GeomAlgoAPI_RemoveExtraEdges Class Reference
This tool tries to unify edges and, optionally, faces of the shape that lie on the same geometry. More...
#include <GeomAlgoAPI_RemoveExtraEdges.h>
Inheritance diagram for GeomAlgoAPI_RemoveExtraEdges:
 Builder type enum. More...
 GeomAlgoAPI_RemoveExtraEdges (const GeomShapePtr &theShape, const bool theDoUnionFaces=false)
GEOMALGOAPI_EXPORT void setResult (const GeomShapePtr theShape)
 Sets result shape. More...
GEOMALGOAPI_EXPORT bool addModified (const GeomShapePtr theOldShape, const GeomShapePtr theNewShape)
 Adds modified shape. More...
GEOMALGOAPI_EXPORT bool addGenerated (const GeomShapePtr theOldShape, const GeomShapePtr theNewShape)
 Adds generated shape. More...
GEOMALGOAPI_EXPORT bool addDeleted (const GeomShapePtr theOldShape)
 Adds deleted shape. More...
GEOMALGOAPI_EXPORT void generated (const GeomShapePtr theOldShape, ListOfShape &theNewShapes)
GEOMALGOAPI_EXPORT void modified (const GeomShapePtr theShape, ListOfShape &theNewShapes)
GEOMALGOAPI_EXPORT bool isDeleted (const GeomShapePtr theOldShape)
template<class T >
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
 Sets builder type. More...
std::string myError
It works similar to GeomAlgoAPI_UnifySameDomain, but in addition it tries to remove seam and degenerated edges on spherical surfaces.
◆ BuilderType
Builder type enum.
◆ GeomAlgoAPI_RemoveExtraEdges()
GeomAlgoAPI_RemoveExtraEdges::GeomAlgoAPI_RemoveExtraEdges ( const GeomShapePtr &  theShape,
const bool  theDoUnionFaces = false
[in]theShapebase shape.
[in]theDoUnionFacesboolean flag to enable/disable faces merging.
◆ setResult()
void GeomAlgoAPI_MakeShapeCustom::setResult ( const GeomShapePtr  theShape)
Sets result shape.
◆ addModified()
bool GeomAlgoAPI_MakeShapeCustom::addModified ( const GeomShapePtr  theOldShape,
◆ addGenerated()
bool GeomAlgoAPI_MakeShapeCustom::addGenerated ( const GeomShapePtr  theOldShape,
◆ addDeleted()
bool GeomAlgoAPI_MakeShapeCustom::addDeleted ( const GeomShapePtr  theOldShape)
Adds deleted shape.
◆ generated()
void GeomAlgoAPI_MakeShapeCustom::generated ( const GeomShapePtr  theOldShape,
ListOfShape &  theNewShapes
the list of shapes generated from the shape theShape
◆ modified()
void GeomAlgoAPI_MakeShapeCustom::modified ( const GeomShapePtr  theShape,
the list of shapes modified from the shape theShape
◆ isDeleted()
bool GeomAlgoAPI_MakeShapeCustom::isDeleted ( const GeomShapePtr  theOldShape)
whether the shape is deleted
◆ initialize()
template<class T >
◆ build()
inlinevirtualinherited
◆ isDone()
status of builder.
◆ shape()
◆ isValid()
◆ mapOfSubShapes()
◆ modifiedCached()
[in]theOldShapebase shape.
◆ check()
◆ prepareNamingFaces()
◆ getCreatedFaces()
the list of created faces.
◆ getError()
the error.
◆ checkValid()
◆ isNewShapesCollected()
◆ collectNewShapes()
◆ cleanNewShapes()
◆ oldShapesForNew()
◆ fixOrientation()
◆ setBuilderType()
Sets builder type.
◆ setDone()
[in]theFlagnew status.
◆ setShape()
Sets result shape.
[in]theShapenew shape.
◆ isValidForHistory()
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
◆ myMap
◆ myError
◆ myCreatedFaces
