Create new instance of QtxAction and register action with specified id. More... | |
| virtual QAction * | createAction (const int, const QString &, const QIcon &, const QString &, const QString &, const QKeySequence &, QObject *=0, const bool=false, QObject *=0, const char *=0, const QString &=QString()) |
| QtxActionGroup * | createActionGroup (const int, const bool=true) |
| Create new action group. More... | |
| int | createTool (const QString &, const QString &=QString()) |
| Create toolbar with speicifed name. More... | |
| int | createTool (const int, const int, const int=-1) |
| Add toolbar item. More... | |
| int | createTool (const int, const QString &, const int=-1) |
| int | createTool (QAction *, const int, const int=-1, const int=-1) |
| int | createTool (QAction *, const QString &, const int=-1, const int=-1) |
| void | clearTool (const QString &title) |
| int | createMenu (const QString &, const int, const int=-1, const int=-1, const int=-1, QMenu *=0) |
| Create menu or submenu. More... | |
| int | createMenu (const QString &, const QString &, const int=-1, const int=-1, const int=-1) |
| int | createMenu (const int, const int, const int=-1, const int=-1) |
| Add menu item. More... | |
| int | createMenu (const int, const QString &, const int=-1, const int=-1) |
| int | createMenu (QAction *, const int, const int=-1, const int=-1, const int=-1) |
| int | createMenu (QAction *, const QString &, const int=-1, const int=-1, const int=-1) |
| virtual void | logAction (QAction *) |
| Log given action. More... | |
| bool | isActionLoggingEnabled () const |
Return true if action logging is enabled. More... | |
| void | setActionLoggingEnabled (bool) |
| Enable / disable action logging. More... | |
Private Attributes | |
| PyModuleHelper * | myHelper |
Additional Inherited Members | |
Public Slots inherited from LightApp_Module | |
| virtual bool | activateModule (SUIT_Study *) |
| virtual bool | deactivateModule (SUIT_Study *) |
| virtual void | studyClosed (SUIT_Study *) |
| virtual void | onObjectClicked (SUIT_DataObject *, int) |
| Virtual public slot. More... | |
| void | onOBDestroyed () |
| void | MenuItem () |
| virtual void | updateInfoPanel () |
Public Slots inherited from CAM_Module | |
| Activate module. More... | |
| Deactivate module. More... | |
| virtual void | connectToStudy (CAM_Study *) |
| Connect data model of the module to the active study. More... | |
| virtual void | studyChanged (SUIT_Study *, SUIT_Study *) |
| Called when study is changed (obsolete). More... | |
| virtual void | onApplicationClosed (SUIT_Application *) |
| Called when application is closed. More... | |
| virtual void | moduleActionActivated () |
| Called when an action is triggered. More... | |
Static Public Member Functions inherited from CAM_Module | |
| static QAction * | separator () |
| Create separator action. More... | |
Protected Slots inherited from LightApp_Module | |
| virtual void | onModelSaved () |
| virtual void | onModelOpened () |
| virtual void | onModelClosed () |
| virtual void | onOperationStopped (SUIT_Operation *) |
| Virtual protected slot called when operation stopped. More... | |
| virtual void | onOperationDestroyed () |
| Virtual protected slot called when operation destroyed. More... | |
| virtual void | onShowHide () |
| virtual void | onViewManagerAdded (SUIT_ViewManager *) |
| virtual void | onViewManagerRemoved (SUIT_ViewManager *) |
Protected Member Functions inherited from SalomeApp_Module | |
| virtual CAM_DataModel * | createDataModel () |
| virtual void | extractContainers (const SALOME_ListIO &, SALOME_ListIO &) const |
Protected Member Functions inherited from LightApp_Module | |
| virtual QtxPopupMgr * | popupMgr () |
| LightApp_Preferences * | preferences () const |
| virtual bool | reusableOperation (const int id) |
| int | addPreference (const QString &label) |
| int | addPreference (const QString &label, const int pId, const int type=LightApp_Preferences::Auto, const QString §ion=QString(), const QString ¶m=QString()) |
| QVariant | preferenceProperty (const int, const QString &) const |
| void | setPreferenceProperty (const int, const QString &, const QVariant &) |
| void | startOperation (const int) |
| Starts operation with given identifier. More... | |
| virtual LightApp_Operation * | createOperation (const int) const |
| Creates operation with given identifier. More... | |
| virtual void | updateControls () |
| Updates controls. More... | |
| virtual bool | isSelectionCompatible () |
| If return false, selection will be cleared at module activation. More... | |
| LightApp_Operation * | operation (const int) const |
| Returns instance of operation by its id; if there is no operation corresponding to this id, null pointer is returned. More... | |
Protected Member Functions inherited from CAM_Module | |
| Create data model. More... | |
| void | setName (const QString &) |
| Set module (internal) name. More... | |
| virtual void | setModuleName (const QString &) |
| Set module title (user name) More... | |
| int | registerAction (const int, QAction *) |
| Register action in the internal action map. More... | |
| bool | unregisterAction (const int) |
| Unregister action from the internal action map. More... | |
| bool | unregisterAction (QAction *) |
| virtual bool | abortAllOperations () |
Protected Attributes inherited from LightApp_Module | |
| int | myDisplay |
| int | myErase |
| int | myDisplayOnly |
| int | myEraseAll |
| bool | myIsFirstActivate |
Protected Attributes inherited from CAM_Module | |
| QMap< QAction *, QKeySequence > | myActionShortcutMap |
| copy actions shortcut map More... | |
| SALOME_PYQT_Module::SALOME_PYQT_Module | ( | ) |
References myHelper.
| SALOME_PYQT_Module::~SALOME_PYQT_Module | ( | ) |
| study | parent study |
true if activation is successful and false otherwise Reimplemented from LightApp_Module.
References PyModuleHelper::activate(), LightApp_Module::activateModule(), and myHelper.
| context | popup menu context (e.g. "ObjectBrowser") |
| menu | popup menu |
| title | popup menu title (not used) |
References PyModuleHelper::contextMenu(), and myHelper.
References PyModuleHelper::createPreferences(), and myHelper.
true if deactivation is successful and false otherwise Reimplemented from LightApp_Module.
References PyModuleHelper::deactivate(), LightApp_Module::deactivateModule(), and myHelper.
| what | list of data objects being dropped |
| where | target data object for drop operation |
| row | line (child item index) where drop operation is performed to |
| action | current drop action (copy or move) |
References CAM_Module::action(), PyModuleHelper::dropObjects(), and myHelper.
This function tries to get engine IOR from the Python module using engineIOR() function. That function can load module engine using appropriate container if required. If this function is not available in Python module, the default implementation is used which loads engine to the default FactoryServer container.
Implements SalomeApp_Module.
References PyModuleHelper::engineIOR(), SalomeApp_Module::getApp(), SalomeApp_Application::lcc(), myHelper, and CAM_Module::name().
| app | parent application object |
References LightApp_Module::initialize(), PyModuleHelper::initialize(), and myHelper.
| what | data object being tested |
true if object can be dragged or false otherwise Reimplemented from LightApp_Module.
References PyModuleHelper::isDraggable(), and myHelper.
| where | data object being tested |
true if if drop operation is supported by object or false otherwise Reimplemented from LightApp_Module.
References PyModuleHelper::isDropAccepted(), and myHelper.
| section | preference resources section |
| parameter | preference resources parameter name |
References myHelper, and PyModuleHelper::preferencesChanged().
References CAM_Module::application(), myHelper, and PyModuleHelper::studyActivated().
| study | study being closed |
References PyModuleHelper::modelClosed(), myHelper, and LightApp_Module::studyClosed().
| viewList | output list of view windows types |
References myHelper, and PyModuleHelper::viewManagers().
| winMap | output map of dockable windows in form { <window_type> : <dock_area> } |
References myHelper, and PyModuleHelper::windows().
private |
