Allows to add or remove subshapes from a shape. More...
#include <GeomAlgoAPI_ShapeBuilder.h>
Public Types | |
| GeomAlgoAPI_ShapeBuilder () | |
| Creates empty builder. More... | |
| void | removeInternal (const std::shared_ptr< GeomAPI_Shape > theShape) |
| Store new shape as result of removing internal shapes from theShape. More... | |
| void | addInternal (const std::shared_ptr< GeomAPI_Shape > theShape, const ListOfShape &theShapesToAdd) |
| Store new shape as result of adding theShapesToAdd to theShape as internal shapes. More... | |
| GEOMALGOAPI_EXPORT void | init (const ListOfMakeShape &theMakeShapeList) |
| Initializes a class with new list of algorithms. More... | |
| GEOMALGOAPI_EXPORT const ListOfMakeShape & | list () const |
| GEOMALGOAPI_EXPORT void | appendAlgo (const GeomMakeShapePtr theMakeShape) |
| Adds algo to the end of list. More... | |
| virtual GEOMALGOAPI_EXPORT void | generated (const GeomShapePtr theShape, ListOfShape &theHistory) |
| virtual GEOMALGOAPI_EXPORT void | modified (const GeomShapePtr theShape, ListOfShape &theHistory) |
| virtual GEOMALGOAPI_EXPORT bool | isDeleted (const GeomShapePtr theShape) |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
| static void | add (std::shared_ptr< GeomAPI_Shape > theShape, const std::shared_ptr< GeomAPI_Shape > theShapeToAdd) |
| Adds theShapeToAdd in theShape. More... | |
| static void | remove (std::shared_ptr< GeomAPI_Shape > theShape, const std::shared_ptr< GeomAPI_Shape > theShapeToRemove) |
| Removes theShapeToRemove in theShape. More... | |
Protected Attributes | |
| ListOfMakeShape | myListOfMakeShape |
| List of make shape algos. More... | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_ShapeBuilder::GeomAlgoAPI_ShapeBuilder | ( | ) |
static |
| [in] | theShape | shape to modify. |
| [in] | theShapeToAdd | shape which will be added. |
static |
| [in] | theShapeToRemove | shape which will be removed. |
| void GeomAlgoAPI_ShapeBuilder::removeInternal | ( | const std::shared_ptr< GeomAPI_Shape > | theShape | ) |
| [in] | theShape | base shape. |
| void GeomAlgoAPI_ShapeBuilder::addInternal | ( | const std::shared_ptr< GeomAPI_Shape > | theShape, |
| const ListOfShape & | theShapesToAdd | ||
| [in] | theShapesToAdd | shapes which will be added. |
| [in] | theMakeShapeList | list of algorithms. |
| [in] | theMakeShape | algo to be added. |
Reimplemented in GeomAlgoAPI_MakeShapeSet, and GeomAlgoAPI_Pipe.
Reimplemented in GeomAlgoAPI_MakeShapeSet.
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
