GeomAlgoAPI_Revolution Class Reference
Allows to create the revolution based on a given face, angles and bounding planes. More...
#include <GeomAlgoAPI_Revolution.h>
Inheritance diagram for GeomAlgoAPI_Revolution:
 Builder type enum. More...
 GeomAlgoAPI_Revolution (const GeomShapePtr theBaseShape, const std::shared_ptr< GeomAPI_Ax1 > theAxis, const GeomShapePtr theToShape, const double theToAngle, const GeomShapePtr theFromShape, const double theFromAngle)
 Creates revolution for the given shape. More...
GEOMALGOAPI_EXPORT const ListOfShape & fromShapes () const
GEOMALGOAPI_EXPORT const ListOfShape & toShapes () const
GEOMALGOAPI_EXPORT void addFromShape (const std::shared_ptr< GeomAPI_Shape > theShape)
 Adds a shape to list of from shape. More...
GEOMALGOAPI_EXPORT void setFromShapes (const ListOfShape &theListOfShapes)
 Sets from shapes. More...
GEOMALGOAPI_EXPORT void addToShape (const std::shared_ptr< GeomAPI_Shape > theShape)
 Adds a face to list of to shape. More...
GEOMALGOAPI_EXPORT void setToShapes (const ListOfShape &theListOfShapes)
 Sets to shapes. More...
GEOMALGOAPI_EXPORT void init (const ListOfMakeShape &theMakeShapeList)
 Initializes a class with new list of algorithms. More...
GEOMALGOAPI_EXPORT const ListOfMakeShape & list () const
GEOMALGOAPI_EXPORT void appendAlgo (const GeomMakeShapePtr theMakeShape)
 Adds algo to the end of list. More...
virtual GEOMALGOAPI_EXPORT void generated (const GeomShapePtr theShape, ListOfShape &theHistory)
virtual GEOMALGOAPI_EXPORT void modified (const GeomShapePtr theShape, ListOfShape &theHistory)
virtual GEOMALGOAPI_EXPORT bool isDeleted (const GeomShapePtr theShape)
template<class T >
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
 Sets builder type. More...
 Sets result shape. More...
ListOfMakeShape myListOfMakeShape
 List of make shape algos. More...
std::string myError
Note that only the planar faces are allowed as bounding faces and resulting revolution will be bounded by the infinite planes taken from the faces.
If the bounding plane was specified with the angle then this plane will be rotated around the axis to the value of the angle.
Note that algorithm return only one solid object. So in case when after cutting with bounding planes algorithm got more than one solid it will return the closest to the center of mass of the base face.
◆ BuilderType
Builder type enum.
◆ GeomAlgoAPI_Revolution()
GeomAlgoAPI_Revolution::GeomAlgoAPI_Revolution ( const GeomShapePtr  theBaseShape,
[in]theBaseShapeface for revolution.
[in]theAxisaxis for revolution.
[in]theToShapeto bounding shape. Can be empty. In this case offset will be applied to the basis.
[in]theToAngleto angle.
[in]theFromShapefrom bounding shape. Can be empty. In this case offset will be applied to the basis.
[in]theFromAnglefrom angle.
◆ fromShapes()
const ListOfShape & GeomAlgoAPI_MakeSweep::fromShapes ( ) const
the list of from shapes.
◆ toShapes()
const ListOfShape & GeomAlgoAPI_MakeSweep::toShapes ( ) const
the list of to shapes.
◆ addFromShape()
void GeomAlgoAPI_MakeSweep::addFromShape ( const std::shared_ptr< GeomAPI_Shape >  theShape)
[in]theShapea shape to add.
◆ setFromShapes()
void GeomAlgoAPI_MakeSweep::setFromShapes ( const ListOfShape &  theListOfShapes)
Sets from shapes.
[in]theListOfShapeslist of from shapes.
◆ addToShape()
void GeomAlgoAPI_MakeSweep::addToShape ( const std::shared_ptr< GeomAPI_Shape >  theShape)
[in]theShapea face to add.
◆ setToShapes()
void GeomAlgoAPI_MakeSweep::setToShapes ( const ListOfShape &  theListOfShapes)
Sets to shapes.
[in]theListOfShapeslist of to shapes.
◆ init()
void GeomAlgoAPI_MakeShapeList::init ( const ListOfMakeShape &  theMakeShapeList)
[in]theMakeShapeListlist of algorithms.
◆ list()
const ListOfMakeShape & GeomAlgoAPI_MakeShapeList::list ( ) const
the list reference
◆ appendAlgo()
void GeomAlgoAPI_MakeShapeList::appendAlgo ( const GeomMakeShapePtr  theMakeShape)
[in]theMakeShapealgo to be added.
◆ shape()
const GeomShapePtr GeomAlgoAPI_MakeShapeList::shape ( ) const
a shape built by the shape construction algorithms
◆ generated()
void GeomAlgoAPI_MakeShapeList::generated ( const GeomShapePtr  theShape,
ListOfShape &  theHistory
the list of shapes generated from the shape theShape
Reimplemented in GeomAlgoAPI_MakeShapeSet, and GeomAlgoAPI_Pipe.
◆ modified()
void GeomAlgoAPI_MakeShapeList::modified ( const GeomShapePtr  theShape,
the list of shapes modified from the shape theShape
Reimplemented in GeomAlgoAPI_MakeShapeSet.
◆ isDeleted()
bool GeomAlgoAPI_MakeShapeList::isDeleted ( const GeomShapePtr  theShape)
whether the shape is deleted
◆ initialize()
template<class T >
◆ build()
inlinevirtualinherited
◆ isDone()
status of builder.
◆ isValid()
◆ mapOfSubShapes()
◆ modifiedCached()
ListOfShape &  theNewShapes
[in]theOldShapebase shape.
◆ check()
◆ prepareNamingFaces()
◆ getCreatedFaces()
the list of created faces.
◆ getError()
the error.
◆ checkValid()
◆ isNewShapesCollected()
◆ collectNewShapes()
◆ cleanNewShapes()
◆ oldShapesForNew()
◆ fixOrientation()
◆ setBuilderType()
Sets builder type.
◆ setDone()
[in]theFlagnew status.
◆ setShape()
Sets result shape.
[in]theShapenew shape.
◆ isValidForHistory()
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
◆ myListOfMakeShape
ListOfMakeShape GeomAlgoAPI_MakeShapeList::myListOfMakeShape
◆ myMap
◆ myError
◆ myCreatedFaces
