Stream lines presentation
Stream lines is a type of presentation transforming the cells with vectors having most similar direction into lines. A streamline can be thought of as the path that a massless particle takes in a vector field. Streamlines are used to convey the structure of a vector field.
To create a Stream lines presentation,
Select a field item in the Object Browser, and
Choose Presentations > Stream lines menu or click
button in the Presentations toolbar.
As a result, Stream lines presentation is published in the Object Browser under selected field and displayed in the 3D Viewer.
Stream lines presentation has the same base parameters as a Scalar map presentation, but in addition it also has own specific ones:
Integration Direction: specifies in which direction(s) streamlines are generated.
